safi78
Posts: 204 Joined: Thursday 05 September 2013 15:39
Domoticz version: LastBeta
Post
by safi78 » Sunday 23 October 2016 19:02
@Derik:
I realised the package has different names, and maybe its even added in the latest distro's only, I don't know.
@hourly runs every xx:00 if I recall correctly, not sure though.
Glad your're happy with it
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
Derik
Posts: 1605 Joined: Friday 18 October 2013 23:33
Post
by Derik » Sunday 23 October 2016 19:08
emme wrote: low ping means fast response.... so it's good
high ping means slow response... that' bad
Watch out the unit: normally it's ms-->milliseconds
What's a normal/good ping?
safi78
Post
by safi78 » Sunday 23 October 2016 19:11
The lower the better. Here's my graph, lowest I got was 25'ish (on cablemodem)
Screen Shot 2016-10-23 at 19.09.29.png (292.29 KiB) Viewed 3790 times
I eventually found out my problem so, the very high pings are either other stuff that's going on (downloading stuff with sabnzbd full throttle) or my connection with my cable modem and switch flappy (probably the auto-negiotation about duplex / speed etc going haywire). Still have to fix that, but TP-link doesn't offer a lot of Mac-software to manage stuff
regards!
Derik
Post
by Derik » Sunday 23 October 2016 19:23
mmm
Hope this "garbage " give no trouble...
I mean the Json files
Or i there something that i do wrong ...
This going to kill my sd ...[ after a few months .]
safi78
Post
by safi78 » Sunday 23 October 2016 19:26
hmm i have the same thing, even with the 'wget -q' and redirect to /dev/null etc. weird. gotto look into that.
somewhat reassuring, I think I'm using my SSD for about 2 years now with a lot of scripting, testing, trial and error, etc and it's still fine.
Derik
Post
by Derik » Sunday 23 October 2016 19:31
safi78 wrote: hmm i have the same thing, even with the 'wget -q' and redirect to /dev/null etc. weird. gotto look into that.
Ok like to hear from you when you think you have a solution, i will test
My sd is stable ony this stuff is not the best option in that place...
When domoticz kills... some people here @ home get nervous..
safi78
Post
by safi78 » Sunday 23 October 2016 19:34
backup, backup backup
Anyway, you can always create a 'ram-drive' to redirect this stuff to? Saves you disk-trashing
Derik
Post
by Derik » Sunday 23 October 2016 20:05
safi78 wrote: backup, backup backup
Backup is not the problem....
0 1 * * * sudo ~/domoticz/scripts/domoticz_backup.sh
5 1 * * 6 sudo ~/domoticz/scripts/scripts_backup.sh
10 1 * * 6 sudo ~/domoticz/scripts/domoticz_map_backup.sh
1 1 1 * * sudo ~/domoticz/scripts/raspberry_backup.sh
Only everytime the work/time...
And Domoticz is going so fast that i do not every time how anything is working..
1 person says to me... when you can hold your card clean why don;t you do that
geho
Posts: 13 Joined: Thursday 08 August 2013 22:30
Post
by geho » Sunday 23 October 2016 20:07
Try this:
curl -s -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command¶m=udevice&idx=$idxdl&svalue=$download"
curl -s -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command¶m=udevice&idx=$idxul&svalue=$upload"
curl -s -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command¶m=udevice&idx=$idxpng&svalue=$png"
this will not add files
Derik
Post
by Derik » Sunday 23 October 2016 20:15
do i need to replace this.. or add?
geho
Post
by geho » Sunday 23 October 2016 20:23
replace it
safi78
Post
by safi78 » Sunday 23 October 2016 20:25
@Derik: I've been running beta since the beginning, never had any problems. A quick reinstall, yes, but restoring the db / scripts etc gets me up-and-running in an hour.
And, I see you are Dutch as well, so you can have a new SSD within 24 hours with BOL or CoolBlue
@geho: Thanks a bundle! Added to original post.
Derik
Post
by Derik » Sunday 23 October 2016 20:38
pi@raspberrypi ~/domoticz/scripts $ ./speedtest.sh
ping = 37.035 ms
download = 33.04 Mbps
upload = 9.32 Mbps
HTTP/1.1 200 OK
Content-Length: 24
Content-Type: application/json;charset=UTF-8
Cache-Control: no-cache
Pragma: no-cache
Access-Control-Allow-Origin: *
"status" : "ERR"
HTTP/1.1 200 OK
Content-Length: 24
Pragma: no-cache
"status" : "ERR"
HTTP/1.1 200 OK
Content-Length: 24
Pragma: no-cache
"status" : "ERR"
Got some errors.. With the new curl..
safi78
Post
by safi78 » Sunday 23 October 2016 20:46
Works fine here. What did you put in your script?
Derik
Post
by Derik » Sunday 23 October 2016 21:00
#!/bin/bash
#setup
host=192.168.5.75
port=8081
username=LOGIN
password=WW
pingidx=4427
downloadidx=4426
uploadidx=4425
# no need to edit
speedtest-cli --simple > output.txt
ping=$(cat output.txt | sed -ne 's/^Ping: \([0-9]*\.[0-9]*\).*/\1/p')
download=$(cat output.txt | sed -ne 's/^Download: \([0-9]*\.[0-9]*\).*/\1/p')
upload=$(cat output.txt | sed -ne 's/^Upload: \([0-9]*\.[0-9]*\).*/\1/p')
#output if you run it manually
echo "ping = $ping ms"
echo "download = $download Mbps"
echo "upload = $upload Mbps"
Sorry i am not sooooo smart//..
safi78
Post
by safi78 » Sunday 23 October 2016 21:18
Not sure, but didn't you forget the $username & $password like so:
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$pingidx&svalue=$ping"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$downloadidx&svalue=$download"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$uploadidx&svalue=$upload"
safi78
Post
by safi78 » Sunday 23 October 2016 21:21
And seriously, do you have like 4000+ devices in your domoticz history?
Derik
Post
by Derik » Sunday 23 October 2016 22:02
Dear Safi,
looks working @ my crontab time.. without garbage in my sd.. [ love your great work ]
See tomorrow, how his is working
And yes my history is real great.... the reason my complicated Zwave network....
did open new sensors for long time to see my new devices.
Then i delete them all, when i get my new devices..
Did this servile times.....
And Domoticz is still counting...
Only working like a rocket....
Thanks!!
Derik
Post
by Derik » Monday 24 October 2016 19:31
Thanks again
Works great without garbage
manjh
Posts: 859 Joined: Saturday 27 February 2016 12:49
Post
by manjh » Monday 24 October 2016 21:42
jumbotroll wrote: manjh wrote: This is great for the R-Pi, but is there an alternative for a Windows based server?
On windows 10 it's working here.
Install python 3.5.2 from
https://www.python.org/downloads/
Open cmd as Administrator and type: pip install speedtest-cli
Then you can type: speedtest
I installed it and ran an admin-cmd. But PIP is not recognized as command or program...
In which directory does Python install? I can't find anything that looks recognizable!
Edit: never mind, I found the directory and was able to install the speedtest package, and run the speedtest manually.
manjh on Monday 24 October 2016 21:47, edited 1 time in total.
Hans
