Lua script - send notification when button is open for 30 seconds
lukcinek
Post by lukcinek »
I have problem to make script to send notification to mail or pushover only when my fridgedoor is open longer than 30s.
Mayby You guys will help me?
Best regards
heggink
Domoticz version: 12451
Re: Lua script - send notification when button is open for 30 seconds
Post by heggink »
Dummy switch with on delay? Won't switch on until after 30 seconds..
P1 meter & solar panel
lukcinek
Post by lukcinek »
Thx for answer but I don't understand :(
Maybe You can write it more precisely ?
Best regards
Edit:
Ok. I know what You mean
It doesn't work
I think maybe becouse my Fridge Door switch is "contact" type
Maybe there is some simple way to do that in lua script?
jvdz
Domoticz version: 4.107
Post by jvdz »
How does domoticz currently get the information about the refrigerator door status (Open/Close)?
Is it simply a swith is Domoticz of which you want to test whether it is in the Open status for 30 seconds?
Jos
lvsigo
Post by lvsigo »
script_time_demo.lua :shock:
Bikey
Domoticz version: 2020.x
Post by Bikey »
heggink wrote:Dummy switch with on delay? Won't switch on until after 30 seconds..
That's not going to work: it ignores "Off" commands during that period so it will switch on after 30 seconds even if the door was closed again within that time.
heggink
Post by heggink »
That's why I suggested a dummy device: a contact device does not have an on/off delay so create a dummy device that has an on delay of 30 seconds and a script behind it. Then build a lua/blocky that switches this device On on open and Off on closed. If the door gets closed before the dummy switches on then the dummy gets switched off and never switches on (the on delay is reset). I just tested it and it works as expected (open window, dummy switches on after 10 secs in my case, close window within 10 secs and the dummy never switches on). I used 2 simple blockies to switch the dummy based on the window sensor.
Bikey
Post by Bikey »
A contact device indeed does nog have a delay, but you could change it to a regular on/of switch. Then however it does not work because, like I mentioned the device itself seems to ignore the "off" command during its delay time. It does however work - as you suggested - with an additional dummy switch which has a delay.
This script works fine:
local Notification = 'TestSwitch'
-- set your delay at the switch properties of the 'TestSwitch'
local TestContact = 'TestContact'
    if devicechanged[TestContact] == 'On'
    then
        commandArray[Notification]='On'
    if devicechanged[TestContact] == 'Off'
    then
        commandArray[Notification]='Off'
   if devicechanged[Notification] == 'On'
    then
        print('Door was open too long!')
heggink
Post by heggink »
Never tried to switch a 'contact as a regular switch' with a delay. Good to know it does not work that way.
For me, I typically use dummy devices as it allows more granular understanding of where things go wrong in my scripts (I can see the states independently and I can test manually before tying to a real device). Downside is that I have a LOT of dummy devices :-) and probably not so good programming skills that I need all this debugging :D .
jimtrout87
Post by jimtrout87 »
If you use the Fuction time diff you may be able to do it without a a dummy switch but you would need a variable if you didnt want to be constantly notified. I dont have any contacts so not sure how they report back but using below you should be able to get it working.
-- script_Fridge.lua
function timedifference(s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   difference = os.difftime (t1, t2)
   return difference
if (otherdevices['Fridge Conact'] == 'Off' and timedifference(otherdevices_lastupdate['Fidge Contact']) > 30) then
	commandArray['SendNotification']='Fridge Open for more than 30 Seconds'
lukcinek
Post by lukcinek »
I try Your script but I don't know how to define variable and add it to script.
When I use Your script without variable Domoticz hangs and I receive notification all the time.
I will try version with Dummy switch.
EDIT:
Thx for Dummy switch idea but I have strange problem. I made Dummy switch named (Lodówka1). My Fridge door switch is (Drzwi - Lodówka). I made two Blocky Scripts but everytime I activate them and try opem my fridge my Dummy switch do nothing. When I open my Blocky scripts page my new two script are Purple colour and deactivated (mayby someone had this problem - I see Purple colour for he first time)
Thanks Everyone for help
Best regards
jimtrout87
Not seen purple before but a quick look on Events Wiki - "Purple = Disabled because a missing device was used [ Domoticz stops this Blockly automatic! ]"
Both devices showing in switches ok?
Once sorted you probably want to change the drop down on the right from "All" to "Device" and you could use a else if for the off statement too for the off statement.
If you want to use the time one. Create a variable under Setup > More Options > User Variables > give it a name, type = integer, Value = 0
- script_Fridge.lua
   t1 = os.time()
   return difference
if (uservariables['Variable name'] == 0 and otherdevices['Fridge Conact'] == 'Open' and timedifference(otherdevices_lastupdate['Fidge Contact']) > 30) then
   commandArray['Variable:Variable name'] = '1'
elseif (uservariables['Variable name'] == 1 and otherdevices['Fridge Conact'] == 'Closed' then
   commandArray['Variable:Variable name'] = '0'
lukcinek
Post by lukcinek »
Thx a lot for help
I changed All to Device and now everythong works!:)
I will also try Your script some time later and write if works.
EDIT:
It works like a charm:)
There was one bracket missing in Your code (in this line - elseif (uservariables['fridge'] == 1 and otherdevices['Drzwi - Lodówka']) == 'Closed' then - but it works! Thank You very much!
Best regards
ensingg
Post by ensingg »
Please post your script. I need a similar option. I have a magnetic switch on a gate. I like a notification when the gate if open for more than 30 sec without closing.
I do have a device script that triggers when the gate opens. But where should I put the timer?
When I change the event to a ALL or TIME it will fire up every minute, but the devicechanged command gives a NIL.
And furthermore the interval should be less that the 1 minute for the TIME scripts.
