Hardware pron pics
Derik
Re: Hardware pron pics
Post by Derik »
Nice Nice....
andriej
Post by andriej »
That's my Raspberry with Arduino as a (double) RF receiver/transmitter and mesh-network manager.
Both separately connected to the LAN.]
Gate#1
Gate#1
Gate#2
Gate#2
Orange Pi (@ Debian) / MySensors Serial / GPIO / Custom Serial 433 MHz Transmitter (for plug switches and livolo wall switches) / JSON&Bash API scripts
Raspberry Piet
Post by Raspberry Piet »
andriej wrote:That's my Raspberry with Arduino as a (double) RF receiver/transmitter and mesh-network manager.
Really like these hardware_home_made_pron_pics! :D
I'm looking forward for your how to!
I think an arduino gateway will be a valuable addition for Domoticz.
Derik
Post by Derik »
Please a how to.... :D :D
And what are the extra's ???
domusr
Post by domusr »
I think that's what I'm trying to do. What is your mesh network made of? Other Arduino's?
andriej
Post by andriej »
Other arduinos and 2.4GHz protocol.
@Derik - how to, I guess, is impossible as it has taken me around 2 years of trying everything I've found on internet.
I'd like to move for other solution tho. Like this: https://github.com/mysensors/Arduino
But it's not supported by Domoticz :-(
Derik
Post by Derik »
I maen, pleace place a how to in the wiki of Domoticz.
elythomaslumber
Domoticz version: 2023.1
Post by elythomaslumber »
Today I retired my iPad 1. Future use is only working as a Domoticz wall panel.
I've a lot of devices, weather reports and web-radio control buttons.
A 15W power plug is in the storage behind the right door. I made 15mm drill-hole behind the wall-mount.
A 1.5m cable leads to the power plug.
Wall mount for iPad1 from Loxone
Foto 2.JPG (105.14 KiB) Viewed 14151 times
Foto 5-2.jpg (93.78 KiB) Viewed 14151 times
Derik
Post by Derik »
Great feature,,,,, ;)
Allways the tab on?
And a web-radio control how do you make that? :mrgreen:
elythomaslumber
I've a "black-box" web-radio from ELV http://www.elv.de/elv-fs20-internet-rad ... usatz.html .
It can be operated via URL requests. So no problem with changing stations, volume, mute,...from Domoticz.
Meanwhile I found MPD ("Music Play Daemon") which is pure SW and can be used as a Web-radio server for streaming. Audio-out via HDMI, analogue or http
Unfortunately it does not work with Domoticz on the same Raspberry Pi when using the analogue-audio out. Has something to do with the ALSA driver.
The iPad is always on but the screen will shut-off after some minutes.
Gusimelo
Post by Gusimelo »
Today I hanged a 21,5'' android display to the wall to use with domoticz and emoncms energy monitoring
The display is quite big so I can use a split screen to have the current energy dial and the several temperature sensor values always visible.
fotografia 3.JPG (298.64 KiB) Viewed 14126 times
fotografia 2.JPG (266.93 KiB) Viewed 14126 times
fotografia 3.JPG (197.23 KiB) Viewed 14126 times
Mince Inside
Post by Mince Inside »
@Gusimelo do you have any more info to share on that screen? Is the OS embedded? Is it touch?
Will look 100% when you hide that power cable ;)
Domoticz V2.2259
Raspberry Pi (B) with PiFace
RFXtrx433 USB
LighwaveRF relays, dimmer bulbs and light switches
Siemens On/Off 13A adaptors
Marmitek MS13E Motion (and Dusk) sensors
Gusimelo
Post by Gusimelo »
it's an idisplay:
http://outform.com/idisplay/tablets/21-5-inch/
Mine is an older model, the new ones should be much better
It's basically an oversized android tablet
I have a smaller which has a stand:
fotografia 2.JPG (135.07 KiB) Viewed 14124 times
fotografia 1.JPG (122.98 KiB) Viewed 14124 times
Derik
Post by Derik »
@Gusimelo
Realy nice... :mrgreen: :D :o :o :shock: :roll:
Are you a miljonair..... :oops: :oops:
Gusimelo
Post by Gusimelo »
Derik wrote:@Gusimelo
ahahahah!... No!... I'm lucky, I guess! These are older tablets that I got... for free :)
My brother works in the interactive media industry and had these displays lying around... I kinda borrowed them indefinitely... they are now obsolete for his work, but are perfect for this :)
He also borrowed me a microsoft kinect and I'm looking for a way to somehow integrate it with domoticz... it would be nice to control lights and stuff just by pointing at them or something :)
Gustavo Melo
CopyCatz
Developer
Post by CopyCatz »
My latest project: a rain sensor from http://www.rainsensors.com/
I fitted a Fibaro universal sensor inside (fits easily) and attached a waterproof temperature sensor as well. It's an optical sensor (works the same ways as automatic wipers in a car) so I know it's raining the very instant a raindrop touches the dome 8-)
I got the inspiration from here: http://www.openremote.org/display/docs/ ... sal+Sensor
MaffeMuis
Domoticz version: 3.9483
Post by MaffeMuis »
My stuff at home. Just starting with domotica. I'm a computernerd, so it's a nice hobby project!
Raspberry Servertjes connected to the Ziggo modem on the USB port
Samsung Tablet on the Wall
Bussy to make a better compleet custom made panel to oversee everyhing. Later on its for the tablet.
Ik ben en blijf een brabander!
|Node-Red|Mqtt|ESPboards|tasmota|NAS|
Derik
Post by Derik »
@ Maffe Muis
Hit F11 for fullscreen..
Like to see your selfmade screen in the future...
When i have my tablet wallmounted... :( ;)
And yor GPS tracker working in Domoticz???
willie-p
Post by willie-p »
My hardware setup :-)
server or wine ;-)
server or wine ;-)
Electric
Electric
Gasmeter
Gasmeter
Derik
Post by Derik »
Looks nice ...
Hopefully you do not get the SmartMeter in your house ...
Expensive hardware ...
Everything was possible with the solarmeter.
Upload to PVO, which dates back get in Domoticz.
Or a counter S0
