Run Terminal Commands on Request
simon_rb
Post by simon_rb »
I have tried to search for this however I don't quite know how to word it. I'm installing https://www.npmjs.com/package/ps4-waker to wake my PS4. Just trying to work out how Domoticz could execute the wake and suspend commands.. Hope to have a dummy switch which will call a script to execute but I have no idea how to do that. Domoticz and ps4-wakes are running on the same raspberry pi.
Thank you
oliviers
Domoticz version: Stable
Re: Run Terminal Commands on Request
Post by oliviers »
I believe this should do it : (assuming you're on Linux):
1. Write a simple bash script like this one:
#!/bin/bash
# Start my PS4
ps4-waker [options] > /dev/null &
The & at the end ensures that the script won't "hang" if the command takes time to execute. Domoticz doesn't like long-running scripts
2. Save it as start_ps4.sh in /home/pi/domoticz/scripts
3. Give it execution rights (chmod)
4. In your dummy script configuration, in "Action on", point to your script:
script:///home/pi/domoticz/scripts/start_ps4.sh
That's it ...
Oliviers
Paris area
Raspberry Pi 4 - RFXComm 433 - IrTrans - Zwave
simon_rb
Post by simon_rb »
Oliviers,
Worked great! Thanks :-)
McJohn
Post by McJohn »
Can anyone tell me why this script is working perfectly in the terminal but not with Domoticz?
#!/bin/sh
xscreensaver-command -deactivate > /dev/null &
Path to the script from Domoticz:
///home/pi/domoticz/scripts/xscreensaverdeactivate.sh
Script is running within Domoticz but nothing happened:
2019-05-30 14:50:03.468 Status: Executing script: ///home/pi/domoticz/scripts/xscreensaverdeactivate.sh
Thanks for the help!
PS: the script has all rights for everyone to read and write.
McJohn wrote: Thursday 30 May 2019 14:51 Can anyone tell me why this script is working perfectly in the terminal but not with Domoticz?
#!/bin/sh
Can you try to execute the script as the same user as you use for domoticz ? The script may be accessed by every user but it could well be that the commands inside are not.
McJohn
Post by McJohn »
Thanks for your feedback!
We use different other .sh scripts and they are working well with Domoticz.
This is the first one with a terminal command.
Is it possible to edit the script that it could be fired by everyone?
What is the default user for Domoticz?
Thanks for your help.
McJohn wrote: Thursday 30 May 2019 22:55 Is it possible to edit the script that it could be fired by everyone?
You stated that the script can be access for read / write by everyone. Is that also true for executing the script ?
identify the domoticz user by the CLI command
ps -ef | grep domoticz
If you need the commands inside the script to be processed by the domoticz user the you could try to put a
sudo <space>
in front of the failing commands in the script.
McJohn
Post by McJohn »
Thanks for your tips & tricks.
I placed a sudo command in the first line into the script.
Nothing changed, it won’t work.
When I run the script (with the sudo command in it) remote from an ssh session, I got an error:
No protocol specified
Without the sudo command in the script it works perfectly with the SSH session; remote the Raspberry Screen wakes up!
The script has all rights for everyone, also for executing the script.
See screendump.
gives:
root 657 1 8 mei30 ? 01:30:39 /home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443
pi 8984 8790 0 10:03 pts/1 00:00:00 grep domoticz
So, with a remote session, with user John, the script works perfectly:
pi@John:~$ /home/pi/domoticz/scripts/xscreensaverdeactivate.sh
Why won’t it work with Domoticz?
Screen Shot 2019-05-31 at 10.12.26.png (166.14 KiB) Viewed 2409 times
So domoticz runs as root and root cannot succesfully executes the command.
So try something with runuser or the likes.
Google for the exact syntax.
I am not at home so limited access to Linux system.
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
McJohn
Post by McJohn »
Thanks for your time.
I’m not an unix expert. I tried something like this:
I added into the script:
runuser
gives this result (from an ssh session command to the script);
runuser: ongeldige optie -- 'd'
When I tried into the script:
runuser -u
gives this:
su -c
gives this:
su: dient uitgevoerd te worden vanaf een terminal
Sorry.
McJohn wrote: Friday 31 May 2019 12:33 When I tried into the script ...
Can you try with this
#!/bin/sh
runuser -l John -c 'xscreensaver-command -deactivate' 2>&1 > /tmp/xscreensaver-command.out &
McJohn
Post by McJohn »
Thanks for the help, I appreciate that.
I did what you asked and edit the script.
Then I tested with an ssh session:
With user John in the script:
It says:
pi@John:~$ runuser: user John does not exist
With user pi in the script:
runuser: may not be used by non-root users
With user root in the script:
It’s driving me crazy….
McJohn
Post by McJohn »
YESSS!!! It’s working!
I think with the remote ssh terminal session the rights won't accept an action locally from user "pi" (the owner of the script, see above screen dump).
BUT; with owner “pi” in the script it’s working perfectly directly from Domoticz at the Raspberry.
Now, with a specific Domoticz action we can wake up the Raspberry screen.
Thank you very much for the giant hint! :D
