Hi.
I want to start/stop my wacuum cleaner, but it is a old non-smart device, so I need to use IR.
some suggestions for an IR transmitter that can work for this?
any suggestions for an IR transmitter that can work for this? ACAP (as cheaply as possible)
I have interface for Z-Wave (UZB1) and 433MHz (RFXtrx433E)
(cleaner: viewtopic.php?f=38&t=9654 )
IR transmitter for wacume vacuum cleaner
Raspberry Piet
Re: IR transmitter for wacume vacuum cleaner
maybe cheapest solution: LIRCEvelen wrote: any suggestions for an IR transmitter that can work for this? ACAP (as cheaply as possible)
I used to control my Roomba (IR) with LIRC installed on my RPI.
Evelen
- Domoticz version: 2.4538
mhm, than I need a RPi.
Is it advanced to set up, and where can I find guides?
also: looks after most complete solutions
Can you please tell me which IR sensor is best suited for wacume vacuum cleaner?Evelen wrote:Hi.
I want to start/stop my Carpet Cleaning Kamloops, but it is a old non-smart device, so I need to use IR.
Evelen
I don't know. Don't have any yetrelly123 wrote:Can you please tell me which IR sensor is best suited for wacume vacuum cleaner?Evelen wrote:Hi.
- LouiS22
The cheapest solution would be mysensors - which then you can use for other projects as well. First you have to build a gateway, then an ir transmitter. Take a look on www.mysensors.org, the instructions are clear, and you can find links for all the equipment you'll need.Evelen wrote:I don't know. Don't have any yetrelly123 wrote:Can you please tell me which IR sensor is best suited for wacume vacuum cleaner?Evelen wrote:Hi.
bend94
hi Raspberry Piet
On my side i have rpi and lirc installed. I would like to manage my irobot 700 series with IR led.
Please help me, how to use lirc with irobot ?
Can you tell me where to connect ir led and how ?
