Ok, i want to set my user varibale to "timer_on" for 3 minutes when a lamp is on, than back, but it don't work, the variable don't change to "timer_on".
why?
blockly: user variable set for time, don't work?
Philosifer
- Domoticz version: 2.4223
Re: blockly: user variable set for time, don't work?
I've been struggling to get events that mention only user variables to trigger at all.
Event that check changes of system states (e.g. security status) seem ok but if they only have user variables in the if clause they seem not to run.
Maybe add a write to the debug log in your do clause to see if your event is running or not.
krollebol
Indeed, I've also noticed that an event with only a user variable in the 'if' doesn't work. But you could probably add an AND with an additional condition that's always true, such as "time > 00:00". Then the event will run every minute. Of course that's not useful if you want to trigger immediately when a user variable changes.
Also setting a user variable for X minutes doesn't work. The value will never be set. Probably this set for X minutes only works for toggling a switch
sorampage
- Domoticz version: LastStab
Indeed, an event does not start on the simple change of state of a variable. And this can be a problem ...
sorampage
Evelen wrote:Ok, i want to set my user varibale to "timer_on" for 3 minutes when a lamp is on, than back, but it don't work, the variable don't change to "timer_on".
why?
You can use hidden dummy switch ..
Evelen
- Domoticz version: 2.4538
have already solved the problem, but just wondering, what is a hidden dummy?sorampage wrote:Evelen wrote:Ok, i want to set my user varibale to "timer_on" for 3 minutes when a lamp is on, than back, but it don't work, the variable don't change to "timer_on".
why?
