How to update RFLink firmware
433Mhz opensource Receiver & Transmitter.
Stuntteam
Post by Stuntteam »
This topic describes an easy method to update the firmware of the RFLink.
Using the RFLink Loader tool:
- Download the latest firmware package from http://sourceforge.net/projects/rflink/ ... urce=files
- Connect the Arduino Mega to a USB port.
- Unpack the zip file to a directory
- Launch the RFLInkLoader.exe program
- Select the file you want to program (which will be the included "rflink.cpp.hex" file)
- Select the serial (USB) port to which the Arduino is connected.
- Hit the "Program" button and wait for the process to finish.
Thats all..
We will try to add firmware updating functionality to Domoticz..
oopee
Domoticz version: 3.x
Re: How to update RFLink firmware
Post by oopee »
Remember that you have to install Arduino usb drivers to get Windows to recognize Arduino board and assign COM port. After that you can use the RFLinkLoader. Drivers are part of the Arduino software package https://www.arduino.cc/en/Main/Software.
oopee
Post by oopee »
And remember to replace /dev/ttyUSB0 with whatever port RFLink is using in your system ;)
remb0
Post by remb0 »
so it's possible to make an sh script.
and make script executable
then a virtual switch which fire that script.
nice ;)
Stuntteam
Post by Stuntteam »
Yes, my rflink loader tool is also using avrdude..
h143
Post by h143 »
can you explane how you do that?
Dlanor
Post by Dlanor »
Stuntteam wrote:This topic describes an easy method to update the firmware of the RFLink.
Thats all..
It works perfectly. Thanks! :D
Domoticz| Zigbee | SONOFF
Derik
Post by Derik »
Great hardware the RFlink
Perhaps a option to upgrade the RFlink like the RFXcom..
L2v2P
Post by L2v2P »
On OS X you can do it as follows:
  1. Download the Arduino App from https://www.arduino.cc and install it.
  2. Open a terminal session.
  3. From the directory where the Arduino App is located run the commands below whereby replacing /dev/cu.usbmodem411 and RFLink_v1-2/RFLink.cpp.hex with your own values.
    Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -v -p atmega2560 -c stk500 -P /dev/cu.usbmodem411 -b 115200 -D -U flash:w:RFLink_v1-2/RFLink.cpp.hex:i -C Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf
remb0
Post by remb0 »
i got now:
avrdude -v -p atmega2560 -c stk500 -P /dev/ACM0 -b 115200 -D -U flash:w:/home/pi/RFLink.cpp.hex:i
 Programmer Type : STK500V2
         Description     : Atmel STK500
         Programmer Model: Unknown
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
Stuntteam
Post by Stuntteam »
Why the -D ?
NietGiftig
Domoticz version: V3.6224
Post by NietGiftig »
Do you have to stop Domoticz that is using Rflink?
RPI-2 + SSD / ESPEasy Sensors & Switches / Sonoff / RFLink / Action Switches / TP-Link switch / Node-Red / Reacticz
Maarten112
Post by Maarten112 »
Hi Guys,
I'm a new Domoticz and RFLink user since a week now....Thanks for all the great work on both the RFLink hardware and Software. So far it's working great, despite the fact that i'm living in a heavily 433MHz crowded location.
Firmware updating is plain simple for everyone that has ever worked with arduino:)
peerkersezuuker
Post by peerkersezuuker »
Same message as remb0.
So updated with my windows machine, would be nice indeed to have an working updater for linux/Pi
rokib
Post by rokib »
hi,
can someone give me the link to latest beta firmware.
Derik
Post by Derik »
rokib wrote:hi,
Perhaps...
https://sourceforge.net/projects/rflink ... =directory
Or:
http://www.nemcon.nl/blog2/2015/07/bb ;) ;) ;) ;)
Or:
https://www.google.nl/?gws_rd=ssl :lol: :lol: :lol: :lol:
Stuntteam
Post by Stuntteam »
He probably means Domoticz beta.. For Pi you can enable the betas under settings.
jumbotroll
Post by jumbotroll »
How to update RFLink on Synology NAS:
1. Download and install avrdude.spk for your synology from my server: http://www.jadahl.com/synology/
2. Copy the newest RFLink.cpp.hex file to a folder on your NAS, for example /volume1/web
3. Go to Hardware settings in Domoticz and temporary disable (not delete) RFLink.
4. Telnet or ssh your NAS and type:
avrdude -v -p atmega2560 -c stk500 -P /dev/ttyUSB1 -b 115200 -D -U flash:w:/volume1/web/RFLink.cpp.hex:i
Remember to edit correct directory and USB port you using!
5. Go to Hardware settings in Domoticz and enable RFLink.
The end :-)
https://paypal.me/Jumbotroll
Jumbotroll
Larsja
Domoticz version: V2.3530
Post by Larsja »
remb0 wrote:i got now:
Hi, did you find out about this remb0? Im getting the same problem.
My RFLink is just 2 meters away, but in near future, im gonna put it in a cabinet, and thus it would be sweet to update it via RPi and skip the usb to windows machine :)
remb0
Post by remb0 »
no solution found and tested. I used USB that time. so stil trying (only it's not here but @ my brothers house.
