doxikus
Post by doxikus »
doxikus wrote:Hi Guys,
I have gateway working for more than two weeks and here is few strange things that I want to share with you here, maybe someone mentioned earlier here but here is my problem. I have gateway with enabled developer mode, IP address is assigned via dhcp, on my phone with MI app I can controll light, radio, add sensor (I have one temp sensor and wireless switch), found and pair works great, I have also mylight led bulb which is under app found and controlled. When I move to domoticz and add gateway with all paired device it will work with no problem, but now is problem with phone app when I open It will report that gateway is offline, mylight also (led bulb have assigned static IP). I repeat control over domoticz works great, but my main concern is what if I want to add new device trough app!? Do I need to reset gateway add/adopt devices and agin pair in domoticz (add ip address and new password), enable developer mode!?
I can see Corbin have same issues as I. I think I have resolve my problem just moving gateway from one side room to another. Maybe I have found "dead spot" for my home WIFI, strange but ok, after I have moved GTW working normal over this few days. My main concern is if I order new devices how to pair them, but again now it is working.
marcotrumpet
Post by marcotrumpet »
bing69 wrote:
marcotrumpet wrote:Does anybody know how to write a lua script to turn on/off lights like the mihome app does?
+1
It seems I did it.
I made 2 variables (the one in this image, sorry but I'm italian)
variables
variables
Than I set the delay off of the switch at 1 sec.
The blocky event for "click --> light on" and "click at the same wireless switch --> light off" looks like this
I try it whit 2 dummy switch, I'll try as soon as possibly with the real one.
xbox2610
Post by xbox2610 »
Hello I would like to ask if the WiFi switch of Xiaomi you work there on Domoticz. (Xiaomi Mi Smart Home Wireless Switch)
Thank
juzx
Post by juzx »
xbox2610 wrote:Hello I would like to ask if the WiFi switch of Xiaomi you work there on Domoticz. (Xiaomi Mi Smart Home Wireless Switch)
Thank
No. At the moment only the Zigbee version works.
bertbigb
Post by bertbigb »
corbin wrote:for anyone having problems with switches, try deleting and re-adding them.
I've also made some changes at https://github.com/corbinmunce/domoticz that will help with some of the switches.
I removed the switch and the cube and then reinstall them but only the first movement or click is seen and afterwards no reaction in Domoticz to any state change. Is there something more i can inspect?
I'm on DomoticZ beta V3.7151
Best regards Bert
Synology DS1517+ - DSM 6.2
xbox2610
Post by xbox2610 »
I have the same problem but it seems that you can not find a solution
deennoo
Post by deennoo »
You need to add a 1sec to off on switch edit. And clik off on widget.
As this beta this still need more improvement
http://domo-attitude.fr
bertbigb
Post by bertbigb »
Ok deenoo, thanks for your answer for now that is indeed a solution.
I hope the final solution will be found soon, but with your suggestion i can cope for now.
Best regards Bert
ReX83
Post by ReX83 »
ReX83 wrote:I am now struggling to get notifications work: I can send (from the web interface) a manual notification to my Android device, but any notification I setup under the Xiaomi Plug, Click Button or Door Sensor is not sent at all. I can't see in the log (the one available via the web interface) any message about the attempt to send the notification.
Anyone with this problem?
corbin
Post by corbin »
did you compile from https://github.com/corbinmunce/domoticz ?
the changes I mentioned above are not in the official beta as we haven't fully tested some other recent changes.
schurgan
Post by schurgan »
Hello, I have the same problem with SmartSwitch and Cube. But it does not help. All your suggestions I have tried. I hope you will soon find final solution. Fortunately, I have made backup of version 3.6838. In the version, everything has still worked.
cocapic
Post by cocapic »
I read only the half of the full post sorry ... But i want to share my worries on the plug !
As I find that plugs are dangerous with an adapter I easely opened 3 of them and replaced pin with cable and trying to directly integrated in the outlet box in the wall. But range of mi plugs are a nightmare, out of there casing and specially when a charge on the ouptut
So did someone figure out the range or open plugs to integrate it ?
I taken some pics of the network board in the plug who can easely be moved from one plug to another keeping the association, also we can see a classic zigbee component http://www.nxp.com/documents/data_sheet/JN5169.pdf so plug should work as a repeter
deennoo
Post by deennoo »
you can find a great how to hack xiaomi sensor here : http://faire-ca-soi-meme.fr/hack/2017/0 ... ty-sensor/
and here a zigbee sniffer : http://faire-ca-soi-meme.fr/hack/2017/0 ... e-sniffer/
cocapic
Post by cocapic »
great ! :) merci deenoo
apazga
Post by apazga »
I just added my Xiaomi Gateway to my new Domoticz installation and I see no new sensors. I have almost 100 sensors working fine (ZWave, Yeelight, RFX, Bluetooth...)
Log shows:
2017-03-30 20:54:51.785 XiaomiGateway: New Device Found (0153914c)
2017-03-30 20:54:51.789 {"cmd":"read_ack","model":"magnet","sid":"158d000153914c","short_id":26728,"data":"{\"status\":\"close\"}"}
But no new devices appear on Devices list.
- Accept new hardware devices is enabled
- Device is added and working on Mi Home app
Thanks in advance.
PD: Should I update devices firmware that Mi Home app suggests?
Domoticz beta: 3.7207 (latest)
apazga
Post by apazga »
Answering myself: Just had to wait a few hours (I really don't know why), but they appeared.
In any case, it will be nice to know if I should update or not the firmware ^_^
Thanks anyway.
deennoo
Post by deennoo »
apazga wrote:Answering myself: Just had to wait a few hours (I really don't know why), but they appeared.
Thanks anyway.
On the gateway ? From which version to which one ?
xxLeoxx93
Post by xxLeoxx93 »
is there any way to add two gateways to domoticz? i tried to add a second one, but it's not detected proberly :( Also I can't edit my "Xiaomi Smart Wireless Switch" after I switched it from the "Switch Type" from "Selector" to "On/Off". The edit button doesn't work anymore.
I'm on the latest beta 3.7212 on Debian/Beaglebone Black
apazga
Post by apazga »
Thanks anyway.
From version 2.23 to new version (I don't know)
farhanito
Post by farhanito »
i see they have a firmware update for the gateway.
from 1.4.1_143.0141 to 1.4.1_144.0141
haven't updated yet, though.
hopefully they enable the power consumption API for the sockets
