Domoticz API/JSON?
alfred_j_kwak
Domoticz version: 2.3530
Domoticz API/JSON?
Post by alfred_j_kwak »
Is it possible for me to do something?
I spend last night trying to read Domoticz temperature values with Tasker. JSON API in Wiki http://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s doesn't help much. Searching and reading several threads gives me "type=devices&rid=<DEVICE_ID> and I got it running. Is there any documentation about types, parameters and commands? If not - can I do something to put together kind of a list?
-Jussi-
Keptenkurk
Re: Domoticz API/JSON?
Post by Keptenkurk »
In this message Gizmocuz points to getting the info from the source code mainworker.cpp especially the decode_xxx parts. Now this doesn't solve the puzzle for me as a c++ noob (even installed notepad++ for it), but maybe someone else can show how to interpret this to get a working JSON from there. Would love to add it to the Wiki :roll:
sebas
Post by sebas »
Keptenkurk wrote:In this message Gizmocuz points to getting the info from the source code mainworker.cpp especially the decode_xxx parts. Now this doesn't solve the puzzle for me as a c++ noob (even installed notepad++ for it), but maybe someone else can show how to interpret this to get a working JSON from there. Would love to add it to the Wiki :roll:
The API isn't very well documented so it's a bit of reverse engineering. For the Android app I looked at the sources of the web frontend and used the developer console of Chrome to track all the API commands that are send by website.
What are you trying to do using json?
gertjuhh
Post by gertjuhh »
Could you please add your missing findings to http://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s ?
The more people contribute, the better the documentation will become.
Keptenkurk
Nothing special really. My use case was to get some Space Weather (solar flux, A index, K index) into the dashboard. These indicate radio propagation possibilities - which is another hobby :) But next will be changing the temperature set value for my heating control script (so changing a dummy temperature). (but it's still so warm outside, my heater hasn't even been switched on)...
Sure will!
/paul
seblang
Post by seblang »
hi
I want to command a light with external http command :
http://XXXXXX:[email protected]:8080/j ... itchcmd=On
when I start this commande in script i have :
Iacces not authorizzed for command : http://XXXXXX:[email protected]:8080/j ... itchcmd=On
on the wiki it is a comment about Authorization (https://www.domoticz.com/wiki/Domoticz_API/JSON_URL's)
I have found solution to convert to base64 Encode. but i do not know how to use it!
thank for help
seb
mrcage
Post by mrcage »
You should try Basic Authentication or disable the authentication for local networks
Domoticz newbie :)
