Set Temperature using Lua
thebeetleuk
Post by thebeetleuk »
I want to set the temperature of a virtual device using something like...
commandArray['Temperature House'] = tostring(current)
.. which doesn't work. How can I do this without using the IDX?
My Setup: Pi, RFXtrx433, HomeEasy: 13 Dimmers & 4 Sockets, 2 motion-sensors, 3 magnetic switches, 1 OWL Electricity Sensor, 3 Oregon Temp Sensor.
oeildefeu
Domoticz version: 2023.2
Re: Set Temperature using Lua
Post by oeildefeu »
why without IDX ?
Raspberry Pi 3 - Raspbian + Razberry (OpenZwave) + RFXtrx433
thebeetleuk
Because I want to define the dummy temperature device by name (as a variable), and don't want to have to specify the IDX as well.
thebeetleuk
anyone?
zofiel
Post by zofiel »
Think that this option can't be enabled at the moment in lua.
you have to use the idx format
jvdz
Domoticz version: 4.107
Post by jvdz »
This is an example of a script that can retrieve the IDX for a devicename which you then can use to set an device with its IDX:
-- Load necessary Lua libraries
http = require "socket.http";
JSON = require "JSON";
server_url="http://192.168.0.xx:8080"
-- Function to retrieve the IDX for a DeviceName
function GetDeviceIDX(DeviceName)
	-- get device IDX from Domotics
	local DeviceIDX,result,record
	DeviceIDX = 99999
	DeviceURL="type=devices&order=name&used=true"
	t = server_url.."/json.htm?" .. DeviceURL
	jresponse, status = http.request(t)
	decoded_response = JSON:decode(jresponse)
	result = decoded_response['result']
	for i = 1, #result do
		record = result[i]
		if record['Name'] == DeviceName then
			DeviceIDX=record['idx']
			break
	return DeviceIDX
DeviceName="ThermostaatHK"
DeviceIDX = GetDeviceIDX(DeviceName)
if DeviceIDX == 99999 then
	print("  DeviceName "..DeviceName.." not found.")
	print("  DeviceName "..DeviceName.."  DeviceIDX="..DeviceIDX)
The required libraries and how to install can be found in the DTGBOT wiki.
Jos
thebeetleuk
thanks!!
