Yes try firmware update, as I believe v2 of the gateway has been released for quite some time alreadydeennoo wrote:@ducseb don't you have a fw update to do on your gateway ?
- corbin
- corbin
I did read somewhere that v1 did not support radio, and that listing specifically states it has the radio feature, so I would guess it is ok.jjnj wrote:Just to be 100% sure:
i should buy this one: https://goo.gl/qQcoeo and not perse https://goo.gl/TZ1291 ?
deennoo
Using a selector switch !corbin wrote:
Yes these events are reported by the gateway, but I don't know what to translate them to in Domoticz. Have you a suggestion?
http://domo-attitude.fr
pavelbor
- Domoticz version: LastBeta
May be split them into 3 independent buttons (switches without state)?corbin wrote:Yes these events are reported by the gateway, but I don't know what to translate them to in Domoticz. Have you a suggestion?levynger wrote: I have noticed that the Switch Does report single, double and Long press (Pressed and released events)
altough it doesnt appear in Device tab like the other XIOAMI devices.
does this exposed in one the switch type as well?
- corbin
Thanks, I just changed my source to add a selector switch, but I only see the button for "Off", not "1 Press | 2 Press | Long Press"deennoo wrote:
Is there something else to do to get those options?
deennoo
My gateway is still not here.
My screen was an exemple for you
Hide off
1 press : selector 10%
2 press : selector 20%
Long press : selector 30%
You have to code it !
Hide off
- corbin
That would be ok, but if the switch deennoo has posted can work, it looks the goods!pavelbor wrote: May be split them into 3 independent buttons (switches without state)?
- corbin
I just ticked "Hide Off level", but that doesn't work, where do i Hide Off?deennoo wrote:Hide off
- corbin
Oh, haha!deennoo wrote:My gateway is still not here.
Hide off
I'm not going to code that, but you are welcome to
Is this something that could be done with the new Python add on?
- vetalok
- Domoticz version: 3.6273
I have a problem, when I add gateway:
Maybe the problem in port? I enter the following data:XiaomiGateway: Worker started...
terminate called after throwing an instance of 'boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::system::system_error> >'
what(): bind: Address already in use
type:command
param:addhardware
htype:95
address:192.168.2.193
port:777
password:oz8w8fomda1do20a
enabled:true
datatimeout:0
Mode1:undefined
deennoo
Will try to help when my gateway will arrive.corbin wrote:Oh, haha!deennoo wrote:My gateway is still not here.
Hide off
About coding/linking switch status to selector switch, i think first that you have to understand that selector is just a dimmer (like yeelight mono bulb) switch with predefin step.
Selector api : https://www.domoticz.com/wiki/Domoticz_ ... tor_Switch
As our switch got 3 status, we need 3 steps, 3 % values
If your able to parse switch message, it need a rules like
If recieve switch xx 1 pluse then selector = 10%
Else if If recieve switch xx 2 pluse then selector = 20%
Else if If recieve switch xx long pulse then selector = 30%
At creation instead of creating push on , select : selector and try adding rules.
Second solution :
Update a text device with switch status message on it.
And python plugin are still on beginning (need to have an installer, and finishing evaluating how it works, if we can call various lib etc etc) as this is a new feature and looks hard to develop this can take time.
- corbin
I was adding the selector switch in a wrong way. Have done it through the Domoticz GUI now and see the extra options - so will be simple to hook up the code.
- corbin
Does this still happen after a system restart?vetalok wrote:I have a problem, when I add gateway:Maybe the problem in port? I enter the following data:XiaomiGateway: Worker started...
- corbin
Switches now have the extra options:
Coldman
to check it is need to do it?corbin wrote:Switches now have the extra options:
git pull
cmake CMakeLists.txt
make
- corbin
only in my repository at this stage, so something like this:
git clone https://github.com/corbinmunce/domoticz.git domoticz
deennoo
Great ! Very great !corbin wrote:Switches now have the extra options:
- vetalok
Yes. System crashed and not restarted.corbin wrote:Does this still happen after a system restart?vetalok wrote:I have a problem, when I add gateway:Maybe the problem in port? I enter the following data:XiaomiGateway: Worker started...
Only If I delete a domoticz.db file, the system runs.
What am I doing wrong? Why do I have this issue?
- corbin
deennoo wrote:Great ! Very great !corbin wrote:Switches now have the extra options:
- corbin
It might be another program listening on UDP. I will try to stop the crash in my code. Are you running other programs or plugins that could be conflicting?vetalok wrote:
