Dashticz - Feature Requests
HansieNL
Re: Dashticz - Feature Requests
Post by HansieNL »
SuperMouse wrote:Hi all,
Is it also possible to lock items (switches) so the cannot be altered in the dashboard.
If someone accidently presses the presence "aanwezig/afwezi'g" switch you have the wrong data.
Maybe create a seperate page with only that switch?
Blah blah blah
EdwinK
Post by EdwinK »
You can protect switches in Domoticz it self. That way you can't switch it by accident in Dashticz.
Protected
Protected
Screen Shot 2017-05-10 at 20.52.59.png (14.81 KiB) Viewed 4037 times
HansieNL
Post by HansieNL »
Or maybe you can try this code in custom.js. Change to your own IDX , icon and description
//Thuis
function getBlock_6(device,idx){
   $('.block_'+idx);
   var html='';
   html+='<div class="col-xs-4 col-icon">';
      if(device['Status']=='Off') html+='<img src="img/cust_away.png" class="off icon" />';
      else html+='<img src="img/cust_home.png" class="on icon" />';
   html+='</div>';
   html+='<div class="col-xs-8 col-data">';
   html+='<strong class="title">'+device['Name']+'</strong><br />';
   if(device['Status']=='Off') html+='<span class="state">AFWEZIG</span>';
   else html+='<span class="state">AANWEZIG</span>';
   if(_SHOW_LASTUPDATE) html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(_LASTUPDATE_FORMAT)+'</span>';
   html+='</div>';
   return html;
Blah blah blah
HansieNL
Post by HansieNL »
The clock on this page http://flipclockjs.com/ is a nice addition too I think.
Blah blah blah
qwerk
Post by qwerk »
Hi Rob,
Is it possible to make a variable to en/disable the second hand from the STATIONclock?
thanks in advance
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
qwerk wrote:Hi Rob,
thanks in advance
As reported in the bug report-topic, this is already fixed in latest beta!
Derik
Post by Derik »
perhaps better responsive.... [ or do i something wrong?? ]
Now i see on my phone other things then my tablet
grrrr
EdwinK
Post by EdwinK »
As far as I understand, there are 2 different DAshboards now. One for desktop and tablets and another for mobile phone use. See the index2.html and other files. See Rob's post about it.
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
You can do that in domoticz, you can protect the switch (beschermd)
gielie
Domoticz version: latest β
Post by gielie »
This doesnt work, if i protect the presence switch it wont switch automatic when i leave or get home, it stays in the status it is.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
blacksn0w
Post by blacksn0w »
An addition to protect a switch manually in Dashticz would be great, like block[idx]['Protect'] = True
So this problem would be solved by manually assiging the protect status in Dashticz, not in Domoticz.
Swifty
Post by Swifty »
Would it be possible to use ical as a source for the garbage collection module?
Here in the UK we don't seem to have any online source for when collection days are, but I could create a new google calendar that has recurring events for the collection days.
It would be great if the garbage module could use this source, and just pick the next single event (ie. pickup day) and display it nicely (maybe change the garbage bin icon to the colour of the bin being collected, using some flag in the calendar event?)
robgeerts
Post by robgeerts »
You could use the calendar module for this?
Swifty
Post by Swifty »
Can that be used to mimic the garbage collection module, in a nice way?
Eg;
Only show the next single event
Don't display any times (all that's needed is the collection day)
Show a garbage icon, with colour that changes based on some keyword in the event title?
robgeerts
Post by robgeerts »
No, I'll add this to my todo list.
Could you send me the ical-url when you have one?
Swifty
Post by Swifty »
Great, many thanks! :)
I will sort out an ical link tonight.
gielie
Post by gielie »
This is my standby screen.
Is it possible to center the text in the lower blocks, is this something I can do?
- FIBARO FGS223
- Toon
- Kodi Media Server
HansieNL
Post by HansieNL »
blacksn0w wrote:An addition to protect a switch manually in Dashticz would be great, like block[idx]['Protect'] = True
Good feature request. In the meantime you can use the code I already posted where switch function through dashboard is removed:
   $('.block_'+idx);
   var html='';
   html+='</div>';
   html+='</div>';
   return html;
Blah blah blah
robgeerts
Post by robgeerts »
Fixed in latest beta!
Add:
blocks[110] = {}
blocks[110]['protected'] = true;
Swifty
Post by Swifty »
robgeerts wrote:No, I'll add this to my todo list.
I have pm'd you the details of the ical url - hope it helps :)
Locked
