StellaZ valve setup
- Westcott
StellaZ valve setup
Finally managed to include my new StellaZ valve.
Eventually found an on-line quick-start guide that said to push/hold the button down for at least 10 secs, with the controller in include mode.
http://www.vesternet.com/downloads/dl/f ... manual.pdf
It worked for me!
Does anyone know how to set the thermostat operating mode to Direct Control?
Direct Control: BASIC SET 0xfe, THERMOSTAT MODE SET 0x1f
Can the device be made to stay awake for longer than 5 secs?
It worked for me!
- johnwulp
- Domoticz version: 3.4834
Re: StellaZ valve setup
Hi, did you manage to set the device in direct valve mode? I also can't change it anywere
if it ain't broke don't fix it!
- Westcott
No, I never managed to do it.
Instead I just change the setpoint to 25 if I want it on, and 18 if off.
Or whatever the current thermostat setting is for the room, because the StellaZ is pretty good at working as a thermostatic valve!
- Domoticz version: 2022.2
I also adjust the setpoints, works great. Other question, how often do you need to change the batteries? Looks like every 2 or 3 months here.
- Westcott
I'd guess 2 months maximum for mine.
Usually mine tells me it wants new batteries by going into a deep sleep.
That's usually when the batteries are down to about 1.3V.
These half used batteries are then used in the room wall thermostats until they are really dead.
Ok, I thought it had something to do with my setup. I disabled polling and have a wake-up time of 5 minutes.
- Westcott
I think it's the 5 minute wake-up that we both use.
If the valve is left to its own devices <unintended pun> the batteries will likely last much longer.
Can you measure your batteries' voltages next time you change them?
- johnwulp
Ok thanks!
For the battery's I use another approach. I bought several stepdown converters http://dutchrfshop.nl/voedingen/mini-st ... erter.html. Just connect them to any old 12v or 5v adapter. With the potentiometer you can set the output voltage to 3v. I soldered the output wire's directly on the power lips on the stellaz where normally the battery's should make contact.
- johnwulp
There is a new beta available today. In this beta release it should be possible to change the temp. mode. On my raspberry I only want to run a stable release, so i can't test it
- johnwulp
I Tried the new beta on my raspberry, could not wait anymore.
After updating i have a new device with type "Thermostat Mode" It looks like this:
And it's possible to set a mode:
But it doesn't actually update the device itself:
It's still in comfort mode. Can somebody explain what it is i'm doing wrong?
- gizmocuz
The device will wakeup after xxx seconds (specified in the configuration parameters), after this, it will change the mode
Or you wakeup the device before, then change the mode
- johnwulp
Well, i have set the update interval to 60 sec, al long time ago. Is there anything else i can check?
