do you know the sid of your gateway? if it doesn't start with "f0b4" that could be the cause.pikapt wrote:Hi corbin,
So I'm back with good and bad news. Good news is that zigbee switch is working, bad news is that gateway switch still doesn't.
Any idea on how to make some debug over it? Is it working for everyone else?
Cheers
- corbin
pikapt
cool, we're getting somewhere!
2017-01-26 00:42:15.357 {"cmd":"report","model":"gateway","sid":"286c0785ad14","short_id":0,"data":"{\"rgb\":1236926719}"}
2017-01-26 00:42:23.330 {"cmd":"report","model":"gateway","sid":"286c0785ad14","short_id":0,"data":"{\"rgb\":0}"}
just got this from the logfile, sid starts with 286c
- corbin
I've just updated github, should work for you now.
pikapt
thanks a lot mate! i'll give it a test tomorrow and will let you know! cheers!
Coldman
Great job, zigbee sockets are working and reaction speed is much faster than in the native app!corbin wrote:I've just updated github, should work for you now.
Thanks.
- galadril
- Domoticz version: latest
Got the next exception after the latest update:
17:57:30.973 Error: MiHome hardware (13) thread seems to have ended unexpectedly
levynger
i will check later on today on my ubuntu and update..corbin wrote:Can you check my latest github update hasn't broken the new switch commands you added?levynger wrote:@corbin, @deennoo found a problem for the ctrl_neutral1 - it wont be triggered as the message is hardcoded for ctrl_neural2 only..
I'm not sure how best to solve the ctrl_neutral/1ctrl_neutral2 problem. I faced something similar with the gateway colour and brightness, where I didn't want to query the database each time for the values needed - ended up using local variables. This approach for the switches would need to store the switch type/name for each switch, and would need an array or similar.
regardin the ctrl# device, though perhaps to add to the ID of the device something like hex identification for "ctrl2" and "ctrl1"
before sending command from the UI and before comaring it in the Reciever proc , remove it.. this way i can determine which ctrl and assign the correct command to it, and avoiding extra sql queries on each command transmitted.. sounds ok? or i am missing something?
levynger
@corbin,
updated git, unable to compile..
23%] Building CXX object CMakeFiles/domoticz.dir/main/mainworker.cpp.o
/home/levynger/domoticzgit/main/mainworker.cpp: In member function ‘void MainWorker::decode_LimitlessLights(int, _eHardwareTypes, const tRBUF*, MainWorker::_tRxMessageProcessingResult&)’:
/home/levynger/domoticzgit/main/mainworker.cpp:5492:98: error: ‘to_string’ is not a member of ‘std’
uint64_t DevRowIdx = m_sql.UpdateValue(HwdID, ID.c_str(), Unit, devType, subType, 12, -1, cmnd, std::to_string(value).c_str(), procResult.DeviceN
/home/levynger/domoticzgit/main/mainworker.cpp:5492:98: note: suggested alternatives:
In file included from /usr/include/boost/exception_ptr.hpp:9:0,
from /usr/include/boost/thread/exceptional_ptr.hpp:10,
from /usr/include/boost/thread/future.hpp:23,
from /usr/include/boost/thread.hpp:24,
from /home/levynger/domoticzgit/main/stdafx.h:57:
/usr/include/boost/exception/detail/exception_ptr.hpp:492:5: note: ‘boost::to_string’
to_string( exception_ptr const & p )
