Locked
robgeerts
Domoticz version: 3.7067
Re: New Dashboard Design v2, with custom positioning
Post by robgeerts »
It's working here.
It's possible that caching is the problem ;) Could you clean the cache of the browser?
You've got at least 2 columns more right now :) I'll check for the rest of the layout like correct positioning of texts etc.
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
robgeerts wrote:It's working here.
I send you a pm with a screenshot but i think the screenshot isn't send with it so here the screenshot.
EdwinK
Post by EdwinK »
robgeerts wrote:No, I set my port to 8080 in Kodi, so used that port in Domoticz too.
I did so too, and it didn't work. So, setting it to 9090 made it work. Somehow that is the port that Kodi and Domoticz talk to each other.
SwordFish
Post by SwordFish »
Its works great. Still not done but will go on tomorrow.
robgeerts
Post by robgeerts »
Thanks, will give it a try!
robgeerts
Post by robgeerts »
Train and traffic info (both dutch) are working again:
Sample usage:
columns[2]['blocks'] = ['train','traffic']
robgeerts
Post by robgeerts »
Too bad... didn't work.
I'm using port 9090 now.. (set in kodi and domoticz).
IP + Port is correct:
2017-04-06 20:27:54.424 Kodi: (Kodi) Connected to '192.168.1.11:9090'.
2017-04-06 20:27:54.425 Kodi: (Kodi) Event: 'On'.
The remote is sending a signal but Kodi doesn't do anything...
App on the phone is working correctly (having the same ip/port)
HansieNL
Post by HansieNL »
Maybe an icon in front of the text?
fa-train / fa-car
Blah blah blah
HansieNL
Post by HansieNL »
Rob ,what Kodi do you use? Application, LibreELEC or OpenELEC?
Blah blah blah
robgeerts
Post by robgeerts »
HansieNL wrote:Maybe an icon in front of the text?
fa-train / fa-car
Done!
HansieNL wrote: Rob ,what Kodi do you use? Application, LibreELEC or OpenELEC?
LibreElec, should work out of the box..
HansieNL
Post by HansieNL »
I had same kind of problem. I couldn't use Kodi (LibreELEC) in Domoticz a few months ago, but it worked in OpenELEC. Kore app worked well with both versions. OpenELEC and LibreELEC seems not to handle the remote control exactly the same way. I did a LibreELEC update and now it works (just checked to be sure).
Have you already checked if there's a LibreELEC update for your device.
Blah blah blah
robgeerts
Post by robgeerts »
Thanks, I'll check later.
Currently I'm working on a multiple screen-function (as requested bij @SwordFish via PM).
This means, you can have 3 (or whatever) columns on the main screen but you can swipe it to left/right for more columns.
This way you can create 1 dashboard for switches, sliders and stuff like that and 1 dashboard for media players, news etc..
SwordFish
Post by SwordFish »
Thanks for that. You really keep going tonight ;)
Bydeway I use the windows version of Kodi, maybe that is the difference.
Dropshot
Post by Dropshot »
This dashboard looks amazing!
I've downloaded and extracted the zip to a subfolder in domoticz and changed CONFIG. Question: should it run instantly, or am I missing something, since I don't see a new dashboard?
Maartenkr
Domoticz version: 3.7196
Post by Maartenkr »
This is really great!
2 quesions
how do I put a name above it like switch?
and how can i get buienradar back the map?
robgeerts
Post by robgeerts »
Dropshot wrote:This dashboard looks amazing!
If you downloaded it to a subfolder, you have to call it like this:
http://192.168.1.20:8084/subfolder/index.html
So, first your regular domoticz-path, then subfolder, then index.html
Maartenkr wrote:This is really great!
2 quesions
You can enter a title by defining him first, in config.js just after
var blocks{}
like:
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars';
If you've done this, you can use it like:
columns[1]['blocks'] = ['blocktitle_1',106,204,248,295]
What do you mean with your question about buienradar?
SwordFish
Post by SwordFish »
I'm filling in my dashboard and i noticed that a block with a scene in my case never gets bigger than 4 even if i fill in 12.
Is this correct and that works only with dimmers?
It also don't work if i do idx_3.
Edit: Also the calendar button isn't displaying correct.
Sorry i have the time. Had surgery and sitting at home 8-)
robgeerts
Post by robgeerts »
SwordFish wrote:I'm filling in my dashboard and i noticed that a block with a scene in my case never gets bigger than 4 even if i fill in 12.
I tried this, for my scene with idx 3, and it works:
var blocks = {}
blocks['s3'] = {}
blocks['s3']['width'] = 12;
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1','s1','s3',233,62]
columns[1]['width'] = 5;
Whats wrong with the calendar button?
Edit: Sorry, i see your screenshot now ;)
SwordFish
Post by SwordFish »
var blocks = {}
blocks['s3'] = {}
var columns = {}
columns[1] = {}
Damm those quotes, i only fill them in by columns :oops:
robgeerts
Post by robgeerts »
Preview with multiple dashboards:
Locked
