[MyDomoAtHome] Support thread
- epierre
Re: [MyDomoAtHome] Support thread
so bad... I will try to downgrade to 0.10 but I *fear* it won't work in 0.10 ...
yes I stopped support for 0.10 some time ago as it was so old... sorry ...
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
kubrik
- Domoticz version: 2020.2
but nothing works to 0.10??
Could i test it? :/
Ubuntu 20.04 on ACEPC AK1 (previously RPi3b+)
Z-Stick Gen5, RFXtrx433E, Philips HUE Bridge, Yeelight, ESP8266 NodeMCU, Broadlink RM
dZvents, bash, php, Node-RED
- jumbotroll
Could i test it? :/
node_88f6281-6.0_0.12.2-6.spk
www.jadahl.com/testbuild/node_88f6281-6.0_0.12.2-6.spk
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
kubrik
Hi @jumbotroll
I've installed your spk but...
- mdah still showing the same thing...it needs v4
- installed version of node shows -6 - in terminal i get this:
root@DiskStation:~# npm
Illegal instruction (core dumped)
root@DiskStation:~# node -v
-ash: /usr/local/bin/node: No such file or directory
- jumbotroll
Ok, it was only a test, maybe it's not working.
you can try to type /usr/local/bin/node ./node -v
or
sudo node
or
sudo node
Jumbotroll
Jumbotroll
kubrik
mmmm a good new...
root@DiskStation:~# /usr/bin/node -v
v0.12.2
i try to put it on path...let me try
v0.12.2
kubrik
mmm bad news...
admin@DiskStation:~$ sudo node
Illegal instruction
admin@DiskStation:~$ node -v
v0.12.2
admin@DiskStation:~$ sudo -i
Illegal instruction
v0.12.2
- jumbotroll
Sorry to say, but your NAS is not supporting new compiler.When I try to compile Node version 4.x i get: WARNING: C++ compiler too old, need g++ 4.8
Your NAS is using g++ 4.6.
Jumbotroll
Jumbotroll
kubrik
but mdah can't quite run with 0.10 ?
- epierre
no, at one time this old version is not good anymore... and nodejs.org has dropped all packages for arm5, you shoult try arm6 but I cannot guarantee anything...
this is why for old PI I propose a nodejs for their arch:
nodejs_4.4.2_armhf.deb
npm_2.14.7_armhf.deb
in last case maybe you could try to extract it from my archives here : http://www.e-nef.com/domoticz/mdah/
nickgosling
Hi. I have searched the forum for hours.
I can't complete the install. I get stuck on the install the software Debian package. How do I run this.
wget -qO - http://www.e-nef.com/domoticz/mdah/gpg.key | sudo apt-key add -
sudo vi /etc/apt/sources.list
Is this 3 separate commands to run. ?
I have clearly done something wrong because it says malformed line 4 in sources list & the list of sources could not be read when I run the update command on the next line.
I m running a Pi model b
nickgosling
Ignore the post above. I finally got it all working.
I am now trying to setup imperihome for external access and do not know where to start.
Do I need to setup a nginx proxy or can I just port forward like in domoticz.
Regards.
Regards.
- epierre
you can do a simple forward to start, I recommend you add a login/pass in the MDAH config file if you do this way.nickgosling wrote:Ignore the post above. I finally got it all working.
- epierre
@kubrik nodejs for armv6l works fine on armv5 (but not armv7l) try this wayepierre wrote:no, at one time this old version is not good anymore... and nodejs.org has dropped all packages for arm5, you shoult try arm6 but I cannot guarantee anything...
nickgosling
Great. Thanks Epierre. I'll give that a go when I get home. Was delighted to get it working at all. It turned out that the "-" was different. So when I cut and pasted the code I got it working.
Sent from my Nexus 5X using Tapatalk
Rena
- Domoticz version: V 3.8153
Running a Rasp 2 for a year with Domoticz and it works fine and now it´s time for me to install imperihome. I´m not a Rasp-expert so first of all a simple question.
How do I change directory so I can go to /etc/mydomoathome/ from the putty terminal? "Cd" doesn´t work, why?
I would like to edit the config-file in mydomoathome diretory with nano.
I have tried to edit the file via Filezilla but that´s not the correct way.
I only have one user on my Rasp, it´s the "pi" user.
- epierre
just do :
nano /etc/mydomoathome/config.json
unix is case sensitive, so cd is cd not Cd
sorampage
- Domoticz version: LastStab
Hi All,
Salut pierre,
Any new's for this problem ? I use a selector with http request for IR climatisation controler.
When i use the selector from domoticz, all is ok. But when i use the same selector from ImperiHome, the same request is sent ... OFF ... always, for any level selector.
Salut pierre,
antares
Hello sorampage,sorampage wrote:I use a selector with http request for IR climatisation controler.
what do you use as AC controller, if I may kindly ask? I have a ZXT-120, but I cannot control my Mitsubishi AC with it. Perhaps yours is a better one and worth a try.
Thx.
sorampage
You can try with an Orvibo AllOne.antares wrote:Hello sorampage,sorampage wrote:I use a selector with http request for IR climatisation controler.
Thx.
http://easydomoticz.com/forum/viewtopic.php?t=2406
