ERRORR2
Post by ERRORR2 »
corbin wrote:Can you compile the code at https://github.com/corbinmunce/domoticz and see if it finds your devices?
I will try, but I never did it before)
levynger
Post by levynger »
Excellent work!
i been working on Beta 17/12 so far seems very stable and works excellent.
i have noticied 2 things though:
The door sensor after 1 minute will send "Closed" message (or earlier if closed of course..)
this means i cant create a notification if the door is open for 10 minute... 1 minute is the longer..
the motion sensor will not update triggers for less then 60 seconds periods, for some implementation i guess its more than enough.
Just got the humidity sensor.. cant wait for the next update with this sensor support included..
deennoo
Post by deennoo »
To users who got zigbee wall plug, can you confirm that plug is a part of zigbee network and act as a network extender ?
http://domo-attitude.fr
pavelbor
Domoticz version: LastBeta
Post by pavelbor »
deennoo wrote:To users who got zigbee wall plug, can you confirm that plug is a part of zigbee network and act as a network extender ?
How we can know/confirm that?
corbin
Post by corbin »
ERRORR2 wrote: I will try, but I never did it before)
It is easier to compile on Linux following the guide in the Wiki, you could setup a VM to test with.
With the way Christmas is going here, I won't have time to do anymore for a week.
deennoo
Post by deennoo »
On zigbee always powered device have to be a part and extender of the mesh network, if a sensor is "connected" to it, message have to go like this
Sensor->plug->gateway
Gateway is the coordinator
Plug acting like a repeter/router
Batterie device are end network device
Put a sensor (switch/door/pir/temp) out of the network range, and put a wallswitch on halfway between the gateway and the sensor and check if sensor is reported or not.
ERRORR2
Post by ERRORR2 »
corbin wrote: It is easier to compile on Linux following the guide in the Wiki, you could setup a VM to test with.
Compiled! And now I can see my socket) Thanks! Waiting for build, allowing to control)
pavelbor
Post by pavelbor »
Hello, what about temp&humidity sensors, do you see them ?
ERRORR2
Post by ERRORR2 »
pavelbor wrote: Hello, what about temp&humidity sensors, do you see them ?
No, I can't see my temp&humidity sensor, only zigbee socket.
tiboo86
Post by tiboo86 »
Corbin said that he had a few lines of codes to finalize before he could put it online to be able to retrieve the information of the temprétaures & humidity sensors.
You have to be patient and corbin has already done a very good job :)
For information, thumb those who would have a problem with their gateway.
The first version of the gateway released before 2016, does not have the function LAN developper.
A gateway must be left after 2016 or the AQARA version.
ZEMI
Post by ZEMI »
I've added Gateway as in instruction https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara) but nothing appeared in "Devices". With Yeelight bulbs it's all ok. I need to enter this password somewhere?
Sorry for noob question) May be i need to download any plugin? I use the latest beta.
levynger
Post by levynger »
ZEMI wrote:I've added Gateway as in instruction https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara) but nothing appeared in "Devices". With Yeelight bulbs it's all ok. I need to enter this password somewhere?
No password needed.
did you go to "Switches" tab and press Learn Light/Switch ? you have 5 seconds to press the switch, or buttons on the MI sensors (door, motion etc)
it should recognize them during the learning time appears on screen.
ZEMI
Post by ZEMI »
I've tried, but nothing, it even doesn't see gateway. May be i can set somewhere is't IP manually?
icibt
Post by icibt »
I have the same problem. Added my Yeelight's without a problem... but can't add my Gateway. Did you found a solution?
Coldman
Post by Coldman »
I had the same problem on Windows 10x64, under Ubuntu everything is working.
Отправлено с моего MI PAD 2 через Tapatalk
ZEMI
Post by ZEMI »
icibt wrote: I have the same problem. Added my Yeelight's without a problem... but can't add my Gateway. Did you found a solution?
No, i don't, also Windows 10 x64
arkoko
Post by arkoko »
levynger wrote:The door sensor after 1 minute will send "Closed" message (or earlier if closed of course..)
I confirm that bug and it's a nasty restriction using door sensor with Domoticz.
Just tested with original MiHome app and there sensor stay "open" as long is it open.
Coldman
Post by Coldman »
I confirm this bug too, window is open still but the sensor has status "off" after 1 minute in log.
Отправлено с моего ONE A2001 через Tapatalk
corbin
Post by corbin »
Cool! Please compile from https://github.com/corbinmunce/domoticz again and you (hopefully) will have control of your socket. As usual you will need to fully refresh your browser cache, and then add the Xiaomi Gateway again with the gateway settings (password, ip, port - only the password needs to be correct).
Also door sensors should now continue to detect as open, when they are left open.
Temp and battery sensors are not quite done yet.
corbin
Post by corbin »
For anyone having no devices being found, please ensure your cache is cleared. If you are using Chrome, try https://chrome.google.com/webstore/deta ... kbap?hl=en as recommended by apazga.
I use Chrome for development, with cache disabled under the network tab, but it still seems to cache sometimes which is a pain.
