Fibaro Switch FGS222 - turns off after 20 seconds
Twan
Domoticz version: 3.5877
Post by Twan »
Hi.
I have a FIBARO System FGS222 Double Relay Switch 2x1.5kW.
But I can not get it to be turned on for longer then 20 seconds.
What could cause this behaviour?
grtz,
Twan
gizmocuz
Re: Fibaro Switch FGS222 - turns off after 20 seconds
Post by gizmocuz »
Hi Twan,
things to check:
- make sure if you edit the switch in domoticz, that you did not specify an off delay value (0=no off delay)
- in the hardware setup of openzwave, select the node and check the configuration, there are settings for an auto off delay here as well:
Parameter No. 3 - Auto off relay after specified time, with the possibility of manual override - immediate Off after button push.
Parameter No. 4 - Auto off for relay 1.
Parameter No. 5 - Auto off for relay 2.
Also make sure there is no more load on the relays then 1.5kW
Twan
Post by Twan »
Setting Parameter 4 and 5 to 0 did the trick.
Sometimes the descriptions with the many parameters can by quite confusing.
grtz,
Twan
This topic can be closed.
gizmocuz
Post by gizmocuz »
Its just in the manual ;)
