blockly: user variable set for time, don't work?
Evelen
Domoticz version: 2.4538
Post by Evelen »
Ok, i want to set my user varibale to "timer_on" for 3 minutes when a lamp is on, than back, but it don't work, the variable don't change to "timer_on".
why?
Evelen
Re: blockly: user variable set for time, don't work?
Post by Evelen »
bumping
Evelen
Post by Evelen »
bump
Evelen
Post by Evelen »
bump
Philosifer
Domoticz version: 2.4223
Post by Philosifer »
I've been struggling to get events that mention only user variables to trigger at all.
Event that check changes of system states (e.g. security status) seem ok but if they only have user variables in the if clause they seem not to run.
Maybe add a write to the debug log in your do clause to see if your event is running or not.
krollebol
Post by krollebol »
Indeed, I've also noticed that an event with only a user variable in the 'if' doesn't work. But you could probably add an AND with an additional condition that's always true, such as "time > 00:00". Then the event will run every minute. Of course that's not useful if you want to trigger immediately when a user variable changes.
Also setting a user variable for X minutes doesn't work. The value will never be set. Probably this set for X minutes only works for toggling a switch :-(
sorampage
Domoticz version: LastStab
Post by sorampage »
Indeed, an event does not start on the simple change of state of a variable. And this can be a problem ...
sorampage
Post by sorampage »
Evelen wrote:Ok, i want to set my user varibale to "timer_on" for 3 minutes when a lamp is on, than back, but it don't work, the variable don't change to "timer_on".
why?
You can use hidden dummy switch .. :)
Evelen
Post by Evelen »
why?
have already solved the problem, but just wondering, what is a hidden dummy?
