StellaZ valve setup
Westcott
StellaZ valve setup
Post by Westcott »
Finally managed to include my new StellaZ valve.
Eventually found an on-line quick-start guide that said to push/hold the button down for at least 10 secs, with the controller in include mode.
http://www.vesternet.com/downloads/dl/f ... manual.pdf
It worked for me!
Does anyone know how to set the thermostat operating mode to Direct Control?
Direct Control: BASIC SET 0xfe, THERMOSTAT MODE SET 0x1f
Can the device be made to stay awake for longer than 5 secs?
johnwulp
Domoticz version: 3.4834
Re: StellaZ valve setup
Post by johnwulp »
Hi, did you manage to set the device in direct valve mode? I also can't change it anywere
if it ain't broke don't fix it!
Westcott
Post by Westcott »
No, I never managed to do it.
Instead I just change the setpoint to 25 if I want it on, and 18 if off.
Or whatever the current thermostat setting is for the room, because the StellaZ is pretty good at working as a thermostatic valve!
jannl
Domoticz version: 2022.2
Post by jannl »
I also adjust the setpoints, works great. Other question, how often do you need to change the batteries? Looks like every 2 or 3 months here.
Westcott
Post by Westcott »
I'd guess 2 months maximum for mine.
Usually mine tells me it wants new batteries by going into a deep sleep.
That's usually when the batteries are down to about 1.3V.
These half used batteries are then used in the room wall thermostats until they are really dead.
jannl
Post by jannl »
Ok, I thought it had something to do with my setup. I disabled polling and have a wake-up time of 5 minutes.
Westcott
Post by Westcott »
I think it's the 5 minute wake-up that we both use.
If the valve is left to its own devices <unintended pun> the batteries will likely last much longer.
Can you measure your batteries' voltages next time you change them?
johnwulp
Post by johnwulp »
Ok thanks!
For the battery's I use another approach. I bought several stepdown converters http://dutchrfshop.nl/voedingen/mini-st ... erter.html. Just connect them to any old 12v or 5v adapter. With the potentiometer you can set the output voltage to 3v. I soldered the output wire's directly on the power lips on the stellaz where normally the battery's should make contact.
johnwulp
Post by johnwulp »
There is a new beta available today. In this beta release it should be possible to change the temp. mode. On my raspberry I only want to run a stable release, so i can't test it :roll:
johnwulp
Post by johnwulp »
I Tried the new beta on my raspberry, could not wait anymore.
After updating i have a new device with type "Thermostat Mode" It looks like this:
And it's possible to set a mode:
But it doesn't actually update the device itself:
It's still in comfort mode. Can somebody explain what it is i'm doing wrong?
gizmocuz
Post by gizmocuz »
The device will wakeup after xxx seconds (specified in the configuration parameters), after this, it will change the mode
Or you wakeup the device before, then change the mode
johnwulp
Post by johnwulp »
Well, i have set the update interval to 60 sec, al long time ago. Is there anything else i can check?
