Basic OpenZwave Question
Cannon
- Domoticz version: 3.5877
Im running windows 10 with the latest stable version of domoticz,
What am i doing wrong to not see my Gen5 aeon labs stick in the open zwave control panel. ?
- Egregius
- Domoticz version: v2024.7
Re: Basic OpenZwave Question
You see the stick in Domoticz -> Hardware?
You open OZWCP from Domoticz -> Hardware -> Openzwave? Or directly from a bookmark?
Cannon
Thanks for your reply,
Yes I see the stick in domoticz, I have about 4 lights 3 sensors, weather underground set up, all operating for about a year, but nothing in my OZWCP, i go through the menus,
Set up
Hardware
Zwave Stick Setup
Node Management
Control Panel
To get to it.
Is that correct?
Set up
Hardware
Zwave Stick Setup
Node Management
Control Panel
To get to it.
Is that correct?
- Egregius
Yes, that's the way to go to it.
You can't open it directly from bookmark, something with session or authentication.
Then, once in OZWCP the screen is empty? Can you post a screenshot?
- Egregius
Can you try this?
First open this url: (change the idx to the idx of your zwave stick)
"http://127.0.0.1:8080/json.htm?type=ope ... odes&idx=3"
then open ozwcp on "http://192.168.2.10:8080/ozwcp/cp.html"
Why? I sent commands from CLI directly to ozwcp. If I don't open the first url I don't get a response.
Cannon
yup got the first one to open ok,
the second timed out though
- Egregius
Oh, I forgot to change the IP address of the second one:
"http://192.168.2.10:8080/ozwcp/cp.html" to "http://127.0.0.1:8080/ozwcp/cp.html"
Also: do it in the same browser without closing it.
Cannon
Yes I figured that bit out after awhile
but still a blank control panel as in the screenshot
benotje
- Domoticz version: V4.20078
Can you post a screenshot from the domoticz hardware ??
raspberry pi
nas synology
homey
nas synology
homey
- Domosapiens
- Domoticz version: V3.5981
Check the permissions of the Domoticz directory.
I vaguely remember that I had an equal problem some time ago after a Windows7 update
Cannon
I checked and everbody has full control over the entire folder, I also tried changing the contents and taking off read only...
Cannon
Anyone???
- Domosapiens
Double check the ozwcp sub-folder on permissions?
Do you have a ozwcp.poll.XXXXXX.xml file in the Domotics folder?
OZW_Log.txt in the Config folder?
Run Domoticz as Administrator?
(just guessing, I have no Win10)
Gravityz
- Domoticz version: 2025.1
anybody solved this.
i have similar problems that 2 devices are not visible in openzwave control panel
is there a way to force ozwcp.poll.XXXXXX to be updated.
This file seems to hold al modules and connections but no idea what is generating this file.
- Egregius
Owzcp creates and updates it.
Think you may even delete it, it will be created again when opening ozwcp.
Gravityz
tried it.
when i delete the file it is not recreated when i open open zwave control panel
what is really weird is that everything works perfectly with good networking coverage.
the modules show up in the statistics section but not in de devices section of open zwave control panel.
- Egregius
Why make a problem of it then? If everything works... Most of the stuff you can do in OZWCP is also in Domoticz available.
Gravityz
you are partly right.
indeed everything is working but sometimes when a certain module does not have a connection with it's neighbor(after reboot or stopping/starting aeonstick) i would like to go to that module and choose"update neighbors"
since 2 modules do not show up i can not force this on those modules