In file included from /usr/include/boost/exception/to_string_stub.hpp:15:0,
from /usr/include/boost/exception/info.hpp:16,
from /usr/include/boost/exception/detail/exception_ptr.hpp:20,
from /usr/include/boost/exception_ptr.hpp:9,
/usr/include/boost/exception/to_string.hpp:72:5: note: ‘boost::to_string’
to_string( std::pair<T,U> const & x )
CMakeFiles/domoticz.dir/build.make:254: recipe for target 'CMakeFiles/domoticz.dir/main/mainworker.cpp.o' failed
make[2]: *** [CMakeFiles/domoticz.dir/main/mainworker.cpp.o] Error 1
CMakeFiles/Makefile2:103: recipe for target 'CMakeFiles/domoticz.dir/all' failed
make[1]: *** [CMakeFiles/domoticz.dir/all] Error 2
Makefile:149: recipe for target 'all' failed
make: *** [all] Error 2
deennoo
same for melevynger wrote:@corbin,
23%] Building CXX object CMakeFiles/domoticz.dir/main/mainworker.cpp.o /home/levynger/domoticzgit/main/mainworker.cpp: In member function ‘void MainWorker::decode_LimitlessLights(int, _eHardwareTypes, const tRBUF*, MainWorker::_tRxMessageProcessingResult&)’: /home/levynger/domoticzgit/main/mainworker.cpp:5492:98: error: ‘to_string’ is not a member of ‘std’ uint64_t DevRowIdx = m_sql.UpdateValue(HwdID, ID.c_str(), Unit, devType, subType, 12, -1, cmnd, std::to_string(value).c_str(), procResult.DeviceN ^ /home/levynger/domoticzgit/main/mainworker.cpp:5492:98: note: suggested alternatives: In file included from /usr/include/boost/exception_ptr.hpp:9:0, from /usr/include/boost/thread/exceptional_ptr.hpp:10, from /usr/include/boost/thread/future.hpp:23, from /usr/include/boost/thread.hpp:24, from /home/levynger/domoticzgit/main/stdafx.h:57: /usr/include/boost/exception/detail/exception_ptr.hpp:492:5: note: ‘boost::to_string’ to_string( exception_ptr const & p ) ^ In file included from /usr/include/boost/exception/to_string_stub.hpp:15:0, from /usr/include/boost/exception/info.hpp:16, from /usr/include/boost/exception/detail/exception_ptr.hpp:20, from /usr/include/boost/exception_ptr.hpp:9, from /usr/include/boost/thread/exceptional_ptr.hpp:10, from /usr/include/boost/thread/future.hpp:23, from /usr/include/boost/thread.hpp:24, from /home/levynger/domoticzgit/main/stdafx.h:57: /usr/include/boost/exception/to_string.hpp:72:5: note: ‘boost::to_string’ to_string( std::pair<T,U> const & x ) ^ CMakeFiles/domoticz.dir/build.make:254: recipe for target 'CMakeFiles/domoticz.dir/main/mainworker.cpp.o' failed make[2]: *** [CMakeFiles/domoticz.dir/main/mainworker.cpp.o] Error 1 CMakeFiles/Makefile2:103: recipe for target 'CMakeFiles/domoticz.dir/all' failed make[1]: *** [CMakeFiles/domoticz.dir/all] Error 2 Makefile:149: recipe for target 'all' failed make: *** [all] Error 2
http://domo-attitude.fr
- corbin
I've undone my change so should compile again. I'll try to get it going in Linux later.
pikapt
@corbin quick update, i'm now able to control gateway led as expected! thanks a lot mate!!
levynger
Works fine! thanks.corbin wrote:I've undone my change so should compile again. I'll try to get it going in Linux later.
Dual switch also seems to be fine..
Hi. Can't get Xiaomi gateway working on Xiaomi router 3
The same thing on Windows 10 64-bit.
log stops on
and nothing happened when
http://ge.tt/4hmk8Xi2
On Raspberry Pi all working fine.
Do i need do some firewall setting on window or router?
