OWL CM180 paring issue
geantvert
Post by geantvert »
Domoticz version: 2.2255
RFxcom FW version: 235
I tried to pari my OWL CM180i (Micro +) to domoticz but it fails and everything was good:
- Oregon protocol enabled (cf attachment)
- new hardware enable in settings (cf attachment)
Any clue about what i'm doing wrong?
Thank a lot for any help
Capture d’écran 2015-02-15 à 18.37.47.jpg (23.17 KiB) Viewed 9779 times
New devices allowed
New devices allowed
Capture d’écran 2015-02-15 à 18.38.06.jpg (22.59 KiB) Viewed 9779 times
RFXCOM FW version
RFXCOM FW version
Capture d’écran 2015-02-15 à 18.37.56.jpg (39.71 KiB) Viewed 9779 times
roblom
Re: OWL CM180 paring issue
Post by roblom »
Should be working with these settings. Are the batteries empty or the distance between the owl and the rfxcom transceiver to big?
geantvert
Post by geantvert »
Ok thanks...
I tried with new batteries and the transmitter near the RFXcom transceiver.
I will try with the rfmngr (win) to see if the transmitter is sending something over the air...
Note that my CMR180 (OWL micro+) is not plugged to his clamp...
geantvert
Post by geantvert »
I have tried with rfxmngr under windows and i can see my OWL:
Packettype = ENERGY
subtype = ELEC3 - OWL CM180
Sequence nbr = 2
ID = 34514
Count = 0
Instant usage = 0 Watt
total usage = 0 Wh
Signal level = 6
Battery = OK
After a reset, ID change:
Packettype = ENERGY
Sequence nbr = 6
ID = 50258
Count = 0
total usage = 0 Wh
Signal level = 8
Battery = Low
But domoticz can see it. Maybe a but in version 2.2255??
Packettype = ENERGY
Sequence nbr = 10
ID = 50258
Count = 0
total usage = 0 Wh
Signal level = 8
Battery = Low
geantvert
Post by geantvert »
I have the same issue in V2.2269 and trie with other battery
simonrg
Domoticz version: 3.8807
Post by simonrg »
Your example with RFXmngr shows all zero value, I think Domoticz only logs changes, so have you tried with the clamps connected?
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
geantvert
Post by geantvert »
You mean that domoticz will add my OWL in devices tab only if value different to 0?
I will try with the clamps connected and keep you in touch
vangent410
Post by vangent410 »
I have EXACT the same symptom. And I also performed the exact same reasoning and checking , including chceking out with Windows PC and RFXtrx433E connected to it.
Is there any solution?
I do not see any trace of the Owl CM180 (in fact CMR10 as it is a Micro+) in the Domoticz log.
vangent4101
Post by vangent4101 »
Nobody willing to help????
Sent from my FEVER using Tapatalk
rich710
Post by rich710 »
I have the same problem, my CM180 shows up in RFXMngr but not in Domoticz, any update in this?
I have enabled Oregon-protocol in domoticz also
Packettype = ENERGY
Sequence nbr = 29
ID = 8992 decimal:35218
Count = 0
total usage = 0 Wh
Signal level = 6 -72dBm
Battery = OK
benboyte
Post by benboyte »
I have the same problem, the protocol is enabled, the "Accept new hardware" checkbox is checked and the RFXCom firmware is up to date but nothing appears in domoticz.
If anybody has a solution...share it please!
benboyte
Post by benboyte »
...I forget to say that the CM180 is detected with RFXmngr.
Does the problem comes from the CM180, RFXcom or Domoticz?
I think it comes from Domoticz as there is nothing about CM180 in the logs.
I would like helping but I don't know where searching.
I would like to have a confirmation that it's a regression.
quazar
Post by quazar »
Still does not seem to be fixed? I can't see my OWL but it used to work a year or so ago...
asjmcguire
Domoticz version: 3.5877
Post by asjmcguire »
Recently re-paired my OWL in the last few months without problems.
However - I am on the stable branch - running v3.5837
AEOTEC ZStick, 11 ZWave Nodes, RFXCOMM, 50ish Byron Sockets.. HE851 (PIR), 2x HE852 (DoorContact)
WS2300, CM180, CC128, 2xTHGR122NX, 2xPiZeroW w/DS18B20, 8Ch 1W Relay Board.
8 Panasonic IP Cams, 1 16ch CCTV DVR + 15 CCTV Cams
Icarus
Post by Icarus »
I have also got my CM180 to work with no problems. Domivicz v3.7518
sycar
Post by sycar »
I've just got a OWl CM180 (micro+) and initially also had the same problem. I was running Domoticz 3.7661 with RFXcom fw 95. I upgraded my RFXcom fw to Type1/1017 and the device immediately showed up in the Dom devices list.
HTH
sycar
kirioss
Post by kirioss »
I have the exact same problem (domoticz not showing the OWL CM180 whereas RFXmngr can see it)
Using domoticz 3.5877 and RFXCOM - RFXtrx433E with latest firmware (Ext/1020)
If someone has an idea...
OzGeo4
Post by OzGeo4 »
Same problem as you (domoticz not showing the OWL CM180 whereas RFXmngr can see it)
Packettype = ENERGY
Sequence nbr = 4
ID = 89F2 decimal:35314
Count = 0
total usage = 0 Wh
Signal level = 7 -64dBm
Battery = OK
domoticz 3.8153
RFXCOM - RFXtrx433E with latest firmware (Ext/1024); also tried with Ext/1020 and Ext2, Type1 & Type2 /1024
Any ideas ?? ...
toasler
Post by toasler »
Hi, this has worked for me:
As the device ID changes when resetting, go to devices, search for the previous OWL device id and delete it by pressing the trash icon.
Then, in the menu of options, settings, general, press the option to allow the discovery of new devices and save the changes.
Now, go back to the list of devices (wait a bit for the transmitter to send a new data and then refresh the list).
The device appears with the new ID. Press the green arrow to add it to your devices.
(remember to change now the adjusts to not allow new devices any more)
I hope it works for you!
Domoticz v4.10717
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver
Version: Ext2/1022
PIFOUBMW
Post by PIFOUBMW »
Hi from France,
I have the same problem since yesterday, I just replaced the batteries but I can't see my CMR180 anymore in domoticz.
Last time I changed the batteries, I had my OWL intuition registration valid but because it is not free anymore, I can't connect anymore to the OWL website to pair my transmitter CMR180 to the OWL intuition module connected to my internet box because the pairing must be set from the website, no way to pair manually in standalone without registration :-(
Then does anyone have an idea to pair or to activate the transmitter without the OWL intuition module ?
Thanks,
