domoticz in synology as package! Available now.
tjofras
Post by tjofras »
This looks great and I want to try it, but I can't find my ds416j under any of the versions? :(
I'm guessing I won't be able to use any of the other 416-packages?
jumbotroll
Post by jumbotroll »
tjofras wrote:This looks great and I want to try it, but I can't find my ds416j under any of the versions? :(
DS416j added :-)
http://www.jadahl.com/domoticz_beta_6/?arch=armada38x
https://paypal.me/Jumbotroll
Jumbotroll
dannyf
Post by dannyf »
Just new here so I don't know this is the right topic.
I've installed a Jadahl package on my Synology DS213, but I can't find the installation files for adding some scripts. It should be at volume1\homes\danny. But I can't enter that folder with SSH. Other folders no problem.
Any ideas?
thx, Danny
jumbotroll
dannyf wrote:Hello,
Any ideas?
thx, Danny
domoticz folder is located in /usr/local/domoticz on synology
Jumbotroll
tjofras
Post by tjofras »
DS416j added :-)
Haha wow I'm impressed!! Thanks a lot!
dobber
Domoticz version: Beta..
Post by dobber »
I'm looking for a version of domoticz from mid or late jan 2017. There is a bug in the February updates that makes my Zipato keypad not work as intended.
I tried outsmarting your website by just changing the version: http://www.jadahl.com/domoticz_beta_6/p ... 6500-7.spk
But the site is smarter than I am, obviously.
I'm on a DS916+ (Braswell)
jumbotroll
@dobber
Older beta versions is deleted from my server, only latest beta version is available.
If this is a bug in newer versions of domoticz, is it not better to report this as a bug and get it corrected?
Jumbotroll
dobber
Post by dobber »
jumbotroll wrote:@dobber
Agreed, but meanwhile my alarmsystem remains offline :(
The problem has already been reported here: viewtopic.php?f=6&t=16164&p=120154#p120154
jumbotroll
@dobber
I can always build an older version for you until the bug is fixed :-)
What version do you want v.3.6500? with or without python plugin?
DSM6.0 or DSM6.1?
Jumbotroll
dobber
Post by dobber »
DSM6.0 or DSM6.1?
Omg, you are awesome!
6500 without python plugin plz.
DSM 6.0.2-8451 Update 9
In the future I'll make sure to make a backup of the install file once a month or so :)
jumbotroll
@dobber
Ok :-) give me 10 min and I will give you a link for domoticz v.3.6500 arch-braswell for DSM 6.0.2.
Remember you can not downgrade domoticz, so you have to take backup of domoticz.db and uninstall the domoticz package from package center.
Jumbotroll
dobber
Post by dobber »
Noticed that when I was switching from 6730 with python to 6708 without python :)
Thanks for the support. That's what makes this community so great!
jumbotroll
@dobber
Here you go :-)
domoticz_braswell-6.0_3.0.6500-7.spk
http://www.jadahl.com/synospk/
Jumbotroll
dobber
Post by dobber »
@jumbotroll
The alarm system works again. Thank you!
jumbotroll
dobber wrote:@jumbotroll
Great!
Let us hope the developers fix this bug and you can update to the latest version :-)
Jumbotroll
bertbigb
Post by bertbigb »
I do not know if this is the right spot to ask this question, if not please let me know.
I have a Synology DS1515, running Domoticz (latest beta) V3.6708. To the domoticz I have a few Yeelights connected and to controle these lights I have to send a command like echo -ne '{"id":1, "method":"set_hsv", "params":[273, 65, "smooth", 2000]}\r\n' | nc -w1 192.168.2.81 55443
when I do this from the command prompt (ssh to the DS1515) then it works.
But when I send the command from a lua script like:
runcommandYeelight ="echo -ne '{"id":1, "method":"set_hsv", "params":[273, 65, "smooth", 2000]}\r\n' | nc -w1 192.168.2.81 55443"
os.execute(runcommandYeelight)
Then nothing happens, however if i send the same command from a raspberry PPi the bulb reacts as expected
Can anyone help me to point out what I could do to make this work for Domoticz on my Synology?
Many thanks
Best regards Bert
Synology DS1517+ - DSM 6.2
Egregius
Domoticz version: v2024.7
Post by Egregius »
Synology released DSM 6.1 build 15047
One of the release notes is:
Due to infrastructure update, packages will need re-initialization after upgrading to DSM 6.1. The process will occupy a higher CPU usage and can take up to an hour depending on the number of packages installed.
Is it safe to update?
jumbotroll
Egregius wrote:Synology released DSM 6.1 build 15047
I have not tested (still on 6.02 here) 2 antother users tested with success.
But I have build domoticz for DSM 6.1 because some models got new kernel and need updated usb drivers.
http://www.jadahl.com/domoticz_beta_6.1/
Jumbotroll
Egregius
Post by Egregius »
OK, will update today and report back if it still works with stable 5877 version ;)
Thank you.
Egregius
Post by Egregius »
No problem here, stable 5877 direct online on my Syno 1513+ :)
