Is it possible for me to do something?
I spend last night trying to read Domoticz temperature values with Tasker. JSON API in Wiki http://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s doesn't help much. Searching and reading several threads gives me "type=devices&rid=<DEVICE_ID> and I got it running. Is there any documentation about types, parameters and commands? If not - can I do something to put together kind of a list?
-Jussi-
Domoticz API/JSON?
alfred_j_kwak
- Domoticz version: 2.3530
- Keptenkurk
- Target OS: -
Re: Domoticz API/JSON?
In this message Gizmocuz points to getting the info from the source code mainworker.cpp especially the decode_xxx parts. Now this doesn't solve the puzzle for me as a c++ noob (even installed notepad++ for it), but maybe someone else can show how to interpret this to get a working JSON from there. Would love to add it to the Wiki
sebas
The API isn't very well documented so it's a bit of reverse engineering. For the Android app I looked at the sources of the web frontend and used the developer console of Chrome to track all the API commands that are send by website.Keptenkurk wrote:In this message Gizmocuz points to getting the info from the source code mainworker.cpp especially the decode_xxx parts. Now this doesn't solve the puzzle for me as a c++ noob (even installed notepad++ for it), but maybe someone else can show how to interpret this to get a working JSON from there. Would love to add it to the Wiki
What are you trying to do using json?
gertjuhh
Could you please add your missing findings to http://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s ?sebas wrote:The API isn't very well documented so it's a bit of reverse engineering. For the Android app I looked at the sources of the web frontend and used the developer console of Chrome to track all the API commands that are send by website.Keptenkurk wrote:In this message Gizmocuz points to getting the info from the source code mainworker.cpp especially the decode_xxx parts. Now this doesn't solve the puzzle for me as a c++ noob (even installed notepad++ for it), but maybe someone else can show how to interpret this to get a working JSON from there. Would love to add it to the Wiki
The more people contribute, the better the documentation will become.
- Keptenkurk
- Target OS: -
Nothing special really. My use case was to get some Space Weather (solar flux, A index, K index) into the dashboard. These indicate radio propagation possibilities - which is another hobbyWhat are you trying to do using json?
Sure will!Could you please add your missing findings
/paul
seblang
hi
I want to command a light with external http command :
http://XXXXXX:[email protected]:8080/j ... itchcmd=On
when I start this commande in script i have :
Iacces not authorizzed for command : http://XXXXXX:[email protected]:8080/j ... itchcmd=On
on the wiki it is a comment about Authorization (https://www.domoticz.com/wiki/Domoticz_API/JSON_URL's)
I have found solution to convert to base64 Encode. but i do not know how to use it!
thank for help
seb
thank for help
seb
mrcage
You should try Basic Authentication or disable the authentication for local networks
Domoticz newbie :)
