I am using a EvoTouch Color with an HGI80 for a few weeks. It's working fine. I try to set the modus of my EvoTouch via a Blockly Event but that won't work. The EvoTouch modes are not available in the Blockly events. I want to set my Thermostat in modus : Away when nobody is home.
Somebody has tried this before with a virtual switch and json commands for example, activating the switch with a blockly event that also tests if somebody is at home or is there another solution ?
Setting EvoTouch in Blockly events ?
- Egregius
- Domoticz version: v2024.7
Re: Setting EvoTouch in Blockly events ?
Lookup the command in the network view (developer mode) of your browser and call it by url
westd001
Thank you for this info, didn't know it was so simple, never used the network view before !!
- StanHD
Also have a look at the end of the Wiki, it gives the Json comand string for setting the modes. This can be used with a virtual switch and Blockly.
https://www.domoticz.com/wiki/Evohome
Python:- Broadlink RM2, Sonos
