Have you tried without https://crossorigin.me/alveman wrote:Now the calendar just saying "Loding..." any suggestions? I'm using iCloud calendar.
Martin
Dashticz - Module - Calendar
- HansieNL
Re: Dashticz - Module - Calendar
Blah blah blah
robgeerts
- Domoticz version: 3.7067
This is handled automatically nowadays with the calendarsHansieNL wrote:Have you tried without https://crossorigin.me/alveman wrote:Now the calendar just saying "Loding..." any suggestions? I'm using iCloud calendar.
Martin
Try:
var calendars = {}
calendars.private = { maxitems: 5, icalurl: 'https://p02-calendarws.icloud.com/ca/subscribe/1/XXX' }
columns[1]['blocks'] = [calendars.private]
alveman
Now I have tested this but no luckrobgeerts wrote:This is handled automatically nowadays with the calendarsHansieNL wrote:Have you tried without https://crossorigin.me/alveman wrote:Now the calendar just saying "Loding..." any suggestions? I'm using iCloud calendar.
Martin
Try:and then in your columns:Code: Select all
var calendars = {} calendars.private = { maxitems: 5, icalurl: 'https://p02-calendarws.icloud.com/ca/subscribe/1/XXX' }But, I'm still working on the calendar-module.Code: Select all
//var _ICALENDAR_URL = 'https://p02-calendarws.icloud.com/ca/subscribe/1/XXX';
//var _ICALENDAR_DATEFORMAT = 'YYYY.MM.DD HH:mm';
//var _ICALENDAR_LOCALE = 'en'; //en,hu, etc.
var calendars = {}
calendars.private = { maxitems: 5, icalurl: 'webcal://p02-calendarws.icloud.com/ca/subscribe/1/XXX' }
Also tested both webcal:// and https:// but no difference same result. It's says "Loding..." for like 3 sec then emty. I can wait for the calendar-module
Martin
robgeerts
Could you share your calendar link (only for me, via pm) so I can test it?
(I dont care about your appointments so dont bother about that
alveman
It seems to be a Internet Explorer "bug", just walked by my wallmounted iPad and there was the calendarrobgeerts wrote:Could you share your calendar link (only for me, via pm) so I can test it?
But the output looks lite random calendar objects from 2014 until now.
Martin
- Skärmklipp1.JPG (34.76 KiB) Viewed 2417 times
poudenes
- Domoticz version: 3.8993
After latest update (beta) is see the items sorted correct. Only the repeated items are gone again.
I can share mine as well if you want to test it?
robgeerts
Recurring will be fixed, meanwhile I fixed something in latest beta when multiple events are at the same day/time
robgeerts
New version of the calendar module is available in BETA.
Please test, its not completely finished... 1 step at a time
BACKUP YOUR CUSTOM.JS
- EdwinK
- Domoticz version: BETA
Going to check it out
robgeerts
Could you test recurring events in latest beta??poudenes wrote:After latest update (beta) is see the items sorted correct. Only the repeated items are gone again.
If not working, please pm me your calendar-url and date where recurring events should be..
- mvveelen
I tried the
but that doesn't work (yet ?).
Also, I see some strange behaviour (see attachment): recurring events are shown multiple times, the date is displayed wrong, the times are...wrong.
Work in progress, right
I tried the
maxitems: 5, ......
poudenes
After latest update, It shows all repeated items somewhere in 2018. And the time is 1 hour later then actual in ical calendar.robgeerts wrote:New version of the calendar module is available in BETA.
And it shows 1 time item for next day (this one is for 12th may 2017)
- gielie
- Domoticz version: latest β
I have the calendar working fine only the days and months are in English, is it possible to show this in Dutch?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
robgeerts
"Da kenne we wel regelen"
I'm not at a pc right now but i thought there was a variable called '_CALENDAR_LOCALE' you can set to nl_NL in config.js
- mvveelen
Eh....why does my calendar show these strange line then ? Using the latest beta (about 1 hour ago). Locale is set to NL, is this a bug or something with my setup (2 iCalendar's combined) ?
robgeerts
Wich line?
- mvveelen
I mean lines....see this screenshot: https://www.domoticz.com/forum/viewtopi ... 84#p134107
- EdwinK
Can we have combined calendar's again?mvveelen wrote:Eh....why does my calendar show these strange line then ? Using the latest beta (about 1 hour ago). Locale is set to NL, is this a bug or something with my setup (2 iCalendar's combined) ?
robgeerts
Your calendar shows right at my dashboard, I have this var set in config.js:mvveelen wrote:I mean lines....see this screenshot: https://www.domoticz.com/forum/viewtopi ... 84#p134107
var _ICALENDAR_DATEFORMAT = 'DD.MM HH:mm';
Combined calendars should work again.
- EdwinK
Okay. Going to try them
When I use calendars.combined I get this error message:
Looks like this happens with the private calendar. So, when I got back from work, I will see if I can find out WHY.
