deennoo
Post by deennoo »
Ok done ! Got to debug brightness for gateway hurry up ! ;-)
And get a hair cut ! Hippie ! Lol
http://domo-attitude.fr
corbin
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by corbin »
murtadin wrote: But i have checked some libs - they are installed. Not all - cause i do not use kerberos, ldap and so on But may be some important libs are missed and for some reason, when i configure sources i see no errors at all about it.
P.S. - i really apreciate your help. Thank you.
I would guess missing crypto libraries on your Gentoo too - I don't really know what I'm looking at here, but this is the output from my Raspberry:
pi@raspberrypi:~/domoticz $ sudo ldd domoticz
        linux-vdso.so.1 (0x7efd6000)
        /usr/lib/arm-linux-gnueabihf/libarmmem.so (0x76f43000)
        libusb-0.1.so.4 => /lib/arm-linux-gnueabihf/libusb-0.1.so.4 (0x76f24000)
        libssl.so.1.0.0 => /usr/lib/arm-linux-gnueabihf/libssl.so.1.0.0 (0x76eca000)
        libcrypto.so.1.0.0 => /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0 (0x76d5c000)
        librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0x76d45000)
        libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0x76d1d000)
        libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0x76cf5000)
        libcurl.so.4 => /usr/lib/arm-linux-gnueabihf/libcurl.so.4 (0x76c84000)
        libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0x76c71000)
        libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0x76bf6000)
        libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0x76ab5000)
        /lib/ld-linux-armhf.so.3 (0x54b15000)
        libidn.so.11 => /usr/lib/arm-linux-gnueabihf/libidn.so.11 (0x76a73000)
        librtmp.so.1 => /usr/lib/arm-linux-gnueabihf/librtmp.so.1 (0x76a4a000)
        libssh2.so.1 => /usr/lib/arm-linux-gnueabihf/libssh2.so.1 (0x76a28000)
        libgssapi_krb5.so.2 => /usr/lib/arm-linux-gnueabihf/libgssapi_krb5.so.2 (0x769de000)
        libkrb5.so.3 => /usr/lib/arm-linux-gnueabihf/libkrb5.so.3 (0x7692a000)
        libk5crypto.so.3 => /usr/lib/arm-linux-gnueabihf/libk5crypto.so.3 (0x768eb000)
        libcom_err.so.2 => /lib/arm-linux-gnueabihf/libcom_err.so.2 (0x768d8000)
        liblber-2.4.so.2 => /usr/lib/arm-linux-gnueabihf/liblber-2.4.so.2 (0x768bc000)
        libldap_r-2.4.so.2 => /usr/lib/arm-linux-gnueabihf/libldap_r-2.4.so.2 (0x76868000)
        libgnutls-deb0.so.28 => /usr/lib/arm-linux-gnueabihf/libgnutls-deb0.so.28 (0x7675b000)
        libhogweed.so.2 => /usr/lib/arm-linux-gnueabihf/libhogweed.so.2 (0x76721000)
        libnettle.so.4 => /usr/lib/arm-linux-gnueabihf/libnettle.so.4 (0x766e1000)
        libgmp.so.10 => /usr/lib/arm-linux-gnueabihf/libgmp.so.10 (0x7666f000)
        libgcrypt.so.20 => /lib/arm-linux-gnueabihf/libgcrypt.so.20 (0x765cc000)
        libkrb5support.so.0 => /usr/lib/arm-linux-gnueabihf/libkrb5support.so.0 (0x765b3000)
        libkeyutils.so.1 => /lib/arm-linux-gnueabihf/libkeyutils.so.1 (0x765a7000)
        libresolv.so.2 => /lib/arm-linux-gnueabihf/libresolv.so.2 (0x76582000)
        libsasl2.so.2 => /usr/lib/arm-linux-gnueabihf/libsasl2.so.2 (0x7655b000)
        libp11-kit.so.0 => /usr/lib/arm-linux-gnueabihf/libp11-kit.so.0 (0x7651a000)
        libtasn1.so.6 => /usr/lib/arm-linux-gnueabihf/libtasn1.so.6 (0x764fa000)
        libgpg-error.so.0 => /lib/arm-linux-gnueabihf/libgpg-error.so.0 (0x764db000)
        libffi.so.6 => /usr/lib/arm-linux-gnueabihf/libffi.so.6 (0x764cb000)
        libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0x7649e000)
corbin
Post by corbin »
deennoo wrote:Ok done ! Got to debug brightness for gateway hurry up ! ;-)
Haha, one day, for both :)
levynger
Post by levynger »
Corbin, I finally assembled Visual studio with domoticz,and cloned your github.
when i run domoitcz, im missing the gateway ip and passoword fields, resulting in empty strings in m_gatewayIp and m_GatewayPassword
any idea what can cause this?
psedma
Post by psedma »
any idea of my "problem"? I can't even see xiaomi gateway in "type" of hardware.
corbin
Post by corbin »
@levynger, @psedma, clear your browser cache so that you get the fresh files.
levynger
Post by levynger »
corbin wrote:@levynger, @psedma, clear your browser cache so that you get the fresh files.
