Setting EvoTouch in Blockly events ?
westd001
Post by westd001 »
I am using a EvoTouch Color with an HGI80 for a few weeks. It's working fine. I try to set the modus of my EvoTouch via a Blockly Event but that won't work. The EvoTouch modes are not available in the Blockly events. I want to set my Thermostat in modus : Away when nobody is home.
Somebody has tried this before with a virtual switch and json commands for example, activating the switch with a blockly event that also tests if somebody is at home or is there another solution ?
Egregius
Domoticz version: v2024.7
Re: Setting EvoTouch in Blockly events ?
Post by Egregius »
Lookup the command in the network view (developer mode) of your browser and call it by url ;)
westd001
Post by westd001 »
Thank you for this info, didn't know it was so simple, never used the network view before !!
StanHD
Post by StanHD »
Also have a look at the end of the Wiki, it gives the Json comand string for setting the modes. This can be used with a virtual switch and Blockly.
https://www.domoticz.com/wiki/Evohome
Python:- Broadlink RM2, Sonos
