corbin
Post by corbin »
pikapt wrote:Hi corbin,
So I'm back with good and bad news. Good news is that zigbee switch is working, bad news is that gateway switch still doesn't.
Any idea on how to make some debug over it? Is it working for everyone else?
Cheers
do you know the sid of your gateway? if it doesn't start with "f0b4" that could be the cause.
pikapt
Post by pikapt »
cool, we're getting somewhere!
2017-01-26 00:42:15.357 {"cmd":"report","model":"gateway","sid":"286c0785ad14","short_id":0,"data":"{\"rgb\":1236926719}"}
2017-01-26 00:42:23.330 {"cmd":"report","model":"gateway","sid":"286c0785ad14","short_id":0,"data":"{\"rgb\":0}"}
just got this from the logfile, sid starts with 286c
corbin
Post by corbin »
I've just updated github, should work for you now.
pikapt
Post by pikapt »
thanks a lot mate! i'll give it a test tomorrow and will let you know! cheers!
Coldman
Post by Coldman »
corbin wrote:I've just updated github, should work for you now.
Great job, zigbee sockets are working and reaction speed is much faster than in the native app!
Thanks.
galadril
Domoticz version: latest
Post by galadril »
Got the next exception after the latest update:
17:57:30.973 Error: MiHome hardware (13) thread seems to have ended unexpectedly
levynger
Post by levynger »
corbin wrote:
levynger wrote:@corbin, @deennoo found a problem for the ctrl_neutral1 - it wont be triggered as the message is hardcoded for ctrl_neural2 only..
Can you check my latest github update hasn't broken the new switch commands you added?
I'm not sure how best to solve the ctrl_neutral/1ctrl_neutral2 problem. I faced something similar with the gateway colour and brightness, where I didn't want to query the database each time for the values needed - ended up using local variables. This approach for the switches would need to store the switch type/name for each switch, and would need an array or similar.
i will check later on today on my ubuntu and update..
regardin the ctrl# device, though perhaps to add to the ID of the device something like hex identification for "ctrl2" and "ctrl1"
before sending command from the UI and before comaring it in the Reciever proc , remove it.. this way i can determine which ctrl and assign the correct command to it, and avoiding extra sql queries on each command transmitted.. sounds ok? or i am missing something?
levynger
Post by levynger »
@corbin,
updated git, unable to compile..
 23%] Building CXX object CMakeFiles/domoticz.dir/main/mainworker.cpp.o
/home/levynger/domoticzgit/main/mainworker.cpp: In member function ‘void MainWorker::decode_LimitlessLights(int, _eHardwareTypes, const tRBUF*, MainWorker::_tRxMessageProcessingResult&)’:
/home/levynger/domoticzgit/main/mainworker.cpp:5492:98: error: ‘to_string’ is not a member of ‘std’
  uint64_t DevRowIdx = m_sql.UpdateValue(HwdID, ID.c_str(), Unit, devType, subType, 12, -1, cmnd, std::to_string(value).c_str(), procResult.DeviceN
/home/levynger/domoticzgit/main/mainworker.cpp:5492:98: note: suggested alternatives:
In file included from /usr/include/boost/exception_ptr.hpp:9:0,
                 from /usr/include/boost/thread/exceptional_ptr.hpp:10,
                 from /usr/include/boost/thread/future.hpp:23,
                 from /usr/include/boost/thread.hpp:24,
                 from /home/levynger/domoticzgit/main/stdafx.h:57:
/usr/include/boost/exception/detail/exception_ptr.hpp:492:5: note:   ‘boost::to_string’
     to_string( exception_ptr const & p )
In file included from /usr/include/boost/exception/to_string_stub.hpp:15:0,
                 from /usr/include/boost/exception/info.hpp:16,
                 from /usr/include/boost/exception/detail/exception_ptr.hpp:20,
                 from /usr/include/boost/exception_ptr.hpp:9,
/usr/include/boost/exception/to_string.hpp:72:5: note:   ‘boost::to_string’
     to_string( std::pair<T,U> const & x )
CMakeFiles/domoticz.dir/build.make:254: recipe for target 'CMakeFiles/domoticz.dir/main/mainworker.cpp.o' failed
make[2]: *** [CMakeFiles/domoticz.dir/main/mainworker.cpp.o] Error 1
CMakeFiles/Makefile2:103: recipe for target 'CMakeFiles/domoticz.dir/all' failed
make[1]: *** [CMakeFiles/domoticz.dir/all] Error 2
Makefile:149: recipe for target 'all' failed
make: *** [all] Error 2
deennoo
Post by deennoo »
same for me
http://domo-attitude.fr
corbin
Post by corbin »
I've undone my change so should compile again. I'll try to get it going in Linux later.
pikapt
Post by pikapt »
@corbin quick update, i'm now able to control gateway led as expected! thanks a lot mate!!
levynger
Post by levynger »
corbin wrote:I've undone my change so should compile again. I'll try to get it going in Linux later.
