IR transmitter for wacume vacuum cleaner
Evelen
Domoticz version: 2.4538
Post by Evelen »
Hi.
I want to start/stop my wacuum cleaner, but it is a old non-smart device, so I need to use IR.
some suggestions for an IR transmitter that can work for this?
any suggestions for an IR transmitter that can work for this? ACAP (as cheaply as possible)
I have interface for Z-Wave (UZB1) and 433MHz (RFXtrx433E)
(cleaner: viewtopic.php?f=38&t=9654 )
Raspberry Piet
Re: IR transmitter for wacume vacuum cleaner
Post by Raspberry Piet »
Evelen wrote: any suggestions for an IR transmitter that can work for this? ACAP (as cheaply as possible)
maybe cheapest solution: LIRC
I used to control my Roomba (IR) with LIRC installed on my RPI.
Evelen
Post by Evelen »
mhm, than I need a RPi.
Is it advanced to set up, and where can I find guides?
also: looks after most complete solutions
relly123
Post by relly123 »
Evelen wrote:Hi.
I want to start/stop my Carpet Cleaning Kamloops, but it is a old non-smart device, so I need to use IR.
Can you please tell me which IR sensor is best suited for wacume vacuum cleaner?
Evelen
Post by Evelen »
relly123 wrote:
Evelen wrote:Hi.
I don't know. Don't have any yet
LouiS22
Post by LouiS22 »
Evelen wrote:
relly123 wrote:
Evelen wrote:Hi.
The cheapest solution would be mysensors - which then you can use for other projects as well. First you have to build a gateway, then an ir transmitter. Take a look on www.mysensors.org, the instructions are clear, and you can find links for all the equipment you'll need.
bend94
Post by bend94 »
hi Raspberry Piet
On my side i have rpi and lirc installed. I would like to manage my irobot 700 series with IR led.
Please help me, how to use lirc with irobot ?
Can you tell me where to connect ir led and how ?
