Domoticz controlled lock on sliding door possible ?
I would like to be able to lock / unlock my sliding door using domoticz without modifications to the door on the outside.
Does anyone on this forum can give me a hint where to start ?
emme
Domoticz version: latest
Re: Domoticz controlled lock on sliding door possible ?
Post by emme »
unless you're able to install an automatic doorlock (Zwave or other kind) I don't think you will be able to...
http://www.zwaveproducts.com/shop/z-wav ... door-locks
"We always done this way"
RayAmsterdam
Post by RayAmsterdam »
Looks like the door has an euro cylinder. Have a look at Nuki.
NStafford
Post by NStafford »
emme wrote:unless you're able to install an automatic doorlock (Zwave or other kind) I don't think you will be able to...
I agree with Emme on this one. I am not aware of any method you can use to achieve what you want out of the lock without making any modifications to the lock/door on the outside. I would strongly suggest upgrading it to a deadbolt lock which will then give you more options in terms of auto locks and smart locks which you can then modify to control using domoticz
markjgabb
Domoticz version: 3.8153
Post by markjgabb »
the only thing at all i can think of would be to install a seperate lock beside it, inside....use a mag lock contact
that would still modify the door, but it would leave the normal door and lock intact if you needed to use it
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
Thx for the suggestions and tips. If I find a working solution for my situation I will post it here
