Dashticz - Module - Calendar
HansieNL
Re: Dashticz - Module - Calendar
Post by HansieNL »
alveman wrote:Now the calendar just saying "Loding..." any suggestions? I'm using iCloud calendar.
Martin
Have you tried without https://crossorigin.me/
Blah blah blah
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Martin
This is handled automatically nowadays with the calendars ;)
Try:
var calendars = {}
calendars.private = { maxitems: 5, icalurl: 'https://p02-calendarws.icloud.com/ca/subscribe/1/XXX' }
and then in your columns:
columns[1]['blocks'] = [calendars.private]
But, I'm still working on the calendar-module.
alveman
Post by alveman »
robgeerts wrote:
Martin
Try:
var calendars = {}
Now I have tested this but no luck
//var _ICALENDAR_URL			= 'https://p02-calendarws.icloud.com/ca/subscribe/1/XXX';
//var _ICALENDAR_DATEFORMAT	= 'YYYY.MM.DD HH:mm';
//var _ICALENDAR_LOCALE		= 'en'; //en,hu, etc.
var calendars = {}
calendars.private = { maxitems: 5, icalurl: 'webcal://p02-calendarws.icloud.com/ca/subscribe/1/XXX' }
And changed the output block from 'icalendar' to calendars.private
Also tested both webcal:// and https:// but no difference same result. It's says "Loding..." for like 3 sec then emty. I can wait for the calendar-module ;) , keep up the good work!!
Martin
robgeerts
Post by robgeerts »
Could you share your calendar link (only for me, via pm) so I can test it?
(I dont care about your appointments so dont bother about that ;)
alveman
Post by alveman »
robgeerts wrote:Could you share your calendar link (only for me, via pm) so I can test it?
It seems to be a Internet Explorer "bug", just walked by my wallmounted iPad and there was the calendar :D and it seems to work in Chrome as well. (worked in IE before the update)
But the output looks lite random calendar objects from 2014 until now.
Martin
poudenes
Domoticz version: 3.8993
Post by poudenes »
After latest update (beta) is see the items sorted correct. Only the repeated items are gone again.
I can share mine as well if you want to test it?
robgeerts
Post by robgeerts »
Recurring will be fixed, meanwhile I fixed something in latest beta when multiple events are at the same day/time
robgeerts
Post by robgeerts »
New version of the calendar module is available in BETA.
Please test, its not completely finished... 1 step at a time ;)
BACKUP YOUR CUSTOM.JS
EdwinK
Post by EdwinK »
Going to check it out :)
robgeerts
Post by robgeerts »
poudenes wrote:After latest update (beta) is see the items sorted correct. Only the repeated items are gone again.
Could you test recurring events in latest beta??
If not working, please pm me your calendar-url and date where recurring events should be..
mvveelen
Post by mvveelen »
I tried the
maxitems: 5, ......
but that doesn't work (yet ?).
Also, I see some strange behaviour (see attachment): recurring events are shown multiple times, the date is displayed wrong, the times are...wrong.
Work in progress, right :) ?
Schermafbeelding 2017-05-11 om 14.09.55.png (282.37 KiB) Viewed 2344 times
poudenes
Post by poudenes »
robgeerts wrote:New version of the calendar module is available in BETA.
After latest update, It shows all repeated items somewhere in 2018. And the time is 1 hour later then actual in ical calendar.
And it shows 1 time item for next day (this one is for 12th may 2017)
gielie
Domoticz version: latest β
Post by gielie »
I have the calendar working fine only the days and months are in English, is it possible to show this in Dutch?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
robgeerts
Post by robgeerts »
"Da kenne we wel regelen"
I'm not at a pc right now but i thought there was a variable called '_CALENDAR_LOCALE' you can set to nl_NL in config.js
mvveelen
Post by mvveelen »
Eh....why does my calendar show these strange line then ? Using the latest beta (about 1 hour ago). Locale is set to NL, is this a bug or something with my setup (2 iCalendar's combined) ?
robgeerts
Post by robgeerts »
Wich line?
mvveelen
Post by mvveelen »
I mean lines....see this screenshot: https://www.domoticz.com/forum/viewtopi ... 84#p134107
EdwinK
Post by EdwinK »
mvveelen wrote:Eh....why does my calendar show these strange line then ? Using the latest beta (about 1 hour ago). Locale is set to NL, is this a bug or something with my setup (2 iCalendar's combined) ?
Can we have combined calendar's again?
robgeerts
Post by robgeerts »
mvveelen wrote:I mean lines....see this screenshot: https://www.domoticz.com/forum/viewtopi ... 84#p134107
Your calendar shows right at my dashboard, I have this var set in config.js:
var _ICALENDAR_DATEFORMAT	= 'DD.MM HH:mm';
What do you have set in this variable?
Combined calendars should work again.
EdwinK
Post by EdwinK »
Okay. Going to try them :)
When I use calendars.combined I get this error message:
Error combined calendars
Screen Shot 2017-05-12 at 11.03.48.png (34.22 KiB) Viewed 2213 times
Looks like this happens with the private calendar. So, when I got back from work, I will see if I can find out WHY.