Thanks @corbin
וtried that, also using the chrome plug in you suggested.
I r happen only on the compiled version from visual Studio.
On my Ubuntu, I pulled and compiled.. No issues.
corbin
Post by corbin »
copy the whole 'www' folder from the root of the project to the msbuild folder, replacing what is already there.
ben53252642
Post by ben53252642 »
Received a box of Xiaomi sensors in the mail today, super impressed by the quality of the hardware, it's a lot smaller than I expected which opens up new possibilities for putting motion sensors around the place.
Opened each sensor and recorded the battery models (I have so many sensors from so many brands now this is the first thing I do).
Might want to keep a packet of each battery type in the cupboard, they all take different batteries. :)
Brand: Type: Sensor Model: Battery Model: Battery Voltage:
Xiaomi Door Sensor MCCGQ01LM CR1632 3v
Xiaomi Motion Sensor RTCGQ01LM CR2450 3v
Xiaomi Push Button WXKG01LM CR2032 3v
Also received the Xiaomi Air Purifier v2, again the quality of the hardware appears very well built. Working to figure out how to integrate it into Domoticz. :D
vetalok
Domoticz version: 3.6273
Post by vetalok »
ben53252642 wrote:Received a box of Xiaomi sensors in the mail today, super impressed by the quality of the hardware, it's a lot smaller than I expected which opens up new possibilities for putting motion sensors around the place.
You must also have Xiaomi Gateway. The sensors do not work without it.
vetalok
Post by vetalok »
corbin wrote:
vetalok wrote: Emm... When I enable LED from MiHome - Domoticz off light
I've made a couple of changes, you will now need to turn the light on from the app to get it to detect in Domoticz, and I've added some extra log output. Can you try that and post the output if it still isn't working?
Yes I can. I will test how come from work (At 17:00 GMT).
levynger
Post by levynger »
corbin wrote:copy the whole 'www' folder from the root of the project to the msbuild folder, replacing what is already there.
thanks @corbin, a magician.. as always..
murtadin
Post by murtadin »
who can give me minimal system requirements? Which libs and kernel options are required in order to run domoticz with xiaomi gateway? Why no errors during configure an make?
Help - this driving me crazy ))
levynger
Post by levynger »
Turning it on/off once indeed got it detected in Devices.
however trying to turn it on/off results in invalid key ack
2017-01-18 10:39:11.700 XiaomiGateway: response {"cmd":"write_ack","sid":"f0b429cbf966","data":"{\"error\":\"Invalid key\"}"}
Coldman
Post by Coldman »
XiaomiGateway: unhandled model: gateway
{"cmd":"report","model":"gateway","sid":"f0b4299a4e49","short_id":0,"data":"{\"rgb\":1694498782}"}
{"cmd":"report","model":"gateway","sid":"f0b4299a4e49","short_id":0,"data":"{\"rgb\":0}"}
update: after git pull from https://github.com/corbinmunce/domoticz
XiaomiGateway: rgb received value: 1694498782
XiaomiGateway: setting on to true
XiaomiGateway: New Gateway Found (299a4e49/Xiaomi RGB Gateway)
2017-01-18 23:23:09.751  (xGW) Lighting Limitless/Applamp (Unknown)
XiaomiGateway: rgb received value: 0
XiaomiGateway: setting on to false
XiaomiGateway: Updating existing - nodeid: f0b4299a4e49
2017-01-18 23:23:13.744  (xGW) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
and as a result:
Mat2Vence
Domoticz version: 3.7449
Post by Mat2Vence »
Any idea why I cannot get the latest beta version update of domoticz? I am getting an error at the very end of the download
Coldman
Post by Coldman »
Mat2Vence wrote:Any idea why I cannot get the latest beta version update of domoticz? I am getting an error at the very end of the download
what is your platform - Windows/Unix?
levynger
Post by levynger »
im using both linux and windows, just tried to downlaod latest beta from domoticz, didnt see any problem.
file downloaded sucessfully.
levynger
Post by levynger »
@corbin, im getting invalid key ack from the gateway on any command i construct using the string from "GetGatewayKey();" function.
is it working for you?
Mat2Vence
Post by Mat2Vence »
I should have made something wrong... I succeed. Let's make some trial on this new release and xiaomi :)
