Is there a way to set the name like '(Auto) Alarm type' or '(Auto) Emergency' for the new included devices? '(Auto) ' = then you know is auto generated or something....
When I include a new node there can be 8 devices be generated but they all look the same.
In the logs when you include a new node you see the following:
2015-12-30 10:34:36.379 OpenZWave: New Node added. HomeID: 3887305232, NodeID: 25 (0x19)
2015-12-30 10:34:36.609 OpenZWave: Value_Added: Node: 25 (0x19), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2015-12-30 10:34:36.634 OpenZWave: Value_Added: Node: 25 (0x19), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2015-12-30 10:34:36.634 OpenZWave: Value_Added: Node: 25 (0x19), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2015-12-30 10:34:36.637 OpenZWave: Value_Added: Node: 25 (0x19), CommandClass: ALARM, Label: Alarm Level, Instance: 1
<snip>
2015-12-30 10:34:49.680 OpenZWave: Value_Added: Node: 25 (0x19), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2015-12-30 10:34:49.681 OpenZWave: Value_Added: Node: 25 (0x19), CommandClass: ALARM, Label: Burglar, Instance: 1
2015-12-30 10:34:49.689 OpenZWave: Value_Added: Node: 25 (0x19), CommandClass: ALARM, Label: Emergency, Instance: 1
2015-12-30 10:34:49.693 OpenZWave: Value_Added: Node: 25 (0x19), CommandClass: ALARM, Label: Appliance, Instance: 1
Or is there another way I can see which of the devices I need to switch on to turn on/off my siren? Thanks!!
2nd question:
Is it also possible to print the name of the device into the 'Setup'/'Devices' page? See column name in the screenshot below: But this name is not used in the page 'Setup' / 'Devices'. I know it's the ID but I think it will have a better user experience, at least if you use this package for the first time. Since I've a bit experience and I know more about it I know how to find out.
Keep up the good work! It's a very nice solution!
