Sorry for the bump, but, nobody an idea about this?
Installed another Qubino double relay, offcourse the same issue.
This is the log for 1 switch:
2015-11-19 16:45:32.314 OpenZWave: Domoticz has send a Switch command! NodeID: 56 (0x38)
2015-11-19 16:45:32.314 (ZWave) Lighting 2 (Keuken)
2015-11-19 16:45:32.597 (ZWave) Lighting 2 (KeukenZolder)
2015-11-19 16:45:33.277 Executing script: /home/pi/domoticz/scripts/domoticz_main
2015-11-19 16:45:33.954 (ZWave) Usage (KeukenZolderUnknown)
2015-11-19 16:45:33.957 (ZWave) Usage (KeukenZolderPower Meter)
2015-11-19 16:45:34.775 Hardware Monitor: Fetching data (System sensors)
2015-11-19 16:45:35.631 Executing script: /home/pi/domoticz/scripts/domoticz_main
2015-11-19 16:45:35.985 (ZWave) Usage (KeukenZolderUnknown)
2015-11-19 16:45:35.988 (ZWave) Usage (KeukenZolderPower Meter)
2015-11-19 16:45:36.197 (ZWave) Usage (KeukenZolderUnknown)
2015-11-19 16:45:36.200 (ZWave) Usage (KeukenZolderPower Meter)
2015-11-19 16:45:36.397 (ZWave) Usage (KeukenZolderUnknown)
2015-11-19 16:45:36.399 (ZWave) Usage (KeukenZolderPower Meter)
2015-11-19 16:45:36.597 (ZWave) Usage (KeukenZolderUnknown)
2015-11-19 16:45:36.600 (ZWave) Usage (KeukenZolderPower Meter)
2015-11-19 16:45:38.568 (ZWave) Usage (KeukenZolderUnknown)
2015-11-19 16:45:38.571 (ZWave) Usage (KeukenZolderPower Meter)
2015-11-19 16:45:38.769 (ZWave) Usage (KeukenZolderUnknown)
2015-11-19 16:45:38.772 (ZWave) Usage (KeukenZolderPower Meter)
2015-11-19 16:45:38.971 (ZWave) Usage (KeukenZolderUnknown)
2015-11-19 16:45:38.975 (ZWave) Usage (KeukenZolderPower Meter)
2015-11-19 16:45:44.551 (ZWave) Usage (KeukenZolderUnknown)
2015-11-19 16:45:44.555 (ZWave) Usage (KeukenZolderPower Meter)
2015-11-19 16:45:44.753 (ZWave) Usage (KeukenZolderUnknown)
2015-11-19 16:45:44.756 (ZWave) Usage (KeukenZolderPower Meter)
2015-11-19 16:45:44.955 (ZWave) Usage (KeukenZolderUnknown)
2015-11-19 16:45:44.958 (ZWave) Usage (KeukenZolderPower Meter)
I notice real latency because of this. Especially when someone enters the hall. Then 2 Qubino's are switched and they both send about 10 power reports for starting the bulb.
If you enter in that moment another room with motion sensor it takes sometimes up to 20 seconds to switch the light on.
I basically don't want any power reports at all from these switches. It are already power saving bulbs or LED so the power consumption doesn't bother me at all.
