And get a hair cut ! Hippie ! Lol
deennoo
Ok done ! Got to debug brightness for gateway hurry up !
http://domo-attitude.fr
- corbin
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
I would guess missing crypto libraries on your Gentoo too - I don't really know what I'm looking at here, but this is the output from my Raspberry:murtadin wrote: But i have checked some libs - they are installed. Not all - cause i do not use kerberos, ldap and so on But may be some important libs are missed and for some reason, when i configure sources i see no errors at all about it.
P.S. - i really apreciate your help. Thank you.
- Spoiler: show
- corbin
Haha, one day, for bothdeennoo wrote:Ok done ! Got to debug brightness for gateway hurry up !
levynger
Corbin, I finally assembled Visual studio with domoticz,and cloned your github.
when i run domoitcz, im missing the gateway ip and passoword fields, resulting in empty strings in m_gatewayIp and m_GatewayPassword
any idea what can cause this?
- Capture.PNG (97.5 KiB) Viewed 3398 times
any idea of my "problem"? I can't even see xiaomi gateway in "type" of hardware.
- 2017-01-17.png (68.5 KiB) Viewed 3374 times
- corbin
@levynger, @psedma, clear your browser cache so that you get the fresh files.
levynger
Thanks @corbincorbin wrote:@levynger, @psedma, clear your browser cache so that you get the fresh files.
וtried that, also using the chrome plug in you suggested.
I r happen only on the compiled version from visual Studio.
On my Ubuntu, I pulled and compiled.. No issues.
- corbin
copy the whole 'www' folder from the root of the project to the msbuild folder, replacing what is already there.
ben53252642
Received a box of Xiaomi sensors in the mail today, super impressed by the quality of the hardware, it's a lot smaller than I expected which opens up new possibilities for putting motion sensors around the place.
Opened each sensor and recorded the battery models (I have so many sensors from so many brands now this is the first thing I do).
Might want to keep a packet of each battery type in the cupboard, they all take different batteries.
Brand: Type: Sensor Model: Battery Model: Battery Voltage:
Xiaomi Door Sensor MCCGQ01LM CR1632 3v
Xiaomi Motion Sensor RTCGQ01LM CR2450 3v
Xiaomi Push Button WXKG01LM CR2032 3v
Also received the Xiaomi Air Purifier v2, again the quality of the hardware appears very well built. Working to figure out how to integrate it into Domoticz.
- vetalok
- Domoticz version: 3.6273
You must also have Xiaomi Gateway. The sensors do not work without it.ben53252642 wrote:Received a box of Xiaomi sensors in the mail today, super impressed by the quality of the hardware, it's a lot smaller than I expected which opens up new possibilities for putting motion sensors around the place.
- vetalok
Yes I can. I will test how come from work (At 17:00 GMT).corbin wrote:I've made a couple of changes, you will now need to turn the light on from the app to get it to detect in Domoticz, and I've added some extra log output. Can you try that and post the output if it still isn't working?vetalok wrote: Emm... When I enable LED from MiHome - Domoticz off light
levynger
thanks @corbin, a magician.. as always..corbin wrote:copy the whole 'www' folder from the root of the project to the msbuild folder, replacing what is already there.
murtadin
who can give me minimal system requirements? Which libs and kernel options are required in order to run domoticz with xiaomi gateway? Why no errors during configure an make?corbin wrote:
Help - this driving me crazy ))
levynger
Turning it on/off once indeed got it detected in Devices.
however trying to turn it on/off results in invalid key ack
2017-01-18 10:39:11.700 XiaomiGateway: response {"cmd":"write_ack","sid":"f0b429cbf966","data":"{\"error\":\"Invalid key\"}"}
Coldman
XiaomiGateway: unhandled model: gateway
{"cmd":"report","model":"gateway","sid":"f0b4299a4e49","short_id":0,"data":"{\"rgb\":1694498782}"}
{"cmd":"report","model":"gateway","sid":"f0b4299a4e49","short_id":0,"data":"{\"rgb\":0}"}
XiaomiGateway: rgb received value: 1694498782
XiaomiGateway: setting on to true
XiaomiGateway: New Gateway Found (299a4e49/Xiaomi RGB Gateway)
2017-01-18 23:23:09.751 (xGW) Lighting Limitless/Applamp (Unknown)
XiaomiGateway: rgb received value: 0
XiaomiGateway: setting on to false
XiaomiGateway: Updating existing - nodeid: f0b4299a4e49
2017-01-18 23:23:13.744 (xGW) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
- Spoiler: show
Mat2Vence
- Domoticz version: 3.7449
Any idea why I cannot get the latest beta version update of domoticz? I am getting an error at the very end of the download
Coldman
what is your platform - Windows/Unix?Mat2Vence wrote:Any idea why I cannot get the latest beta version update of domoticz? I am getting an error at the very end of the download
levynger
im using both linux and windows, just tried to downlaod latest beta from domoticz, didnt see any problem.Coldman wrote:what is your platform - Windows/Unix?Mat2Vence wrote:Any idea why I cannot get the latest beta version update of domoticz? I am getting an error at the very end of the download
file downloaded sucessfully.
levynger
@corbin, im getting invalid key ack from the gateway on any command i construct using the string from "GetGatewayKey();" function.levynger wrote:corbin wrote:I've made a couple of changes, you will now need to turn the light on from the app to get it to detect in Domoticz, and I've added some extra log output. Can you try that and post the output if it still isn't working?vetalok wrote: Emm... When I enable LED from MiHome - Domoticz off light
is it working for you?
Mat2Vence
I should have made something wrong... I succeed. Let's make some trial on this new release and xiaomilevynger wrote:im using both linux and windows, just tried to downlaod latest beta from domoticz, didnt see any problem.Coldman wrote:what is your platform - Windows/Unix?Mat2Vence wrote:Any idea why I cannot get the latest beta version update of domoticz? I am getting an error at the very end of the download
