Possibility to show all uservariables in 1 single page
sebitop
Post by sebitop »
Hi everyone
few month ago I requested a trick to show all uervariables in a single page instead of having them 10 by 10 (and there is no option to show more)
The topic here was locked viewtopic.php?f=31&t=6065 considered as solved, but the proposed solution was not tested ! simply as it's not possible !
the proposed solution was to replace the following code in uservariables.html file
"iDisplayLength" : 10,
'bLengthChange': false,
but this code dosen't exist in the mentionned file !!
Is someone able to help on this question ?
thank you in advance for your help !
cheers
Last edited by sebitop on Saturday 28 November 2015 22:33, edited 1 time in total.
domoticz on Raspberry Pi + RFXcom LAN moded
Blyss / DI.O / ESP / Arduino
Egregius
Domoticz version: v2024.7
Re: Possibility to show all uservariables in 1 single page
Post by Egregius »
look in www/app/UservariablesController.js
Or use a good text editor to look in all files and subfolders after iDisplayLength or bLenghtChange
sebitop
Post by sebitop »
thanks egrenius
the code is located in this file you're true
so in fact just need to replace
by
"iDisplayLength" : 100,
'bLengthChange': true,
thansk again for your help
cheers
gizmocuz
Post by gizmocuz »
in a next update, i will add a dropdown on the top left of the table, where you can select to display 25, 50, 100 or all items
Egregius
Post by Egregius »
While you are at it, could you also do that for the Zwave Groups & network view? :mrgreen:
sebitop
Post by sebitop »
Brilliant,
thanks gizmo
