Energy read "computed" or "from device"
rmbrmb
Domoticz version: Latest
Post by rmbrmb »
Can someone explain me the difference between the energy read options "computed" and "from device"?
I have an Inepro DDS-1Y kWh Meter (2000 pulses per kWh) and I have a S0PCM-5 Pulse Counter Module.
The S0PCM-5 Pulse Counter Module port is configured for "Energy" and 2000 pulses per hour.
I doubt if the Watts reading is accurate, so perhaps that is a matter of changing a setting...
Kind regards,
Rene.
Toulon7559
Domoticz version: <2025
Re: Energy read "computed" or "from device"
Post by Toulon7559 »
Where do you see those 2 options for energy read?
rmbrmb
Post by rmbrmb »
Check this screenshot;
rmbrmb
Post by rmbrmb »
Nobody knows the difference?
Toulon7559
Cannot remember to have seen that choice when I installed S0PCM for Domoticz.
At this moment in my setup I see that the selection-'dot' is at 'Device', apparently as result of the automatic upgrades of Domoticz-software.
As deduction, in my opinion 'Device' means that Domoticz takes the value as reported by S0PCM.
The firmware of S0PCM has been upgraded since the time I installed it, and recently I also went to version 5.
I vaguely remember to have heard that in S0PCM some extra features have been added which can optionally be called by Domoticz.
The wiki is not uptodate for explanation on that choice:
therefore I guess/speculate that 'Computed' means that Domoticz has some hidden computation, in relation to extra information from S0PCM, or there is some other, undocumented feature for the S0PCM-interface ........
Because I also have some questions related to the accuracy of the results out of some channels of S0PCM, for 'try-and-error' I will shift those S0PCM-channels to 'Computed' and will look what happens.
Last edited by Toulon7559 on Sunday 22 January 2017 12:18, edited 1 time in total.
rmbrmb
Post by rmbrmb »
How can I check my S0PCM firmware version and is it user-upgradable?
I think in my case selecting "computed" is giving more accurate results, but I am not completely convinced about this.
Toulon7559
(At least at my S0PCModule) the housing of the S0PCM has a sticker showing the firmware-version at delivery.
Is upgrable by user if you have the latest firmware-file with suitable upload-software and instructions.
Toulon7559
:( Result of the short experiment to put the selection at 'Computed':
handling of actual power values seems OK/unchanged, but the related accumulated day-values in Domoticz now stay fixed at 0
Conclusion: still questionmark
Toulon7559
;-) We make another testrun starting this evening with all 5 channels of the S0PCM put a 'Computed':
2 channels are for Consumption (and according to gordonb3's assumptions should start counting immediately after midnight, providing me with some values at breakfast)
3 channels are for Generation (and at breakfast to be expected still at 0, coming up later in the morning).
Toulon7559
In my setup the result of the test over last 2 days is clear:
  • 5 of 5 S0PCM-channels report a dayenergy-value of 0
First conclusion: put the setting on 'From Device', because then at least you get values.
Questionmark remaining related to meaning of other setting 'Computed'.
juankar
Domoticz version: 4.
Post by juankar »
Difference between Computed and from device is simple:
Computed:
Domoticz compute the energy by subtracting values sent by device.
Domoticz computes the energy by multiplying time and power,
for instance: 5 watts lamp light on for 2 hours, energy consumption is 5x2 = 10 wh = 0,010 kwh
This is useful if device doesn't send energy consumption or if device precision energy meter is too low.
In last example if device reads energy with a precision of 0,1 kwh, it doesn't send the consumption of the lamp until it reach a value of 0,1 kwh. But with computed method you can read the energy consumption every minute.
Toulon7559
In my setup the S0PCM reports for all channels an actual power which seems reasonably correct
[for the 3 'generation-channels' I have comparison-info from my K8055-board+software: see http://www.vannwnhzn.nl/grafiek.jpg ].
That makes me wonder, because it demonstrates that the S0PCM-calculations are rather accurate.
And more surprising is that these actual power values are shown regardless whether 'Computed' or 'From Device' is selected.
Therefore it seems that juankar's explanation is not true, but what is then the explanation?
juankar
Post by juankar »
I have using this setting for Qubino switches, whose energy meter has 0,1 kwh precision, and it works fine as computed. I don't use in production.
