denisj
Post by denisj »
barbaar wrote:...
However, I would like to adjust the frontpage so it will be full screen on my tablet (1920x1200). I cannot get this to work.
I also want to change the screen res. in order to run on my tablet.
I think that in some place of code it take the max resolution of the screen and then it reduce it. ) (???)
Denis
peterjoosen
Domoticz version: 4.9700
Post by peterjoosen »
[/quote]
Hansbit wrote:I've updated the default frontpage.html page
Most important changes:
- The html is cleaned and structured. User settings are now only at end of script.
- All cells are numbered. If cell is not defined in user settings, the cell number appears on screen
- User can now easily set the label of the cell in the user settings (like 'Temperature Livingroom')
- User can now set optional alarm value. Of value of sensor above this value, the text will turn to RED.
- User can easily adjust the color of the text.
- If defined cell is a switch, the cell is clickable to switch that device.
How to install?
- copy attached frontpage.html to the Domoticz ditrectory (domoticz/www)
- Create a roomplan in Domoticz and add devices to that roomplan
- Adjust user settings in frontpage.html: the URL of your domoticz, the number of your roomplan and the devices to display
- If log-in for Domoticz is required, it best to add the IP of the device displaying the frontpage to the settings in Domiticz, so no login is required.
- Open in browser [your Domoticz IP]:8080/frontpage.html
Please send me your comments!
Hans
frontpage.html.tar.gz
Hello Hans,
I followed your instructions to get the frontpage online, but all cells stays empty (--) and also no names are filled in the cells.
-Created a roomplan in Domoticz
-Filled in the roomplan N° (user values)
-Filled in url (user values)
-Filled in a couple off switches (idx,....name of the switch etc...)
Any idea what causes this problem???
Thanks already ;-)
Peter
albertvandam
Post by albertvandam »
Dear all,
With all the examples and code in this forum, I have managed to create a pretty good frontpage which runs on a wall mounted tablet. Thanks to Hansbit, G3rard and all others.
However I can't get to control my Dru Fireplace (Mertik G6R-HT4B) on the frontpage like it should. Directly from Domoticz it works fine.
Does someone have the right json commands to control the Mertik controller?
When I send json commands directly from the Chrome Address Bar, it doesn't work as aspected also.
For example:
http://192.168.4.250:8080/json.htm?type ... itchcmd=up
switches the fire place off!
Thanks in advance for any response.
jompie
Domoticz version: 3.5877
Post by jompie »
you need to use Capitial letter "U", thus: Up and not up, as a command.
KAKU switches/receivers/Motion sensor/Doorbell
Oregon Temp sensors, TFA Temp sensor
Mertik controller
Raspberry Pi, RFXCom
albertvandam
Hi Jompie,
You were absolutely right! :lol:
Thanks a lot.
madrian
Post by madrian »
Guys, one question:
I can't get to work one Dummy switch. I have few of them, but this one is not working. It's just showing "Nan" and doesn't reagate to click.
 "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 15,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "HardwareName" : "Dummy",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "00014060",
         "Image" : "Heating",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-01-06 15:00:01",
         "Level" : 100,
         "LevelInt" : 100,
         "MaxDimLevel" : 100,
         "Name" : "Heating",
         "Notifications" : "false",
         "PlanID" : "4",
         "PlanIDs" : [ 4 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "SwitchType" : "On/Off",
         "SwitchTypeVal" : 0,
         "Timers" : "true",
         "Type" : "Light/Switch",
         "TypeImg" : "lightbulb",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "17"
Screen Shot 2017-01-07 at 02.45.29.png (35.64 KiB) Viewed 3197 times
Screen Shot 2017-01-07 at 03.58.04.png (337.49 KiB) Viewed 3191 times
.js:
['17',	'Status',		'cell6',	'Heating','0','0'],
If I turn on "lastseen is wanted" -> I can see the correct date.
What's wrong with this?
denisj
Post by denisj »
albertvandam wrote:Dear all,
Albert,
can you please upload your frontpage packet some wear in order to download it and take some sample please ?
Thanks in advance
Denis
ChrisPi
Post by ChrisPi »
Is ther anyone that can tel how to change mij inlogscreen? I just want to change the Domoticz into my name.
Inlog screen
Inlog screen
ropske
Domoticz version: V3_8394
Post by ropske »
hi ChrisPi,
i don't think you can change this, unless you change it in the sourcecode and rebuild it
madrian
Post by madrian »
I created similar dummy switch and replaced the not working switch with this. Now it works. Anyone knows what happened here?
