Can get the fgsd-002 smoke detector into Domotics
roelfsre
Post by roelfsre »
I'm running a Raspbery PI with the Z-ware module. I just bought a FGSD-002 smoke detector, but it does not appear in Domoticz.
When checking ZWave on port 8083, it does see the smoke detector and I've included it to the network.
How do I get the smoke detector into Domoticz ?
Thank you for helping.
Regards,
René
gizmocuz
Re: Can get the fgsd-002 smoke detector into Domotics
Post by gizmocuz »
you have to use openzwave with your razberry, see wiki/forum/google how to do this
alexsh1
Domoticz version: v3.8975
Post by alexsh1 »
roelfsre wrote:Hello,
Regards,
René
I have FGSD-002 smoke detector working with Domoticz fine (it is seen as "FIBARO System FGSD002 Smoke Sensor"). OZW must be used
roelfsre
Post by roelfsre »
At the moment I can see the smoke detector both ways. The "regular" way and when I use OZW. ( cloned my SD card to test both way's ).
Unfortunately it just sees the smoke detector, but I want to make use of the temperature sensor in the smoke detector. I did not get it to work in both configurations. Is there a way to get this in Domoticz ? I would like to see the temperature log of the smoke detector in Domoticz... .
Thanks again for helping !
Regards,
René
Egregius
Domoticz version: v2024.7
Post by Egregius »
How long did you wait? It takes some time for the temperature to appear.
I have 5 such smokesensors and use all their temperatures.
roelfsre
Post by roelfsre »
Thank you for your reply ! I will do some more tests next weekend !
Thanks again.
roelfsre
Post by roelfsre »
Thank you all, I got it working now. Too much garbage on the SD card from my old configuration. I started from Scratch and now all is working with OpenWave.
assenzuid
Post by assenzuid »
Egregius wrote:How long did you wait? It takes some time for the temperature to appear.
I have also one installed today, but not temp values. How long can it take, running for a few hours now.
Westcott
Post by Westcott »
I changed configuration "21. Temperature report hysteresis:" from 10 to 2 so that it reports every 0.2C change, rather than the default 1.0C
assenzuid
Post by assenzuid »
I have change the setting also, but still after almost 24 hours no temp. data
assenzuid
Post by assenzuid »
I have, after adding the Smoke detector 8 devices, no clue where they all are for but none of the devices is reporting the temperature.
Someone some advise here?
Egregius
Post by Egregius »
You are missing one with id 0901 (where 09 is the node id).
Why? I don't know. I have 6 such smoke detectors wich are mainly used for their superb thermometer (with aeotec z-stick).
assenzuid
Post by assenzuid »
Just performed a fresh install (other SD card), running the latest stable version, I only performed basic configuration settings and it works now.
The Temp sensor is reporting.
The other installation was running with the latest beta version.
barbaar
Post by barbaar »
Looks like I am missing some devices to. What ID will the actual smokedetector have (the one tha will switch on, when the alarm goes off?). I used the units testprogram to test the alarm, but none of my devices reported an On state...
elgarne
Post by elgarne »
I'm also facing the same issue with 5 devices. All of them are working except the temp devices of the smoke detectors. Excluded them then included them back, tried to put them in the frizzer, no effect.
I'd prefer to avoid a fresh install since I have a complete conf.
elgarne
Post by elgarne »
No idea about my issues? These devices are well recognized by jeedom, which excludes hardware issues.
Thanks.
elgarne
Post by elgarne »
Downgraded to the latest stable version (2.3530), same issue.
mvank
Post by mvank »
assenzuid wrote:Just performed a fresh install (other SD card), running the latest stable version, I only performed basic configuration settings and it works now.
Hi all, just started this week with Domoticz.
I run into the same issue as quoted.
bought a RPI and a Fibaro Smoke Detector fgsd-002 and an Aeon Zwave stick GEN5.
Used some manuals online, put the image on the sdcard and all necessary steps.
I was able to add the fgsd-002, and saw 12 device settings. after some playing wanted to reset the temp graphics, but only option (as written online) is to remove the device and add it again. After the fgsd-002 was added again, I only saw 10 device setting, and temp was gone.
resetting controller, resetting fgsd-002, removing all settings from config did not work. Only option what did work was putting the image back on the SD card, resetting fgsd-002, and adding the device again.
As I am testing, it is not a issue, but what if many devices have been connected?
Anyone seen also this issue?
Regards,
Michel
ricorico94
Post by ricorico94 »
I just purchased and added a FGSD-002 : I could add it with no issue, but the temperature sensor is not appearing as for other guys above.
However, if I go into ZWave controller, then into control pannel menu, and if I click on the FGSD-002 device, I can see a field with a temperature properly filled in... so I guess the device is working..
Please help...
Ricorico94
Edit: after some time, maybe also because I pushed the button 3 times to wake it up, the temperature device appeared in the list and seems being updated since then.. Weird..
mvank
Post by mvank »
Still got a strange behavior on my setup.
Reinstalled it with pre-built image, but still no TEMP sensor (like previous post).
In control panel, i can see the temp value, the sensor field is set to off (cannot change it)
Schermafbeelding 2016-02-15 om 12.53.14.png (88.06 KiB) Viewed 4541 times
Try to update the temp frequency, but this stays on 10s. Unable to update the config.
After a manual install, i did not see any changes of, stil no temp node. i installed the beta release and suddenly i noticed the temp sensor as node
Schermafbeelding 2016-02-15 om 13.23.50.png (326.91 KiB) Viewed 4541 times
Only the previous nodes, are still visible. Changing back to stable release, because i could still not adjust the smoke detector config settings, the temp value was still reporting every 5 min. Only during the night it stopped and at random points it is reporting.
Schermafbeelding 2016-02-15 om 12.53.52.png (333.79 KiB) Viewed 4541 times
This is not because of the 1 degree temp change, because from time to time it reports every 5min and sometimes not for a few hours.
anyone seen this?