Works fine! thanks.
Dual switch also seems to be fine..
derrij
Post by derrij »
Hi. Can't get Xiaomi gateway working on Xiaomi router 3
root@XiaoQiang:~# /data/opt/domoticz/domoticz
2017-01-27 08:28:29.489  Domoticz V3.5876 (c)2012-2016 GizMoCuz
2017-01-27 08:28:29.489  Build Hash: b97777b, Date: 2016-11-09 13:33:42
2017-01-27 08:28:29.490  Startup Path: /data/opt/domoticz/
2017-01-27 08:28:29.795  Active notification Subsystems: http (1/12)
2017-01-27 08:28:29.802  WebServer(HTTP) started on address: :: with port 8080
2017-01-27 08:28:29.828  Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: use_certificate_chain_file: asio.ssl error
2017-01-27 08:28:29.828  Error: WebServer(SSL) check privileges for opening ports below 1024
2017-01-27 08:28:29.830  Proxymanager started.
2017-01-27 08:28:29.844  Starting shared server on: :::6144
2017-01-27 08:28:29.846  TCPServer: shared server started...
2017-01-27 08:28:29.847  RxQueue: queue worker started...
2017-01-27 08:28:31.886  EventSystem: reset all events...
2017-01-27 08:28:31.889  EventSystem: reset all device statuses...
2017-01-27 08:28:31.891  EventSystem: Started
2017-01-27 08:28:31.892  XiaomiGateway: Worker started...
tcp        0      0 127.0.0.1:9898          0.0.0.0:*               LISTEN       0 52 18163/rule_mgr
udp        0      0 0.0.0.0:9898            0.0.0.0:*                            0 43 19727/domoticz
The same thing on Windows 10 64-bit.
log stops on
and nothing happened when
Imagehttp://ge.tt/4hmk8Xi2
On Raspberry Pi all working fine.
Do i need do some firewall setting on window or router?
How can i debug it?
pi@raspberrypi:~/domoticz $ ./domoticz
2017-01-27 06:47:17.384  Domoticz V3.6395 (c)2012-2017 GizMoCuz
2017-01-27 06:47:17.387  Build Hash: b0d58fc, Date: 2017-01-20 14:52:28
2017-01-27 06:47:17.394  System: Raspberry Pi
2017-01-27 06:47:17.398  Startup Path: /home/pi/domoticz/
2017-01-27 06:47:17.680  PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platfo                rm.
2017-01-27 06:47:17.734  Active notification Subsystems: http (1/12)
2017-01-27 06:47:17.782  WebServer(HTTP) started on address: :: with port 8080
2017-01-27 06:47:17.875  Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
2017-01-27 06:47:17.877  Error: WebServer(SSL) check privileges for opening ports below 1024
2017-01-27 06:47:17.882  Proxymanager started.
2017-01-27 06:47:17.896  Starting shared server on: :::6144
2017-01-27 06:47:17.909  TCPServer: shared server started...
2017-01-27 06:47:17.911  RxQueue: queue worker started...
2017-01-27 06:47:19.916  EventSystem: reset all events...
2017-01-27 06:47:19.923  XiaomiGateway: Worker started...
2017-01-27 06:47:19.929  EventSystem: reset all device statuses...
