Execute Batch file on remote PC
Thomasdc
Post by Thomasdc »
Hi everybody!
I run Domoticz on a Raspberry pi
I wondered if it was possible to execute a Batch file on a windows 10 pc with domoticz on the Raspberry pi
(i saw that it was possible to shut down a pc remotly, so i was hoping that maybe executing a batch file on a remote pc would also be possible)
the way i see it there are 2 "scenario's"
1) The code is in a batch file on the pc and the Rpi with domoticz on it send a command to the pc to execute the batch file
2) The code is sent from the Rpi to the Remote PC (some kind of SSH connection? )
I don't know if any of those 2 are possible, but it would help me a lot!
Raspberry Piet
Re: Execute Batch file on remote PC
Post by Raspberry Piet »
Hi Thomas,
That would be possible by using scenario nr 1.
I use Evenghost with AutoRemote plugin to achieve this.
But i'm sure there is also another plugin for Eventghost that could do the same.
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
You can also install Domoticz on your Windows PC and connect both Domoticz to each other :)
Thomasdc
Post by Thomasdc »
Raspberry Piet wrote:Hi Thomas,
has anyone experience with this but with Domoticz instead of tasker?
bizziebis wrote:You can also install Domoticz on your Windows PC and connect both Domoticz to each other :)
i thought of this also but i rather not instal domoticz for something simple like executing some code once maybe twice a day.
mostly i would like a "scenario 2" manner to do this, this way i can program all the code on 1 place (the RPI) and if i ever replace my computers it all keeps working with little modification (permissions settings or something )
Raspberry Piet
I use it with the AutoRemote plugin like this:
RPI CLI:
curl -m 1 "http://192.168.1.10:1817/?message=ARPAR=:=ARCOMM"
Evenghost:
Then add macro:
Thomasdc
Post by Thomasdc »
This works great!!! so easy to use! the possibilities are amazing!
Big thanks for this suggestion Raspberry Piet!
Raspberry Piet
Thomasdc wrote:This works great!!! so easy to use! the possibilities are amazing!
Yes, Eventghost is amazing. (it's like a sort of Tasker for Windows) ;)
Many useful plugins available also!
AutoRemote is my favorite. Works with EventGhost, Tasker and Linux here.
Here is my simple AutoRemote bash script i use to send messages to EventGhost and my android smartphone:
#!/bin/sh
ARPAR=$1  # %arpar(): array with all the parameters at the left of =:=
ARCOMM=$2  # %arcomm: all the words at the right of =:= (if only one =:= is present)
TTL=$3 # Time in seconds AutoRemote will try to deliver the message for before giving up
# Settings
KEY="xxxxxx" #SMARTPHONE
EG_IP="192.168.1.10"
EG_PORT="1817"
# SEND AUTOREMOTE MESSAGE TO SMARTPHONE (WAN)
string="https://autoremotejoaomgcd.appspot.com/sendmessage?key=$KEY&message=$ARPAR=:=$ARCOMM&ttl=$TTL"
string2=$( printf "%s\n" "$string" | sed 's/ /%20/g' )
echo $string2
curl "$string2"
# SEND AUTOREMOTE MESSAGE TO EVENTGHOST (LAN)
string="http://$EG_IP:$EG_PORT/?message=$ARPAR=:=$ARCOMM"
echo $string2
curl -m 1 "$string2"
Example:
/home/pi/domoticz/scripts/bash/AutoRemote.sh "CMD" "DOORBELL" "10"
Sends this message to EvenGhost (which executes VLC opening ipcam stream), ...
endless possibilities! :ugeek:
