Ditto - I purchased a second gateway so that I could use one as a hallway light.xxLeoxx93 wrote:I've two gateways, but I can't see or use the second oneclaudioita wrote:Is it possible to use TWO Xiaomi Gateway in Domoticz?
Is there any way to get this done? With the additional functions it would be sweat to use two gateway.
When I added the second gateway in MiHome it seems to appear in Domoticz devices even though I haven't added another hardware unit for the IP of the new gateway.
However, controlling it does not work, as it says the key is incorrect (since it tries to use the key for the first gateway).
So, I've added another hardware unit in Domoticz, using the key and IP of the second gateway - the log no longer complains about incorrect key, but neither gateway responds... any way to make this work?
