Dashticz - Bug report
robgeerts
- Domoticz version: 3.7067
Please report found bugs here, but only when you've first tried to find a solution.
Always make sure you have the latest (beta) version and cleared your cache. If you get any (related) error in console (F12 on Windows), post it here.
- DewGew
- Domoticz version: V4.10618
Re: Dashticz - Bug report
In latetest master, selector switch is not working on my dashbord then also 'weather' and 'currentweather_big' is not showing any icons in stand by when using new moving icons.
// DewGew
// DewGew
- htilburgs
When using a slider (with a dimmer light) the light turns on to the selected %, but the icon (lightbulb) is not turn on.
When I do a manual refresh, or I set var _DASHTICZ_REFRESH to 1 minute so it refreshes automaticly, then the lightbulb icons turn on.
Actions taken:
- Clear Cache
- New installation (Master & Beta)
Actions taken:
- Clear Cache
Hardware:
koowee
Heating thermostat "minus" selector doesn't do anything, "plus" selector works. It might be bug, but reason might also be that this thermostat is somehow different that other
Tried this with two browsers and also cleaned cache
"ActTime" : 1493974686,
"ServerTime" : "2017-05-05 11:58:06",
"Sunrise" : "05:01",
"Sunset" : "21:41",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "6.0",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 4,
"HardwareName" : "Razberry",
"HardwareTypeVal" : 21,
"HaveTimeout" : false,
"ID" : "0001801",
"LastUpdate" : "2017-05-04 22:36:59",
"Name" : "Heating",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"SetPoint" : "6.0",
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "SetPoint",
"Timers" : "false",
"Type" : "Thermostat",
"TypeImg" : "override_mini",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "330"
"status" : "OK",
"title" : "Devices"
}- rbo0567
- Domoticz version: v4.9701
Yesterday evening I installed the latest Beta. Now my graphs don't display right anymore. I also noticed that screen 2 is partially visible on screen 1.
On my laptop everything looks alright but on my Ipad 2 it's a little messed up. click link for screenshot
https://postimg.org/image/cmbr2ejv3/
CONFIG.js
CONFIG.js
- Spoiler: show
- Spoiler: show
- gielie
- Domoticz version: latest β
I have added my camera to the standby screen and i can see the camera but its kind of greyed out so not very clear.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
- htilburgs
That is the meaning of the standby-screen
This is as designed.
Hardware:
Blueone
The code which refreshes domoticz is commented so the dashboard isn't updated automatically. After uncomment ing it still is always updating
, a complete update does refresh the data. Maybe the buienradar updates are blocking the domoticz update??
last rows from main.js:
//if(typeof(_DEBUG)=='undefined' || _DEBUG===false) setTimeout(function(){ getDevices(); },(_DOMOTICZ_REFRESH*1000));
else {
blacksn0w
Got the same problem on latest beta. If i activate a switch via App or Domoticz itself, it should update after 5 seconds on Dashticz, but it won't. I have to reload to get the new state.Blueone wrote:The code which refreshes domoticz is commented so the dashboard isn't updated automatically. After uncomment ing it still is always updating, a complete update does refresh the data. Maybe the buienradar updates are blocking the domoticz update??
//if(typeof(_DEBUG)=='undefined' || _DEBUG===false) setTimeout(function(){ getDevices(); },(_DOMOTICZ_REFRESH*1000)); } }); } else { //if(typeof(_DEBUG)=='undefined' || _DEBUG===false) setTimeout(function(){ getDevices(); },(_DOMOTICZ_REFRESH*1000)); }
robgeerts
Ok thanks for reporting. Will fix this asap!
Blueone
Thanks, I noticed the dashboard was crashed again this morning, didn't respond to anything and I couldn't open the debugger on my android device.
I debugged it again on my laptop and it appeared to be an external site with a invalid script, 99% of the time the dashboard hangs has something to do with an external site. Maybe there are possibilities to make it more independent from external site or some sort of error handdling when a script error occurs on a external site.
- htilburgs
Like to share which external site / script??
Hardware:
Blueone
Sometimes like nu.nl or weeronline. Or some errors in one of the vendor scripts:
Most of the times is goes oke, but sometimes he browser stops responding after a long period.
- htilburgs
@robgeerts:
When having the var _STANDBY_AFTER_MINUTES = false; in the CONFIG.js, then network console give a lot of errors:
When you set var _STANDBY_AFTER_MINUTES = 1; then this output is gone.
Uncaught TypeError: disableStandby is not a function main.js?v=52:460
at HTMLBodyElement.<anonymous> (main.js?v=52:460)
at HTMLBodyElement.dispatch (jquery.min.js:3)
at HTMLBodyElement.r.handle (jquery.min.js:3)Hardware:
- mlamie
- Domoticz version: 3.5877
I think it is a bug, but don't know for sure. When I click a button to request the graph data and the graph is already displayed on one of the pages it will will not display the graph and is will mess up the graph on the dashboard page it selfs. See screenshot.
P.s. I use the beta version.
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
- DewGew
I add screenshot..there is no icons after last update with new moving icons any ideas???DewGew wrote:In latetest master, selector switch is not working on my dashbord then also 'weather' and 'currentweather_big' is not showing any icons in stand by when using new moving icons.
// DewGew
- standby.png (98.89 KiB) Viewed 26127 times
Blueone
There appear to be a new bug with the thermostat function. Every 5 seconds (the refresh time) there is a class added to the thermostat setpoint. When you increase or decrease the setpoint the action is done for every added class, zo if you have the dashboard open for a couple of minutes the classed several dozens of classes are added to the setpoint, and it is going to change the setpoint for every class and one click will change the setpoint with 10 degrees for example:
robgeerts
Please test in latest beta!Blueone wrote:There appear to be a new bug with the thermostat function. Every 5 seconds (the refresh time) there is a class added to the thermostat setpoint. When you increase or decrease the setpoint the action is done for every added class, zo if you have the dashboard open for a couple of minutes the classed several dozens of classes are added to the setpoint, and it is going to change the setpoint for every class and one click will change the setpoint with 10 degrees for example:
Just tested and seens to work here..DewGew wrote:I add screenshot..there is no icons after last update with new moving icons any ideas???DewGew wrote:In latetest master, selector switch is not working on my dashbord then also 'weather' and 'currentweather_big' is not showing any icons in stand by when using new moving icons.
// DewGew
- htilburgs
@robgeerts, problem is solved in latest beta, thnx!htilburgs wrote:When using a slider (with a dimmer light) the light turns on to the selected %, but the icon (lightbulb) is not turn on.
Actions taken:
- Clear Cache
Hardware:
- htilburgs
@robgeerts, problem is solved in latest beta, thnx!htilburgs wrote:@robgeerts:
When you set var _STANDBY_AFTER_MINUTES = 1; then this output is gone.Code: Select all
Uncaught TypeError: disableStandby is not a function main.js?v=52:460 at HTMLBodyElement.<anonymous> (main.js?v=52:460) at HTMLBodyElement.dispatch (jquery.min.js:3) at HTMLBodyElement.r.handle (jquery.min.js:3)
Hardware:
