Hardware pron pics
Derik
- Domoticz version: BETA
Re: Hardware pron pics
Nice Nice....
andriej
That's my Raspberry with Arduino as a (double) RF receiver/transmitter and mesh-network manager.
Both separately connected to the LAN.]
Orange Pi (@ Debian) / MySensors Serial / GPIO / Custom Serial 433 MHz Transmitter (for plug switches and livolo wall switches) / JSON&Bash API scripts
Raspberry Piet
Really like these hardware_home_made_pron_pics!andriej wrote:That's my Raspberry with Arduino as a (double) RF receiver/transmitter and mesh-network manager.
I'm looking forward for your how to!
I think an arduino gateway will be a valuable addition for Domoticz.
Derik
Please a how to....
And what are the extra's ???
domusr
I think that's what I'm trying to do. What is your mesh network made of? Other Arduino's?andriej wrote:That's my Raspberry with Arduino as a (double) RF receiver/transmitter and mesh-network manager.
andriej
Other arduinos and 2.4GHz protocol.
@Derik - how to, I guess, is impossible as it has taken me around 2 years of trying everything I've found on internet.
I'd like to move for other solution tho. Like this: https://github.com/mysensors/Arduino
But it's not supported by Domoticz
Derik
I maen, pleace place a how to in the wiki of Domoticz.
- elythomaslumber
- Domoticz version: 2023.1
Today I retired my iPad 1. Future use is only working as a Domoticz wall panel.
I've a lot of devices, weather reports and web-radio control buttons.
A 15W power plug is in the storage behind the right door. I made 15mm drill-hole behind the wall-mount.
A 1.5m cable leads to the power plug.
Derik
Great feature,,,,,
Allways the tab on?
And a web-radio control how do you make that?
Allways the tab on?
- elythomaslumber
I've a "black-box" web-radio from ELV http://www.elv.de/elv-fs20-internet-rad ... usatz.html .
It can be operated via URL requests. So no problem with changing stations, volume, mute,...from Domoticz.
Meanwhile I found MPD ("Music Play Daemon") which is pure SW and can be used as a Web-radio server for streaming. Audio-out via HDMI, analogue or http
Unfortunately it does not work with Domoticz on the same Raspberry Pi when using the analogue-audio out. Has something to do with the ALSA driver.
The iPad is always on but the screen will shut-off after some minutes.
Gusimelo
Today I hanged a 21,5'' android display to the wall to use with domoticz and emoncms energy monitoring
The display is quite big so I can use a split screen to have the current energy dial and the several temperature sensor values always visible.
- Mince Inside
@Gusimelo do you have any more info to share on that screen? Is the OS embedded? Is it touch?
Will look 100% when you hide that power cable
Domoticz V2.2259
Raspberry Pi (B) with PiFace
RFXtrx433 USB
LighwaveRF relays, dimmer bulbs and light switches
Siemens On/Off 13A adaptors
Marmitek MS13E Motion (and Dusk) sensors
RFXtrx433 USB
Gusimelo
it's an idisplay:
http://outform.com/idisplay/tablets/21-5-inch/
Mine is an older model, the new ones should be much better
It's basically an oversized android tablet
I have a smaller which has a stand:
Derik
@Gusimelo
Realy nice...
Are you a miljonair.....
Realy nice...
Gusimelo
Derik wrote:@Gusimelo
Realy nice...![]()
Are you a miljonair.....![]()
ahahahah!... No!... I'm lucky, I guess! These are older tablets that I got... for free
My brother works in the interactive media industry and had these displays lying around... I kinda borrowed them indefinitely... they are now obsolete for his work, but are perfect for this
He also borrowed me a microsoft kinect and I'm looking for a way to somehow integrate it with domoticz... it would be nice to control lights and stuff just by pointing at them or something
Gustavo Melo
- CopyCatz
- Developer
- Target OS: -
My latest project: a rain sensor from http://www.rainsensors.com/
I fitted a Fibaro universal sensor inside (fits easily) and attached a waterproof temperature sensor as well. It's an optical sensor (works the same ways as automatic wipers in a car) so I know it's raining the very instant a raindrop touches the dome
I got the inspiration from here: http://www.openremote.org/display/docs/ ... sal+Sensor
- MaffeMuis
- Domoticz version: 3.9483
My stuff at home. Just starting with domotica. I'm a computernerd, so it's a nice hobby project!
Ik ben en blijf een brabander!
|Node-Red|Mqtt|ESPboards|tasmota|NAS|
Derik
@ Maffe Muis
Hit F11 for fullscreen..
Like to see your selfmade screen in the future...
When i have my tablet wallmounted...
And yor GPS tracker working in Domoticz???
willie-p
My hardware setup
- server or wine ;-)
- IMG_3621a.jpg (164.44 KiB) Viewed 13249 times
- Electric
- IMG_3619a.jpg (148.06 KiB) Viewed 13249 times
- Gasmeter
- IMG_3617a.jpg (106.67 KiB) Viewed 13249 times
Derik
Looks nice ...
Hopefully you do not get the SmartMeter in your house ...
Expensive hardware ...
Everything was possible with the solarmeter.
Upload to PVO, which dates back get in Domoticz.
Or a counter S0
Or a counter S0
