I'm guessing I won't be able to use any of the other 416-packages?
DS416j addedtjofras wrote:This looks great and I want to try it, but I can't find my ds416j under any of the versions?
domoticz folder is located in /usr/local/domoticz on synologydannyf wrote:Hello,
Just new here so I don't know this is the right topic.
I've installed a Jadahl package on my Synology DS213, but I can't find the installation files for adding some scripts. It should be at volume1\homes\danny. But I can't enter that folder with SSH. Other folders no problem.
Any ideas?
thx, Danny
Haha wow I'm impressed!! Thanks a lot!jumbotroll wrote:DS416j addedtjofras wrote:This looks great and I want to try it, but I can't find my ds416j under any of the versions?
http://www.jadahl.com/domoticz_beta_6/?arch=armada38x
Agreed, but meanwhile my alarmsystem remains offlinejumbotroll wrote:@dobber
Older beta versions is deleted from my server, only latest beta version is available.
If this is a bug in newer versions of domoticz, is it not better to report this as a bug and get it corrected?
Omg, you are awesome!jumbotroll wrote:@dobber
I can always build an older version for you until the bug is fixed
What version do you want v.3.6500? with or without python plugin?
DSM6.0 or DSM6.1?
Noticed that when I was switching from 6730 with python to 6708 without pythonjumbotroll wrote:@dobber
Okgive me 10 min and I will give you a link for domoticz v.3.6500 arch-braswell for DSM 6.0.2.
Remember you can not downgrade domoticz, so you have to take backup of domoticz.db and uninstall the domoticz package from package center.
Great!dobber wrote:@jumbotroll
The alarm system works again. Thank you!
runcommandYeelight ="echo -ne '{"id":1, "method":"set_hsv", "params":[273, 65, "smooth", 2000]}\r\n' | nc -w1 192.168.2.81 55443"
os.execute(runcommandYeelight)
Is it safe to update?Due to infrastructure update, packages will need re-initialization after upgrading to DSM 6.1. The process will occupy a higher CPU usage and can take up to an hour depending on the number of packages installed.
I have not tested (still on 6.02 here) 2 antother users tested with success.Egregius wrote:Synology released DSM 6.1 build 15047
One of the release notes is:Is it safe to update?Due to infrastructure update, packages will need re-initialization after upgrading to DSM 6.1. The process will occupy a higher CPU usage and can take up to an hour depending on the number of packages installed.