How can i debug it?
root@XiaoQiang:~# /data/opt/domoticz/domoticz
2017-01-27 08:28:29.489 Domoticz V3.5876 (c)2012-2016 GizMoCuz
2017-01-27 08:28:29.489 Build Hash: b97777b, Date: 2016-11-09 13:33:42
2017-01-27 08:28:29.490 Startup Path: /data/opt/domoticz/
2017-01-27 08:28:29.795 Active notification Subsystems: http (1/12)
2017-01-27 08:28:29.802 WebServer(HTTP) started on address: :: with port 8080
2017-01-27 08:28:29.828 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: use_certificate_chain_file: asio.ssl error
2017-01-27 08:28:29.828 Error: WebServer(SSL) check privileges for opening ports below 1024
2017-01-27 08:28:29.830 Proxymanager started.
2017-01-27 08:28:29.844 Starting shared server on: :::6144
2017-01-27 08:28:29.846 TCPServer: shared server started...
2017-01-27 08:28:29.847 RxQueue: queue worker started...
2017-01-27 08:28:31.886 EventSystem: reset all events...
2017-01-27 08:28:31.889 EventSystem: reset all device statuses...
2017-01-27 08:28:31.891 EventSystem: Started
2017-01-27 08:28:31.892 XiaomiGateway: Worker started...
tcp 0 0 127.0.0.1:9898 0.0.0.0:* LISTEN 0 52 18163/rule_mgr
udp 0 0 0.0.0.0:9898 0.0.0.0:* 0 43 19727/domoticzlog stops on
XiaomiGateway: Worker started...On Raspberry Pi all working fine.
How can i debug it?
pi@raspberrypi:~/domoticz $ ./domoticz
2017-01-27 06:47:17.384 Domoticz V3.6395 (c)2012-2017 GizMoCuz
2017-01-27 06:47:17.387 Build Hash: b0d58fc, Date: 2017-01-20 14:52:28
2017-01-27 06:47:17.394 System: Raspberry Pi
2017-01-27 06:47:17.398 Startup Path: /home/pi/domoticz/
2017-01-27 06:47:17.680 PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platfo rm.
2017-01-27 06:47:17.734 Active notification Subsystems: http (1/12)
2017-01-27 06:47:17.782 WebServer(HTTP) started on address: :: with port 8080
2017-01-27 06:47:17.875 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
2017-01-27 06:47:17.877 Error: WebServer(SSL) check privileges for opening ports below 1024
2017-01-27 06:47:17.882 Proxymanager started.
2017-01-27 06:47:17.896 Starting shared server on: :::6144
2017-01-27 06:47:17.909 TCPServer: shared server started...
2017-01-27 06:47:17.911 RxQueue: queue worker started...
2017-01-27 06:47:19.916 EventSystem: reset all events...
2017-01-27 06:47:19.923 XiaomiGateway: Worker started...
2017-01-27 06:47:19.929 EventSystem: reset all device statuses...
2017-01-27 06:47:19.945 EventSystem: Started
2017-01-27 06:47:20.551 XiaomiGateway: Temperature - nodeid: 158d000116a89d
2017-01-27 06:47:20.566 {"cmd":"read_ack","model":"sensor_ht","sid":"158d000116a89d","short_id":32014,"data":"{\"temperature\":\"2223\",\"hu midity\":\"3140\"}"}
2017-01-27 06:47:20.559 (mi) Temp (Xiaomi Temperature)
2017-01-27 06:47:20.597 (mi) Light/Switch (Xiaomi Wireless Switch)
2017-01-27 06:47:20.617 {"cmd":"read_ack","model":"switch","sid":"158d00010a88c3","short_id":17332,"data":"{}"}
2017-01-27 06:47:20.624 (mi) Light/Switch (Xiaomi Motion Sensor)
2017-01-27 06:47:20.643 {"cmd":"read_ack","model":"motion","sid":"158d0000fd3061","short_id":44775,"data":"{\"status\":\"no_motion\"}"}
2017-01-27 06:47:20.650 (mi) Light/Switch (Xiaomi Door Sensor)
2017-01-27 06:47:20.669 {"cmd":"read_ack","model":"magnet","sid":"158d00012afd6c","short_id":47575,"data":"{\"status\":\"open\"}"}
2017-01-27 06:47:20.676 (mi) Light/Switch (Xiaomi Smart Plug)
2017-01-27 06:47:20.694 {"cmd":"read_ack","model":"plug","sid":"158d00013fc03f","short_id":10117,"data":"{\"status\":\"on\",\"inuse\":\"1\"} "}
2017-01-27 06:47:20.701 (mi) Light/Switch (Xiaomi Cube)
2017-01-27 06:47:20.719 {"cmd":"read_ack","model":"cube","sid":"158d000110637d","short_id":26883,"data":"{}"}
pi@raspberrypi:~ $ netstat -tulpn | grep :9898
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
udp 0 0 0.0.0.0:9898 0.0.0.0:* 989/domoticz
- corbin
I had Hyper-V enabled on my Windows machine, which was breaking Yeelights and Xiaomi Gateway. Maybe you have something installed that modifies your network adapter?
