Hi everybody!
I run Domoticz on a Raspberry pi
I wondered if it was possible to execute a Batch file on a windows 10 pc with domoticz on the Raspberry pi
(i saw that it was possible to shut down a pc remotly, so i was hoping that maybe executing a batch file on a remote pc would also be possible)
the way i see it there are 2 "scenario's"
1) The code is in a batch file on the pc and the Rpi with domoticz on it send a command to the pc to execute the batch file
2) The code is sent from the Rpi to the Remote PC (some kind of SSH connection? )
I don't know if any of those 2 are possible, but it would help me a lot!
Execute Batch file on remote PC
Raspberry Piet
Re: Execute Batch file on remote PC
Hi Thomas,
That would be possible by using scenario nr 1.
I use Evenghost with AutoRemote plugin to achieve this.
But i'm sure there is also another plugin for Eventghost that could do the same.
- bizziebis
- Domoticz version: 3.8805
You can also install Domoticz on your Windows PC and connect both Domoticz to each other
Thomasdc
Raspberry Piet wrote:Hi Thomas,
has anyone experience with this but with Domoticz instead of tasker?
bizziebis wrote:You can also install Domoticz on your Windows PC and connect both Domoticz to each other
i thought of this also but i rather not instal domoticz for something simple like executing some code once maybe twice a day.
mostly i would like a "scenario 2" manner to do this, this way i can program all the code on 1 place (the RPI) and if i ever replace my computers it all keeps working with little modification (permissions settings or something )
Raspberry Piet
I use it with the AutoRemote plugin like this:Thomasdc wrote:Raspberry Piet wrote:Hi Thomas,
RPI CLI:
curl -m 1 "http://192.168.1.10:1817/?message=ARPAR=:=ARCOMM"
Then add macro:
Thomasdc
This works great!!! so easy to use! the possibilities are amazing!
Big thanks for this suggestion Raspberry Piet!
Raspberry Piet
Yes, Eventghost is amazing. (it's like a sort of Tasker for Windows)Thomasdc wrote:This works great!!! so easy to use! the possibilities are amazing!
Many useful plugins available also!
AutoRemote is my favorite. Works with EventGhost, Tasker and Linux here.
Here is my simple AutoRemote bash script i use to send messages to EventGhost and my android smartphone:
- Spoiler: show
/home/pi/domoticz/scripts/bash/AutoRemote.sh "CMD" "DOORBELL" "10"endless possibilities!