ChrisPi
Post by ChrisPi »
ropske wrote:hi ChrisPi,
Oké. Do you know where to find the sourcecode?
ropske
Post by ropske »
ChrisPi
Post by ChrisPi »
Thanks for your comment. I just looked here but can you be more specific?
ropske
Post by ropske »
I also don't know in what part this is, sorry
markk
Post by markk »
Has anyone incorporated their front page into a smart mirror? https://www.youtube.com/watch?v=oLpwJAphU7Y
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
sorry wanted to delete this post
JuanUil
Post by JuanUil »
Do you know the problem?
Do we need to put the garbage, the green garbage or the paper container outside?
I have made a selectorswitch and a program to display what container needs to get out.
the LUA code:
week 	= tonumber (os.date( "%V"))
dag		= tostring(os.date("%a"));
status	= tonumber(otherdevices_svalues['Afval'])
--print ('Dag=  '..dag)
if (dag=='Fri' or dag=='Sat'  ) then
	weekend = false; weekdag = true
if (dag=='Mon' or dag=='Tue' or dag=='Wed' or dag=='Thu'or dag=='Sun') then
	weekend = true ; weekdag = false
--Bepalen alleen grijs
if(week==2 or week==6 or week==10 or week==14 or week==18 or week==22 or week==26 or week==30 or week==34 or week==38) then
		afval = true ; papier = false ; groen = false
--Bepalen grijs en papier
if (week==42 or week==46 or week==50) then
		afval = true ; papier = true ; groen = false
--Bepalen alleen groen
if (week==1 or week==5 or week==9 or week==13 or week==17 or week==19 or
	week==21 or week==23 or week==25 or week==27 or week==29 or week==31 or week==35 or week==39
	or week==41 or week==43 or week==45 or week==47 or week==49 or week==51) then
		afval = false ; papier = false ; groen = true
--Bepalen groen en papier
if (week==3 or week==7 or week==11 or week==15 or week==33 or week==37 ) then
		afval = false ; papier = true ; groen = true
--Bepalen alleen papier
if (week==20 or week==24 or week==28) then
		afval = false ; papier = true ; groen = false
-- Bepalen niets
if (week==4 or week==8 or week==12 or week==16 or week==32 or week==36 or week==40 or week==44 or week==48 or week==52) then
		afval = false ; papier = false ; groen = false
if (not(afval) and not(papier) and not(groen) and status~=10) then
		status=10
		commandArray ['UpdateDevice']= '383|0|' .. status
if (afval and weekdag and status~=20)then
		status=20
if (afval and weekend and status~=10) then
		status=10
if (groen and weekdag and status~=30) then
		status=30
if (groen and weekend and status~=10) then
		status=10
if (papier and weekend and status~=40) then
		status=40
if (papier and weekdag and status~=10) then
		status=10
And the adjustment in frontpage.js
	// replace Afval met icoon
		if (item.idx == idx_Afval){// && vdata == "grijs" ){
			vdata = item['Level']; //get current level
			if (vdata == '10'){}
				vdata=new String(vdata).replace( "10", "<img src=icons/niets.png  height=155px vspace=35> ");
			if (vdata == '20'){}
				vdata=new String(vdata).replace( "20", "<img src=icons/grijs.png  height=155px vspace=20> ");
			if (vdata == '30'){}
				vdata=new String(vdata).replace( "30", "<img src=icons/groen.png  height=155px vspace=20> ");
			if (vdata == '40'){}
				vdata=new String(vdata).replace( "40", "<img src=icons/papier.png  height=155px vspace=35> ");
And of course some screenshots
enjoy
Jan
pvm
Domoticz version: 4.10538
Post by pvm »
markk wrote:Has anyone incorporated their front page into a smart mirror? https://www.youtube.com/watch?v=oLpwJAphU7Y
Somewhat different but possibly interesting :
I performed some tests with https://magicmirror.builders
Nice mirror software with a lot of plugins. It shouldn't be too hard to incorporate domoticz information.
jhenrikb
Post by jhenrikb »
Hi:)
How are you guys installing any frontpage to your Raspi Domoticz interface?
I have tried to Download this (among other frontpages) packages.
Unzip on computer
Edit config and or other file to correct IP adress, Port, User&Password etc.
Load all the files into www folder with a subfolder with filezilla
enter: http://ip:port/folder (with no success)
also tried "..folder/" and "..folder/index.htm" and "..index.htm/". Also with no success.
Do i need to do this differently?
Sincerely
John
Trigun
Domoticz version: 4.10717
Post by Trigun »
For example:
Hi Albertvandam,
first of all, you did a great job!
is there a chance you can post your frontpage files?
I would love to check it out and see how I can make it fit for my home.
thnx in advance!