pavelbor
- Domoticz version: LastBeta
Domoticz beta version: 3.6500. Still can not control power sockets
Log also does not show "full" Gateway messages. When it will be fixed?
- corbin
if you want it working right now, use https://github.com/corbinmunce/domoticz
I'll do a new pull request in the next couple of days, just doing some more testing currently as I don't want to break the main repository code again.
- corbin
I don't think this will work as the id is passed in externally in the WriteToHardware function.levynger wrote: i will check later on today on my ubuntu and update..
levynger
I though removing it before sending to HW again..corbin wrote:I don't think this will work as the id is passed in externally in the WriteToHardware function.levynger wrote: i will check later on today on my ubuntu and update..
i eventually added array as you suggested to store all IDs belong to the ctrl2 (for multiple ctrl2 devices as home), and added an optional paremeter to InsertUpdateSwitch to identify the ctrl2 device from the UDP reciever.
also tried now to change its type to On/Off, and it it twice with Unit field.. however seems that domoticz wont allow to use same ID for the same Type..
the same one is being updated..
so i guess will remain with Selector for the Aqara..
work in progress.. takes time.. at least to my c++ skills..
UPDATE: found how to make 2 on/off type for the same HW.. had to change the xcmd.unitnumber before providing it to mainworker!
i have got this
trying to run Domoricz Xiaomi Gateway on Xiaomi router 3.
how can i debug?
add
when i start domoticz on router
output on router
when i start domoticz on raspberry pi (ip 192.168.1.190)
output on router
017-01-27 15:21:50.541 XiaomiGateway: Worker started...
2017-01-27 15:21:50.544 start_receive
2017-01-27 15:22:51.143 sec_counter 60
2017-01-27 15:23:51.743 sec_counter 120
2017-01-27 15:30:55.943 sec_counter 540
2017-01-27 15:31:56.543 sec_counter 600
how can i debug?
add
output on router
root@XiaoQiang:~# tcpdump -n -i br-lan | grep '9898'
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on br-lan, link-type EN10MB (Ethernet), capture size 65535 bytes
16:50:45.909007 IP 192.168.1.11.4321 > 224.0.0.50.9898: UDP, length 135
16:50:55.881381 IP 192.168.1.11.4321 > 224.0.0.50.9898: UDP, length 135
16:51:05.853986 IP 192.168.1.11.4321 > 224.0.0.50.9898: UDP, length 135
output on router
16:50:52.122336 IP 192.168.1.190.9898 > 224.0.0.50.4321: UDP, length 15
deennoo
Guys ! Corbin and you are the mens of Xiaomi In Domoticz Dev !levynger wrote: UPDATE: found how to make 2 on/off type for the same HW.. had to change the xcmd.unitnumber before providing it to mainworker!Capture.PNG
got a small teaser for you :
http://domo-attitude.fr/cube-xiaomi-teaser/
Xiaomi Cube + Yeelight : Rotative dimmer !
