It's possible that caching is the problem
You've got at least 2 columns more right now
I send you a pm with a screenshot but i think the screenshot isn't send with it so here the screenshot.robgeerts wrote:It's working here.
It's possible that caching is the problemCould you clean the cache of the browser?
You've got at least 2 columns more right nowI'll check for the rest of the layout like correct positioning of texts etc.
I did so too, and it didn't work. So, setting it to 9090 made it work. Somehow that is the port that Kodi and Domoticz talk to each other.robgeerts wrote:No, I set my port to 8080 in Kodi, so used that port in Domoticz too.
Thanks, will give it a try!EdKo66 wrote:I did so too, and it didn't work. So, setting it to 9090 made it work. Somehow that is the port that Kodi and Domoticz talk to each other.robgeerts wrote:No, I set my port to 8080 in Kodi, so used that port in Domoticz too.
columns[2]['blocks'] = ['train','traffic']
Too bad... didn't work.robgeerts wrote:Thanks, will give it a try!EdKo66 wrote:I did so too, and it didn't work. So, setting it to 9090 made it work. Somehow that is the port that Kodi and Domoticz talk to each other.robgeerts wrote:No, I set my port to 8080 in Kodi, so used that port in Domoticz too.
Rob ,what Kodi do you use? Application, LibreELEC or OpenELEC?robgeerts wrote:Too bad... didn't work.robgeerts wrote:Thanks, will give it a try!EdKo66 wrote:
I'm using port 9090 now.. (set in kodi and domoticz).
IP + Port is correct:
2017-04-06 20:27:54.424 Kodi: (Kodi) Connected to '192.168.1.11:9090'.
2017-04-06 20:27:54.425 Kodi: (Kodi) Event: 'On'.
The remote is sending a signal but Kodi doesn't do anything...
App on the phone is working correctly (having the same ip/port)
Done!HansieNL wrote:Maybe an icon in front of the text?
fa-train / fa-car
LibreElec, should work out of the box..HansieNL wrote: Rob ,what Kodi do you use? Application, LibreELEC or OpenELEC?
If you downloaded it to a subfolder, you have to call it like this:Dropshot wrote:This dashboard looks amazing!
I've downloaded and extracted the zip to a subfolder in domoticz and changed CONFIG. Question: should it run instantly, or am I missing something, since I don't see a new dashboard?
Maartenkr wrote:This is really great!
2 quesions
how do I put a name above it like switch?
and how can i get buienradar back the map?
var blocks{}Code: Select all
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars';
columns[1]['blocks'] = ['blocktitle_1',106,204,248,295]
I tried this, for my scene with idx 3, and it works:SwordFish wrote:I'm filling in my dashboard and i noticed that a block with a scene in my case never gets bigger than 4 even if i fill in 12.
Is this correct and that works only with dimmers?
It also don't work if i do idx_3.
Edit: Also the calendar button isn't displaying correct.
var blocks = {}
blocks['s3'] = {}
blocks['s3']['width'] = 12;
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1','s1','s3',233,62]
columns[1]['width'] = 5;
Damm those quotes, i only fill them in by columnsrobgeerts wrote:I tried this, for my scene with idx 3, and it works:SwordFish wrote:I'm filling in my dashboard and i noticed that a block with a scene in my case never gets bigger than 4 even if i fill in 12.
Whats wrong with the calendar button?Code: Select all
var blocks = {} blocks['s3'] = {} blocks['s3']['width'] = 12; var columns = {} columns[1] = {} columns[1]['blocks'] = ['blocktitle_1','s1','s3',233,62] columns[1]['width'] = 5;
Edit: Sorry, i see your screenshot now
