I want to set the temperature of a virtual device using something like...
commandArray['Temperature House'] = tostring(current)
.. which doesn't work. How can I do this without using the IDX?
Set Temperature using Lua
My Setup: Pi, RFXtrx433, HomeEasy: 13 Dimmers & 4 Sockets, 2 motion-sensors, 3 magnetic switches, 1 OWL Electricity Sensor, 3 Oregon Temp Sensor.
- oeildefeu
- Domoticz version: 2023.2
Re: Set Temperature using Lua
why without IDX ?
Raspberry Pi 3 - Raspbian + Razberry (OpenZwave) + RFXtrx433
Because I want to define the dummy temperature device by name (as a variable), and don't want to have to specify the IDX as well.
anyone?
Think that this option can't be enabled at the moment in lua.
you have to use the idx format
- jvdz
- Domoticz version: 4.107
This is an example of a script that can retrieve the IDX for a devicename which you then can use to set an device with its IDX:
The required libraries and how to install can be found in the DTGBOT wiki.
Jos
-- Load necessary Lua libraries
http = require "socket.http";
JSON = require "JSON";
server_url="http://192.168.0.xx:8080"
-- Function to retrieve the IDX for a DeviceName
function GetDeviceIDX(DeviceName)
-- get device IDX from Domotics
local DeviceIDX,result,record
DeviceIDX = 99999
DeviceURL="type=devices&order=name&used=true"
t = server_url.."/json.htm?" .. DeviceURL
jresponse, status = http.request(t)
decoded_response = JSON:decode(jresponse)
result = decoded_response['result']
for i = 1, #result do
record = result[i]
if record['Name'] == DeviceName then
DeviceIDX=record['idx']
break
return DeviceIDX
DeviceName="ThermostaatHK"
DeviceIDX = GetDeviceIDX(DeviceName)
if DeviceIDX == 99999 then
print(" DeviceName "..DeviceName.." not found.")
print(" DeviceName "..DeviceName.." DeviceIDX="..DeviceIDX)
Jos
thanks!!
