Hi everyone
few month ago I requested a trick to show all uervariables in a single page instead of having them 10 by 10 (and there is no option to show more)
The topic here was locked viewtopic.php?f=31&t=6065 considered as solved, but the proposed solution was not tested ! simply as it's not possible !
the proposed solution was to replace the following code in uservariables.html file
"iDisplayLength" : 10,
'bLengthChange': false,
but this code dosen't exist in the mentionned file !!
Is someone able to help on this question ?
thank you in advance for your help !
cheers
Possibility to show all uservariables in 1 single page
sebitop
Last edited by sebitop on Saturday 28 November 2015 22:33, edited 1 time in total.
domoticz on Raspberry Pi + RFXcom LAN moded
Blyss / DI.O / ESP / Arduino
- Egregius
- Domoticz version: v2024.7
Re: Possibility to show all uservariables in 1 single page
look in www/app/UservariablesController.js
Or use a good text editor to look in all files and subfolders after iDisplayLength or bLenghtChange
sebitop
thanks egrenius
the code is located in this file you're true
so in fact just need to replace
by
"iDisplayLength" : 100,
'bLengthChange': true,
thansk again for your help
cheers
by
cheers
- gizmocuz
in a next update, i will add a dropdown on the top left of the table, where you can select to display 25, 50, 100 or all items
- Egregius
While you are at it, could you also do that for the Zwave Groups & network view?
sebitop
Brilliant,
thanks gizmo
thanks gizmo
Users browsing this forum: Ahrefs [Bot] and 1 guest