2017-01-27 06:47:19.945  EventSystem: Started
2017-01-27 06:47:20.551  XiaomiGateway: Temperature - nodeid: 158d000116a89d
2017-01-27 06:47:20.566  {"cmd":"read_ack","model":"sensor_ht","sid":"158d000116a89d","short_id":32014,"data":"{\"temperature\":\"2223\",\"hu                midity\":\"3140\"}"}
2017-01-27 06:47:20.559  (mi) Temp (Xiaomi Temperature)
2017-01-27 06:47:20.597  (mi) Light/Switch (Xiaomi Wireless Switch)
2017-01-27 06:47:20.617  {"cmd":"read_ack","model":"switch","sid":"158d00010a88c3","short_id":17332,"data":"{}"}
2017-01-27 06:47:20.624  (mi) Light/Switch (Xiaomi Motion Sensor)
2017-01-27 06:47:20.643  {"cmd":"read_ack","model":"motion","sid":"158d0000fd3061","short_id":44775,"data":"{\"status\":\"no_motion\"}"}
2017-01-27 06:47:20.650  (mi) Light/Switch (Xiaomi Door Sensor)
2017-01-27 06:47:20.669  {"cmd":"read_ack","model":"magnet","sid":"158d00012afd6c","short_id":47575,"data":"{\"status\":\"open\"}"}
2017-01-27 06:47:20.676  (mi) Light/Switch (Xiaomi Smart Plug)
2017-01-27 06:47:20.694  {"cmd":"read_ack","model":"plug","sid":"158d00013fc03f","short_id":10117,"data":"{\"status\":\"on\",\"inuse\":\"1\"}                "}
2017-01-27 06:47:20.701  (mi) Light/Switch (Xiaomi Cube)
2017-01-27 06:47:20.719  {"cmd":"read_ack","model":"cube","sid":"158d000110637d","short_id":26883,"data":"{}"}
pi@raspberrypi:~ $ netstat -tulpn | grep :9898
(Not all processes could be identified, non-owned process info
 will not be shown, you would have to be root to see it all.)
udp        0      0 0.0.0.0:9898            0.0.0.0:*                           989/domoticz
corbin
Post by corbin »
I had Hyper-V enabled on my Windows machine, which was breaking Yeelights and Xiaomi Gateway. Maybe you have something installed that modifies your network adapter?
pavelbor
Domoticz version: LastBeta
Post by pavelbor »
Domoticz beta version: 3.6500. Still can not control power sockets :(
Log also does not show "full" Gateway messages. When it will be fixed?
corbin
Post by corbin »
if you want it working right now, use https://github.com/corbinmunce/domoticz
I'll do a new pull request in the next couple of days, just doing some more testing currently as I don't want to break the main repository code again.
corbin
Post by corbin »
levynger wrote: i will check later on today on my ubuntu and update..
I don't think this will work as the id is passed in externally in the WriteToHardware function.
levynger
Post by levynger »
I though removing it before sending to HW again..
i eventually added array as you suggested to store all IDs belong to the ctrl2 (for multiple ctrl2 devices as home), and added an optional paremeter to InsertUpdateSwitch to identify the ctrl2 device from the UDP reciever.
also tried now to change its type to On/Off, and it it twice with Unit field.. however seems that domoticz wont allow to use same ID for the same Type..
the same one is being updated..
so i guess will remain with Selector for the Aqara..
work in progress.. takes time.. at least to my c++ skills.. :D
UPDATE: found how to make 2 on/off type for the same HW.. had to change the xcmd.unitnumber before providing it to mainworker!
derrij
Post by derrij »
i have got this
017-01-27 15:21:50.541  XiaomiGateway: Worker started...
2017-01-27 15:21:50.544  start_receive
2017-01-27 15:22:51.143  sec_counter 60
2017-01-27 15:23:51.743  sec_counter 120
2017-01-27 15:30:55.943  sec_counter 540
2017-01-27 15:31:56.543  sec_counter 600
trying to run Domoricz Xiaomi Gateway on Xiaomi router 3.
how can i debug?
add
when i start domoticz on router
output on router
root@XiaoQiang:~# tcpdump -n -i br-lan | grep '9898'
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on br-lan, link-type EN10MB (Ethernet), capture size 65535 bytes
16:50:45.909007 IP 192.168.1.11.4321 > 224.0.0.50.9898: UDP, length 135
16:50:55.881381 IP 192.168.1.11.4321 > 224.0.0.50.9898: UDP, length 135
16:51:05.853986 IP 192.168.1.11.4321 > 224.0.0.50.9898: UDP, length 135
when i start domoticz on raspberry pi (ip 192.168.1.190)
output on router
16:50:52.122336 IP 192.168.1.190.9898 > 224.0.0.50.4321: UDP, length 15
deennoo
Post by deennoo »
levynger wrote: UPDATE: found how to make 2 on/off type for the same HW.. had to change the xcmd.unitnumber before providing it to mainworker!Capture.PNG
Guys ! Corbin and you are the mens of Xiaomi In Domoticz Dev !
got a small teaser for you :
http://domo-attitude.fr/cube-xiaomi-teaser/
Xiaomi Cube + Yeelight : Rotative dimmer !
