Lua script - send notification when button is open for 30 seconds
lukcinek
I have problem to make script to send notification to mail or pushover only when my fridgedoor is open longer than 30s.
Mayby You guys will help me?
Best regards
Best regards
- heggink
- Domoticz version: 12451
Re: Lua script - send notification when button is open for 30 seconds
Dummy switch with on delay? Won't switch on until after 30 seconds..
P1 meter & solar panel
lukcinek
Thx for answer but I don't understand
Maybe You can write it more precisely ?
Best regards
Edit:
Ok. I know what You mean
It doesn't work
I think maybe becouse my Fridge Door switch is "contact" type
Maybe there is some simple way to do that in lua script?
Best regards
Edit:
It doesn't work
- jvdz
- Domoticz version: 4.107
How does domoticz currently get the information about the refrigerator door status (Open/Close)?
Is it simply a swith is Domoticz of which you want to test whether it is in the Open status for 30 seconds?
Jos
Jos
lvsigo
script_time_demo.lua
Bikey
- Domoticz version: 2020.x
That's not going to work: it ignores "Off" commands during that period so it will switch on after 30 seconds even if the door was closed again within that time.heggink wrote:Dummy switch with on delay? Won't switch on until after 30 seconds..
- heggink
That's why I suggested a dummy device: a contact device does not have an on/off delay so create a dummy device that has an on delay of 30 seconds and a script behind it. Then build a lua/blocky that switches this device On on open and Off on closed. If the door gets closed before the dummy switches on then the dummy gets switched off and never switches on (the on delay is reset). I just tested it and it works as expected (open window, dummy switches on after 10 secs in my case, close window within 10 secs and the dummy never switches on). I used 2 simple blockies to switch the dummy based on the window sensor.
Bikey
A contact device indeed does nog have a delay, but you could change it to a regular on/of switch. Then however it does not work because, like I mentioned the device itself seems to ignore the "off" command during its delay time. It does however work - as you suggested - with an additional dummy switch which has a delay.
This script works fine:
local Notification = 'TestSwitch'
-- set your delay at the switch properties of the 'TestSwitch'
local TestContact = 'TestContact'
if devicechanged[TestContact] == 'On'
then
commandArray[Notification]='On'
if devicechanged[TestContact] == 'Off'
then
commandArray[Notification]='Off'
if devicechanged[Notification] == 'On'
then
print('Door was open too long!')
return commandArray- heggink
Never tried to switch a 'contact as a regular switch' with a delay. Good to know it does not work that way.
For me, I typically use dummy devices as it allows more granular understanding of where things go wrong in my scripts (I can see the states independently and I can test manually before tying to a real device). Downside is that I have a LOT of dummy devices
and probably not so good programming skills that I need all this debugging
jimtrout87
If you use the Fuction time diff you may be able to do it without a a dummy switch but you would need a variable if you didnt want to be constantly notified. I dont have any contacts so not sure how they report back but using below you should be able to get it working.
-- script_Fridge.lua
function timedifference(s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
return difference
if (otherdevices['Fridge Conact'] == 'Off' and timedifference(otherdevices_lastupdate['Fidge Contact']) > 30) then
commandArray['SendNotification']='Fridge Open for more than 30 Seconds'
lukcinek
I try Your script but I don't know how to define variable and add it to script.
When I use Your script without variable Domoticz hangs and I receive notification all the time.
I will try version with Dummy switch.
EDIT:
Thx for Dummy switch idea but I have strange problem. I made Dummy switch named (Lodówka1). My Fridge door switch is (Drzwi - Lodówka). I made two Blocky Scripts but everytime I activate them and try opem my fridge my Dummy switch do nothing. When I open my Blocky scripts page my new two script are Purple colour and deactivated (mayby someone had this problem - I see Purple colour for he first time)
Thanks Everyone for help
Best regards
EDIT:
Best regards
- lodowka.jpg (151.32 KiB) Viewed 7881 times
jimtrout87
Not seen purple before but a quick look on Events Wiki - "Purple = Disabled because a missing device was used [ Domoticz stops this Blockly automatic! ]"
Both devices showing in switches ok?
Once sorted you probably want to change the drop down on the right from "All" to "Device" and you could use a else if for the off statement too for the off statement.
If you want to use the time one. Create a variable under Setup > More Options > User Variables > give it a name, type = integer, Value = 0
- script_Fridge.lua
t1 = os.time()
return difference
if (uservariables['Variable name'] == 0 and otherdevices['Fridge Conact'] == 'Open' and timedifference(otherdevices_lastupdate['Fidge Contact']) > 30) then
commandArray['Variable:Variable name'] = '1'
elseif (uservariables['Variable name'] == 1 and otherdevices['Fridge Conact'] == 'Closed' then
commandArray['Variable:Variable name'] = '0'
lukcinek
Thx a lot for help
I changed All to Device and now everythong works!:)
I will also try Your script some time later and write if works.
EDIT:
It works like a charm:)
There was one bracket missing in Your code (in this line - elseif (uservariables['fridge'] == 1 and otherdevices['Drzwi - Lodówka']) == 'Closed' then - but it works! Thank You very much!
Best regards
EDIT:
Best regards
ensingg
Please post your script. I need a similar option. I have a magnetic switch on a gate. I like a notification when the gate if open for more than 30 sec without closing.
I do have a device script that triggers when the gate opens. But where should I put the timer?
When I change the event to a ALL or TIME it will fire up every minute, but the devicechanged command gives a NIL.
And furthermore the interval should be less that the 1 minute for the TIME scripts.
