Script error blocky, compare number with string
koenjer
Domoticz version: 3.8153
Post by koenjer »
Hi There,
I´m trying to use the second switch input on a Qubino dimmer to work as a secundary switch for my kitchen lights.
In dutch called a `wissel schakeling`.
The problem is that the kitchen light is always dimmed to +/- 50% when on. So the state in Domoticz is not Always "ON" but sometimes
showed as 50%.
When i'm trying this blocky script I get a error.
Error:
Name: Wisselkeuken => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to compare string with number
mrf68
Re: Script error blocky, compare number with string
Post by mrf68 »
Hi koenjer,
try this:
20151109 forum.jpg (18.04 KiB) Viewed 1077 times
EDIT: but I think it won't work as expected. Because when the Wisselschakelaar Keuken is On and you activate the dimmer, the script will turn the light of again. You can probably fix that by setting the Off Delay to let's say 5 seconds, so it will turn off automaticaly. Then you will be able to use the other switch to turn the lights on again.
